Procharger guys
Old Jan 28, 2010 | 08:02 AM
  #241
TWS's Avatar
TWS
Originally Posted by blue00ZZleeper
10 psi and as high of timing as you can go without knock should easily make 560+. Do you run meth as well? Well an update on my car...I got into a small fender bender on sunday night. Its not to bad but it sets my plans back a little bit. Windshield needs to be replaced as well as the dash. Guess I need to wait to do the EPP cam lol
Sorry to hear about the fender bender. That sucks.
No meth, unfortunately.
My goal is not to get every last HP out of it. Keeping the stock motor in mind, we will continue to tune very cautiously and keep the tune conservative. Meth would help, but I don't have a kit installed. Last time we tuned it to where there was no knock, verified that by a dyno pull, and then took an additional 1/2 degree out for safety. Also keeping the AFR 11.2-11.5 over the RPM band at WOT. If I had a built and forged boost motor, I'd go 11.8 AFR, but we need to protect the weak little stocker.
Old Jan 28, 2010 | 02:14 PM
  #242
99 black ss sj's Avatar
Is there SC system for an Fbody that is not as loud as a disk just like novi for corvete
Old Jan 28, 2010 | 03:29 PM
  #243
blue00ZZleeper's Avatar
Sounds like a good game plan. My first run before I put the meth on with stock 853's, 226-232 113lsa, on 9ish psi made 575 with no knock around 15deg. AFR was 11.5 throughout the whole run. Meth is a nice saftey blanket and you can also tune for it if you wish to. If I was you I'd look into running a meth kit. I got mine from cooling mist for around 500 bucks. Easy to install and its nice knowing its a little safer. I'm still on my stock bottom end for another couple of weeks. The forged motor should be getting done shortly. Insurance adjuster will be out on monday to see what the deal is. All I want done is the windshield and dash/steering wheel at min.
Old Jan 28, 2010 | 03:41 PM
  #244
LS1RedZ's Avatar
Originally Posted by Lawnboy
01 SS M6
Built/forged LS6/D1-sc /4.5" big twins/ Two BOV's/ 3.7 blower pulley
Custome Auto spring tentioner set up, (not the sd-concepts unit)
SD tune/alky control/M-5 meth
@15 PS1 6,300 rpm , 17 degs timming
Very small Blower cam (no overlap) spect out by me
776/697 uncorected
740/667 ASE corrected
It has more
Nice numbers. What is your compression? What heads and intake? Header size?
My car:
Built/forged 370 (9.1:1 comp.)
TEA Stg 2 LS6 heads, LS6 intake, 1 3/4 headers
Big red valve, EPP FMIC
3.4 pulley
EPP blower cam
Tune was on pure pump gas
Car made 754rwhp & 707rwtq
You guys think I would see a good gain going with a Vic Jr setup and bigger headers? What about different heads? Just been wondering about this.
Old Jan 28, 2010 | 07:55 PM
  #245
zssman's Avatar
Any F1r builds or set up pics out there. f-bodys? Lookin at doin a F1r for local 275 racin. Lets see em.
Old Jan 28, 2010 | 09:18 PM
  #246
dense0420's Avatar
Default procharger!
http://memimage.cardomain.com/ride_i...009_medium.jpg
Old Jan 28, 2010 | 11:05 PM
  #247
Lawnboy's Avatar
Restricted User
Hello LS1REDZ how much boost you making on your set up?
OK i am running A/S stage 1X ported 241 castings, flow about 300 at .550-.600
Using the diamond -8.6 cc boost pistons, i should be around 9.3-9.5 compression
Using the Stock LS6 intake and accufab 75 mm polished Throttle body
Using FLP 1 3/4" Long tubes, (small) 2.5" Y pipe, no cats, and that is going to my "stock"
SLP single 3" exhaust to the stock SS duel duel SLP muffler exhaust
Old Jan 29, 2010 | 02:50 AM
  #248
NEED MO POWA!'s Avatar
Here is my set up
http://www.youtube.com/watch?v=19hdYpTavuQ
Old Jan 29, 2010 | 10:50 AM
  #249
LS1RedZ's Avatar
The car saw 15psi on that run.
Old Jan 29, 2010 | 11:56 AM
  #250
Elite_Hot_Rod's Avatar
A couple pics of mine.
Old Jan 29, 2010 | 08:38 PM
  #251
danbap's Avatar
need mo powa! what kit is that?
Old Jan 29, 2010 | 08:48 PM
  #252
Rickys S/C Z28's Avatar
**** yes!!!!!!!!!!!!!!!
Old Jan 29, 2010 | 09:43 PM
  #253
TWS's Avatar
TWS
Total baller.
Makes my car look like a Toyota Prius by comparison.
Old Jan 30, 2010 | 10:21 AM
  #254
Total baller.
LMAO, thanks. I almost spit coffee all over my monitor. We built it as an all out race effort to run in our local Texas True Ten.5 Extreme Street class. It's a 99 T/A 401 CID solid roller, A2W intercooler, P/G with a Neil Chance converter, fabbed 9" w/4:10 gears and alot of other bells and whistles. Had a couple set backs early on and haven't had a chance to get any goods runs in on her yet, it made over 900 RWHP on 16 lbs of boost on the dyno during the initial tuning pulls and made 26 lbs of boost during track testing. Hoping for consistant 5.3X's in the 1/8th and some 5.1X's with some good air. Should be a monster.
Old Jan 30, 2010 | 10:42 AM
  #255
TWS's Avatar
TWS
That's awesome. If you have any races down at San Antonio Raceway, send me a PM in advance. I'd love to see the car run and check it out in person.
Old Jan 30, 2010 | 07:54 PM
  #256
lablackbeast's Avatar
doesn't know what quit means
this is a guys 4 door chevy silverado that is on another forum ..... his set up is 6.0 lq4 with stock heads, stock intake manifold, and stock tb, and has a d1 with cam only and regular bolt ons with a 3200 stall with 410s and the stock g80 ..... vs a gto ls2 with heads, cam, stall, fast intake and ..... car runs 12.0s with traction problems, truck runs 11.8s full weight and taking off easy do to the spnning of the stock g80 with a 1.71 60ft ..... truck has more in it
http://www.youtube.com/watch?v=YtaOdZI-L2o
Old Feb 3, 2010 | 04:40 AM
  #257
zssman's Avatar
Default f1r
Exellent! any more pics, intercooler location, set up? cog belt? What s/c mounting bracket r u using? Raceweight? More details sir. Thanks Phil.
Old Feb 3, 2010 | 08:26 AM
  #258
Lawnboy's Avatar
Restricted User
I am running a custome J bracket, using the extra supercharger mounting bolt hole, J bracket is a little wider for more strenth, GM auto spring belt tentioner with 8 rib pullies , Using this Custome set up alllowes you to keep your ATI procharger 7.65 8 rib crank blower pulley , but a LS3/LS7 water pump is required because they have a low profile pump pulley.
My set up was upgraded to having all my pullies snap ringed to prevent bearning walking, so far so good
Old Feb 3, 2010 | 01:44 PM
  #259
The bracket was manufactured by Jakes Performance Solutions. Our race weight is 3300 LBS minimum. I have alot of pictures of the build but haven't downloaded them to imageshack yet. Anything else you want to know just ask.
Old Feb 3, 2010 | 08:35 PM
  #260
Well good news here guys. Insurance company is giving me 6100 for repairs lol. It needs windshield and a dash and will be good to drive. I've been looking at getting a forged 370 and boosting it as much as the D1 will go. What do you guys think for heads? CNC'd 317's? What about possible power? Rest of the parts will be reused from my sig. All input is welcome.
