6.0 ms4 ported 243s 431whp
Old 07-24-2009, 06:15 PM
thats_10kid's Avatar
Default 6.0 ms4 ported 243s 431whp
Finally got my car fully tuned and dyno...(TAHNKS TO GFORCE!!)
02 camaro m6..6.0, ms4 cam, ported 243 heads, 12 bolt with 4.10s
431wph and 403 lb torque
http://www.youtube.com/watch?v=BjzeUrANcXw
Old 07-24-2009, 11:25 PM
caviness's Avatar
nice numbers for sure,and a little more left in it to.what else you got done??
Old 07-25-2009, 07:49 PM
registered user
ScreaminRedZ's Avatar
Damn, that car's gotta pull hard! Future plans for the car?
Old 07-26-2009, 10:15 AM
Ya it would pull pretty good If I could get traction I still got the stock 16s with 245s....need to look into some cheap rims here soon...as far as future plans...probably just a fast 92 intake and maybe some spray.. But now that I have the 6.0 I wanna make it a 408 and go from there but that won't be for awhile..
Thanks for the nice replys!!
Old 07-27-2009, 01:57 AM
BlkBird2000's Avatar
Nice numbers. What exactly is a 6.0? Does the ls1 block have to get machined or something?
Old 07-27-2009, 06:21 PM
WSsick's Avatar
im assuming its an lq4 or an lq9, sinec those go for cheap, but it could be an ls2. if its an lq motor, whats your compression? good numbers regardless man. pretty good torque for an MS4
Old 07-27-2009, 07:34 PM
its an lq4..And i dont know about the compression..
thanks!
Old 07-28-2009, 05:53 PM
JS01's Avatar
Not trying to bash your setup but I guess I'm the only one that thinks those numbers seem low for a 6.0, ported 243's, and a huge cam like a MS4. The LQ4 dished pistons must have lowered your compression quite alot, possibly the gears played with the numbers a bit.
Old 07-28-2009, 06:01 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
Nice numbers for a car that is most likely a little soft on compression, not to mention the 12-bolt! With some more compression and a FAST intake that car might hit 450rwhp.
Old 07-28-2009, 08:53 PM
lilbuddy1587's Avatar
Yep, JUST TOSS A FAST ON IT!
Old 07-29-2009, 01:57 AM
blackedout drop ls1's Avatar
Good numbers
Old 07-29-2009, 08:59 AM
ryarbrough's Avatar
I agree... What are the heads milled to? What cc's? Gasket thickness?
Looks like it's not making power as high in the rpm band as that cam should, but I can't really tell because the RPM figure is cut off of the picture (probably a function of low CR)
You'll love that cam with the M6 and a good tune. Build the 408, add compression, and it'll pull to the moon.
Old 07-31-2009, 05:25 PM
chrs1313's Avatar
nope i agree too the numbers are low...unless he doesnt have full bolt on or something strange...
Old 07-31-2009, 06:07 PM
Nitroused383's Avatar
I thought they were low too but everytime I critque a setup some guy jumps in saying to just leave the guy alone the car will run great. You have almost 20 more cubes on a 346, ported heads and a huge cam. 430/400 through an m6 is kind of on the low side. Ya you can throw a fast on it but you should be able to do 450 without a fast so your numbers will still be low.
Are those SAE or STD numbers?
Old 08-03-2009, 06:25 PM
hmm well some people have told me there low some have told me there average...so idk...either way it does the job..and its good enough for me (for now) lol
Old 08-03-2009, 07:31 PM
30th t/a's Avatar
I agree with the others. I think those are a little on the low side.
Old 08-06-2009, 12:01 PM
ricknbird350's Avatar
im still curious if he has other bolt ons...hedders?,intake?,cai?full exhaust? maybe he has manifolds still on it and its holding him back.
Old 08-06-2009, 12:09 PM
RS_SS69's Avatar
I second that, sounds like you have true duals? If so what kind or are you just running off the cutout?
Old 08-09-2009, 03:06 AM
it has...
SLP Lid
Ported TB
All free Mods
Stainless Works Long Tube headers
Stainless Works Y-pipe
DMH cutout where the Y meets togeather..
MS4 cam
ported and polished 243s
42lb ford injectors
underdrive pulley
12 bolt with 4.10 gears
LS6 intake
LQ4 6.0
thats all i can think of for now..
Old 08-09-2009, 11:05 AM
tillery's Avatar
Well with an LS6 intake and possible less than stellar compression your power looks good. Keep that cam for you stroker build and a killer topend(heads/intake). Work on getting power to the ground and let us kno track results.
Quick Reply: 6.0 ms4 ported 243s 431whp
