Difference between K&N filter versus Stock Filter...take a guess
On monday at work i will run some pressure drop tests on both a K&N element and a stock Paper element...this will be the true test of which is more restrictive and by how much...
going to do the flow at various CFM...
probably 100-700CFM...
REFERENCE: For my cam only at WOT the max mass flow i saw at my throttle body was 330g/s using the density of air you get around 591CFM...
make some guesses i am going to use pressure of inches of water column just so it is more accurate...
Ref again: around 28" H2O is 1 PSI
I am going to guess at 600 CFM the K&N will have around 3-4" less pressure drop...
Hopefully we will be able to quantify these results into rear world hp numbers of some sort...
No it wasn't the conditions. Ran first past 13.16 took out air filter and ran 12.92. I also have a 10 second mustang that has made 400 passes and the camaro is my new project. I've made this same test several times before and have even switched from a stock to a slp lid on consecutive runs with no changes.
