Fireball Outlaw Drag Radial Rebuild Thread
Old 01-15-2010, 05:27 PM
  #261
DanZ28's Avatar
Fireball, you have any pics of the bottom? That floor work sure is different going up to the inside main bar like that. Looks good though.
DanZ28 is offline
Old 01-15-2010, 05:35 PM
  #262
Fireball's Avatar
Just these from when we first did it...
Fireball is offline
Old 01-15-2010, 06:05 PM
  #263
DanZ28's Avatar
Thanks.
When you get some the way it is or will be that would be cul. This is a 25.2?
DanZ28 is offline
Old 01-29-2010, 07:13 AM
  #264
Fireball's Avatar
New hood arrived yesterday. Just sat it on the car for now.
Fireball is offline
Old 01-29-2010, 07:17 AM
  #265
Race your car!
JL ws-6's Avatar
That hood looks farmiliar... too bad mine's never gonna even get mounted at the rate I'm going
I do like the accusump setup, where are you plumbing that in? It's one of those things I've thought/considered adding to the list, but wasn't sure where it gets plumbed into the block on these cars.
JL ws-6 is offline
Old 01-29-2010, 07:34 AM
  #266
Fireball's Avatar
plumbs in nice with a moroso pan setup...had it the last two years.
Fireball is offline
Old 01-29-2010, 08:35 AM
  #267
Race your car!
JL ws-6's Avatar
Aah, so you have it in the return line after the filter (or before).
Makes sense, I'll have to look into that, was planning on putting a moroso pan on the car.
remind me how that works, you start the car the first time with it open, it gets filled with pressurized oil, then you close the valve, and next time you start the car you open the valve first right, then close after the car's running, etc.?
Reason I ask is alot of people put those inside the cabin so the driver can get to it.
JL ws-6 is offline
Old 01-29-2010, 08:40 AM
  #268
Fireball's Avatar
oil lines are technically not allowed inside the cabin. they make electric solenoids that can be opened/closed with a switch from inside the car too...
prepressurize with oil (first time its installed) by filling with oil and using air pressure to preload it. before starting car open valve and it prelubes the motor. before shutting off car close valve (oil pressure will hold it full). leave it open during the run...if the motor is starved for oil for whatever reason it'll put the reserve oil thru the motor.
Fireball is offline
Old 01-29-2010, 10:33 AM
  #269
UNDER PRESSURE MOD
The Alchemist's Avatar
The build looks great Brian. That new hood looks mean as well.
The Alchemist is offline
Old 01-29-2010, 10:36 AM
  #270
Race your car!
JL ws-6's Avatar
Makes sense. Not sure where I've seen one inside.. but that might have been on an older car before that became a rule (no oil inside the cabin)
Sounds like it's simple enough to set up, probably worth looking into too (being that a race car suffers from more damage at startup then most cars, due to them being started and shut off alot more during their lives)
JL ws-6 is offline
Old 01-29-2010, 02:32 PM
  #271
Fireball's Avatar
few more pics of the hood
Fireball is offline
Old 01-29-2010, 03:45 PM
  #272
dacajun's Avatar
The hood looks nice. Those birds sure do look mean from the front!!! Nice build!!!
-Dave
dacajun is offline
Old 01-29-2010, 07:13 PM
  #273
DanZ28's Avatar
Very nice look'n hood.
DanZ28 is offline
Old 01-31-2010, 06:37 PM
  #274
dschmittie1's Avatar
Love the new Hood Brian. It seems like things have slowed down a little as far as progress on the car. I realize it is a HUGE project and requires lots of $$ but they way things were rolling in the fall it seemed like you wanted to be back out this year yet. Hope things come back together quickly and that bad *** car is back ready to put up some big numbers.
I know how it is though I was hoping to have my car back together by mid February and now it is looking like mid March. You still willing to come out and sign for my licensing passes? I know I will need it this year
dschmittie1 is offline
Old 02-01-2010, 06:29 AM
  #275
Fireball's Avatar
Just haven't been 100% motivated to go out in the garage to work on it haha.
I have no ambitions to finish the car until next year anyhow. When the weather starts warming up I'll probably spend more time on it
Fireball is offline
Old 02-01-2010, 01:01 PM
  #276
DanZ28's Avatar
I know that feeling well .
DanZ28 is offline
Old 02-07-2010, 09:29 AM
  #277
Fireball's Avatar
Since I've been snowed in due to the blizzard of 2010...I decided to start working on making the front end removable as one piece. Started with a VFN removable front end kit.
here it is mocked up on the ground:
Note the clecos...they are holding the front attachment plates. Here is a picture from the back side. The bar that goes across the bumper is what holds the front in place...locking it in place both up/down and side to side. The small bar in the back is just for mockup...keeps the back of the fenders at the proper distance.
These are the plates that the front bar interlock with
Now its time to cut a sh%t ton of metal out of the front
Fireball is offline
Old 02-07-2010, 11:14 AM
  #278
White.Lightning's Avatar
Looks good Brian. Is the hood still functional (can it open)? Are the fenders and bumpers locked in with dzus fasteners?
White.Lightning is offline
Old 02-07-2010, 11:53 AM
  #279
Fireball's Avatar
hood will be removable, but pin on (dzus). The assembly (as I envision it) will be removable after undoing 6 dzus fasteners in the back (3 on each side)
Fireball is offline
Old 02-07-2010, 03:22 PM
  #280
7 Second Club
Phil99vette's Avatar
Looks good, gives me one more thing to do...
Phil99vette is offline
Quick Reply: Fireball Outlaw Drag Radial Rebuild Thread
