Procharger guys
Old Feb 16, 2010 | 11:43 AM
  #301
TWS's Avatar
TWS
Originally Posted by -Q-
So, out of an abundance of caution, would you guys recommend pinning a 6-rib setup? Or should I just wait until I go 8-rib, which will probably be sometime within the year?
From your previous post, it sounds like you have already purchased a 6-rib kit?
If I am mistaken and you have not, then just hold off and buy an 8-rib kit from the begining. Don't fool around with the 6-rib.
Old Feb 16, 2010 | 12:28 PM
  #302
-Q-'s Avatar
-Q-
Yeah, I have the 6-rib already.
Old Feb 17, 2010 | 11:11 AM
  #303
Mr. Trick's Avatar
Alot of awesome cars in this thread. But, someone needs to go get some pictures and daytime videos of inspector12's car lol.
Originally Posted by Inspector12
Well here is one video of my car at a meet in Austin a while back its all I have as I don't video or take many pictures of my own stuff etc...
http://www.youtube.com/watch?v=9bifF5hYog4&feature=fvw
Old Feb 20, 2010 | 07:47 AM
  #304
BlkHwk's Avatar
You NEED to pin the crank!!! IF you don't you will have inconsistent boost and risk ruining the nose of the crank.
Old Feb 20, 2010 | 07:50 AM
  #305
EPP's Avatar
EPP
I agree, the crank bolt can loosen up and the balancer can wobble and tearup the crank. Bob
Old Feb 20, 2010 | 08:18 AM
  #306
Rickys S/C Z28's Avatar
plus one on pinning the crank!!!!
Old Feb 20, 2010 | 01:36 PM
  #307
BLNLS1/RX7's Avatar
Must Pin
Old Feb 20, 2010 | 02:12 PM
  #308
sixt9er's Avatar
Nice thread...just when I thought I wanted (for certain) to stick with a NA build...
Damn you guys...
Thanks for all of the inspiration!
Old Feb 20, 2010 | 05:29 PM
  #309
blue00ZZleeper's Avatar
Well just got a set or ARH 2" headders for the build. I cant wait to get it all in the car!!
Old Feb 20, 2010 | 07:17 PM
  #310
TWS's Avatar
TWS
You might be lucky and have no slippage issues. If you haven't installed it yet, go ahead and pin the crank. The DIY fail-proof kit is only like $120 IIRC.
Old Feb 20, 2010 | 10:57 PM
  #311
Taubr Unit's Avatar
yep as well as myself. My set of 2" Kooks should be here monday for my d1 build. Post up some pics, id like to see um
I was doin some reading over on yellow bullet and seen a lot of people sayin if u want big power you should use big headers and how the forced air needs to get out fast. Cant wait to to get my car runnin
Old Feb 20, 2010 | 11:19 PM
  #312
x2 on that one! What are you looking to make/run on your setup? I'm looking at getting the "aster" bracket to avoid belt slip. Hoping to see 16-18psi maxed out and possibly over spinning her just a bit. I'll take pics of all the parts and the headders and all the good stuff!!
Old Feb 20, 2010 | 11:28 PM
  #313
Lawnboy's Avatar
Restricted User
Default NO more belt slip
LSXsolutions has the auto spring tentioner your looking for
Old Feb 20, 2010 | 11:45 PM
  #314
Taubr Unit's Avatar
all these conversion kits seem to cost a ton of money. IMO if i get to that point ill spend a few bucks more and just get a cog kit.
Either way its cool other options are out there. Lets keep the pics coming so we can oooooo-n-ahhhhh over all this stuff
Old Feb 20, 2010 | 11:47 PM
  #315
Taubr Unit's Avatar
lookin to make 600+hp on e85 and set on kill and run high 9s with my 27xx race weight. Im gonna squeeze every last bit outta this lq4 i have n see what the grand total numbers are! Were not gonna be conservative on the tune, its all or none IMO
Old Feb 20, 2010 | 11:55 PM
  #316
Lawnboy's Avatar
Restricted User
Yeah The Spring tentioners do cost a lot , But after burning out (3) thats right three Procharger solid teinioner pulley/bearning asembleys at $100 bucks a pop, i had enough. My auto spring tentioner system is worth every penney and more, the time and heart that went into designing it is worth a lot more, never mind it works Great! I am at 15.2 PSI out of my D1-sc and i am still 3 pulley sizes away from maxing it out, I know i would see 20-22 PSI if i was brave enough But at 740 RWHP the car is pretty scarry as it is.
Old Feb 21, 2010 | 02:04 AM
  #317
-Q-'s Avatar
-Q-
Yeah, I'm definitely going to go ahead and pin it...need to order a new crank bolt anyways, might as well do it now.
I've got another problem now, though...I bought this kit used, and I didn't realize it until now but I'm missing the dowel pins that are used on the crank pulley for the 6 rib setup. I guess the dowel pins hook up to the balancer or something? Really not sure because I have no idea what they are supposed to look like. Is there anywhere I can get these things, or is there another method I can use here? Maybe studs?
Old Feb 21, 2010 | 05:59 AM
  #318
EPP's Avatar
EPP
You should be able to locally source the dowel pins, although if you need to order a new crank bolt you might as well get the dowel pins at the same time. Here is a copy of the installation instructions, which many help you out. http://www.exoticperformanceplus.com...html?item=1043 Bob
Old Feb 21, 2010 | 07:58 AM
  #319
forcd ind's Avatar
i wanted to look at the LSX Solutions tensioner kit, but their website is under const, hard to read with pics posted on top of the info-i use a vette front acces dr setup, with the 2000-2004 vette Procharger setup, didnt know it they had a kit for that or just an F body retro
with the ATI (Perf Prod.) 7.5 8 rib crank pulley, and a 4" dr pulley, on the dyno i only saw 11 lbs boost under the carb, 617 RWHP, 403, AFR 225's, EPP cam-(i dont know where all these huge dyno #'s come from, but i never see them, lol)not sure if i have belt slip or not, on the street i see more boost, but i read that in the carb hat, fig a 1 lb loss thru the carb
Old Feb 21, 2010 | 08:32 AM
  #320
forcd ind's Avatar
heres some early picks of the Chevelle with the old 6.0 ($400) and Procharger, was kind of a budget deal to begin with, i do all my own work, so i save money
got a killer deal orig on the partial Procharger Vette kit, scored a new, never used 3 core sheetmetal Procharger (not imported) intercooler on ebay ($300)
made up my own tubing-it orig made 488 RWHP, ran some high 10's @125
i orig had a switch/pitch turbo 400, i later built a 4L80E on the cheap, best addition ever-ran on Pass Time, filmed last Sept, just aired last week
i now have the 403 in it, more power, lol 617 RWHP, 518 TORQ-the converter def didnt like the dyno
the car is all steel, ful stock interior w/6 pt bar, pretty heavy car
i orig built it to see how it would all work, with the int. of later upgrades-it was so trouble free, i ran it 1 1/2 years like that, lol
i have had prob 10 Procharged cars, B/B's, S/B's, some with massive power, i just like boost, lol-they have all been street cars, i just prefer track rentals now, or a not to crowed T & T, not much into waiting in line for an hour to run anymore
Attached Thumbnails Procharger guys-im001041.jpg   Procharger guys-im001046.jpg   Procharger guys-im001048.jpg
