Drag Racing Tech
SFI 25.2 Mustang/LSx build "The Renegade"
Old 07-10-2009, 07:35 AM
  #1941
z28rob18's Avatar
Originally Posted by slammer454
funny how things change...and snowball...and leave you broke.
i hear that my car started as a minor rebuild now look at it. and im broke good luck tonight. look forward to hearin how it went
Old 07-10-2009, 08:15 AM
  #1942
ATVracr's Avatar
See you guys there tonite !
Me and Shiz are heading down to give Smith a hand.
Old 07-10-2009, 08:17 AM
  #1943
7 Second Club
Phil99vette's Avatar
The car is loaded up just need to put the tool box together and throw the generator in the truck. I've definitely got some pre-race jitters, yesterday was a very productive day. My oil pressure sender wasn't working correctly, fixed that. I was very concerned with my BS3 box, we had to removed 40% fuel just to get it to idle. Turns out on the reflash one of the tables got corrupted and was adding 100% fuel. Needless to say I did 6 transbrake tests and got the fuel right to 5000rpms. Its using 23% more fuel than it did last year @ the same VE/RPM with less timing. I went ahead and added 20% fuel up top and removed 5 degrees of timing just to be safe.
Pulled the control arms off and changed them over to double adjustable and everything looks good in the engine. Scaled the car and finished up a couple loose ends. The interior is a wreck but thats fine with me.
Old 07-10-2009, 08:18 AM
  #1944
buzz12586's Avatar
Good luck tonight.
Old 07-10-2009, 12:50 PM
  #1945
Wnts2Go10O's Avatar
Good luck guys
Old 07-10-2009, 03:55 PM
  #1946
fenton06's Avatar
We demand videos!
Old 07-11-2009, 02:18 AM
  #1947
brandoz28's Avatar
so how'd it go?
Old 07-11-2009, 08:24 AM
  #1948
Fireball's Avatar
I'll let phil chime in...but its definately making a sh%t-ton more power (based on VE table additions) and its a little tricker to get down the track
Old 07-11-2009, 10:04 AM
  #1949
7 Second Club
I'll post here shortly but man the car is making a TON of power, we left 500rpms short of last year and went a 1.36 60'(1.33 last year). Had a bunch of small issues that will be fixed this week...more shortly...
Old 07-11-2009, 12:36 PM
  #1950
7 Second Club
Long story short.....
1st pass, left @ 3800 and 4.5 psi, picked up the front tires pretty good and hung them for 20-30', didn't turn the AMS-1000, 5.7 @ 126
2nd pass, tossed the fuel pump belt && Timer problem
3rd pass, left @ 3800 and 3.6psi, left soft never got no the tire and shook as power came in
4th pass, upped the leave RPM to 3900, somehow we got 5.9psi and killed the tires
5th pass, dropped the leave RPM to 3800 and still ended up with 5.5psi due to changing the 2 step low and killed the tires.
Looking back, we're going to go back to our 1st pass setup and apply boost there, we were chasing the car the entire night.
Old 07-11-2009, 01:44 PM
  #1951
Shawn @ VA Speed's Avatar
don't forget the mph,139-141 on most of the runs,last run went 150,picked up 8mph with 3 lbs of boost.can't wait until we put some timing in it
Old 07-11-2009, 01:57 PM
  #1952
7 Second Club
All with 22-23% converter slippage.... Engine is making too much powa!
Old 07-11-2009, 02:12 PM
  #1953
never too much power,i told you last night the converter needed tightened up
Old 07-12-2009, 08:20 AM
  #1954
Fireball's Avatar
we told him that WEEKS ago
Old 07-12-2009, 04:55 PM
  #1955
gator's 99TA's Avatar
you guys must be making a BUNCH more power if you are seeing that much slippage compared to last years results with that converter.
114 single?
Old 07-12-2009, 05:23 PM
  #1956
114 single?
still the same 106,just made some improvements to the engine-it must have liked them
Old 07-12-2009, 06:05 PM
  #1957
bballr4567's Avatar
Thats still pretty damn fast. Gonna be interesting when you get the car dialed in.
Old 07-12-2009, 08:29 PM
  #1958
87Lt1Monte's Avatar
How do you calculate converter slippage?
Old 07-12-2009, 10:38 PM
  #1959
Wnts2Go10O's Avatar
from wht uve been saying it REALLY liked the changes if uve gained 2-300hp or more. arent you guys gonna try and run more boost this year?
Old 07-13-2009, 05:58 AM
  #1960
Fireball's Avatar
by comparing driveshaft speed to engine speed in high gear.
Quick Reply: SFI 25.2 Mustang/LSx build "The Renegade"
