Procharger guys
Old Jan 12, 2011 | 11:30 AM
  #501
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by kp
Best I have run with a D1SC/347 was 9.17 @ 149mph with a 347 @ 3350lbs.
Took another 3-4 months of fine tuning to get the same combo to run 9.82 @ 152 at the same weight with an F1A.
Anyone who thinks a D1SC cant make the power and is a good upgrade from the P1SC is mistaken, F1R is a waste unless you have a better system to drive it than an 8rib. May work on the dyno but the acceleration in 1st and 2nd gear at the track it will slip. F1A is a good blower, really hits hard down low but it makes the heat as well. IMO LS engines and D1SC is one of the best street/strip combos going. Especially if you get a helical D1SC, F1+ is real noisemaker, but it makes the power for sure.
Nice car Congrats on the times, good to see you kept it around.
"Took another 3-4 months of fine tuning to get the same combo to run 8.82 @ 152 at the same weight with an F1A."
I changed it for you by a second. lol Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jan 12, 2011 | 02:12 PM
  #502
idahoblkss's Avatar
first time poster , i think i finally found a home on this site...
my truck set up....
when i bought it...
my bov ... i love it ...
installed...
Old Jan 12, 2011 | 02:17 PM
  #503
SKINNYPIMP T/A's Avatar
Sorry one more dumb noob. Im wanting to buy a p-1 kit how can i tell if it is the quieter version or the louder? And if i get the quieter is there a way to make it louder? Also other than pinning the crank is there anything else that needs to be done to make it last awhile? Any help appreciated!
Old Jan 12, 2011 | 02:59 PM
  #504
kp's Avatar
kp
Oops, 8.92
Old Jan 12, 2011 | 03:05 PM
  #505
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
F1R is a popular blower for folks running in the high 7's like Jason Lee (7.8's in a Mustang @ 3200). Going from an D1SC to a F1R is a very big jump.
Old Jan 12, 2011 | 04:16 PM
  #506
Taubr Unit's Avatar
PM me if interested in a d1 kit
Old Jan 12, 2011 | 04:31 PM
  #507
slow67's Avatar
Gingervitis Addict
Do you have F.I. A.D.D.?
Old Jan 12, 2011 | 04:51 PM
  #508
Taubr Unit's Avatar
kinda, lol
Old Jan 12, 2011 | 10:06 PM
  #509
helicoil's Avatar
Thanks, I just finally found the right buttons to push.
Are you getting the itch?
Old Jan 12, 2011 | 10:49 PM
  #510
blue00ZZleeper's Avatar
Understood. Looking to run the car as a M6 for a little bit and then putting a built 4L80 in it with some 3.42's I think. Since my blower is the older 5:0.1 steup up ratio I want to upgrade the blower. I want to be able to run 9's when I get the auto in but all I'm expecting with the 6spd is a low 10 with a high trap speed for now. Since the F1R might be, ok...is overkill what would the recommendations be? F1C? Thanks for the knowledgeable input...always appreciated!
Old Jan 13, 2011 | 12:25 AM
  #511
kp's Avatar
kp
Na, I'm playing around with this new 5.0 mustang, these have a ton of potential and it will keep me occupied for a few months
Swap cams in there and I bet you get mighty close to 8s, be pretty cool with a D1SC.
Old Jan 13, 2011 | 07:07 AM
  #512
LS1Tech Sponsor
Thumbs up
You can run 9's with either a D-1SC or an F-1A. Bob
__________________
Old Jan 13, 2011 | 02:39 PM
  #513
mattster03's Avatar
can any recommend a pulley combo to make around 8PSI with a P1SC in my LS1/T56 RX7, here are my specs:
347CI LS1 Engine w/LS6 Intake & ported TB
Futral F7 Cam 224/230 0.585/0.595
Stock 317 Heads with Patriot Dual Springs
Front Mount intercooler
Full Exhaust
BTW, great thread!
Old Jan 13, 2011 | 03:00 PM
  #514
LS1RedZ's Avatar
Full Exhaust
BTW, great thread!
I wanna say the 4.25 because thats what i saw out of it.
Old Jan 13, 2011 | 03:08 PM
  #515
mattster03's Avatar
That's actually what i was thinking as well, so I'm glad you are verifying that. What crank pulley diameter were you using, and did you ever dyno your car?
Old Jan 14, 2011 | 12:12 AM
  #516
Well I think I'm going to look at running the F1C then. I want the CFM capabilities if I decide to go with a larger engine down the road. I believe the upgrade cost is around the same.
Old Jan 14, 2011 | 10:41 AM
  #517
LS1RedZ's Avatar
Yeah I ran that pulley for a little while so I could save up for my fuel system and of course it didnt work out to well lol. I had a racetronix hot wire kit on a stock pump and it made like close to 600 on 7psi at 5500rpms. Ran out of fuel after that. I was using the stock 7.65 crank pulley. Now Im running a 3.4 pulley with Asters bracket at about 16psi.
I dont like you!! lol jk. I want to get a F1C really bad.
Old Jan 14, 2011 | 02:13 PM
  #518
mattster03's Avatar
with a p1sc?!
Old Jan 14, 2011 | 02:26 PM
  #519
fatmat80's Avatar
I would think that LS1REdZ is referring to a d1sc but I could be wrong.
Old Jan 14, 2011 | 03:47 PM
  #520
LS1RedZ's Avatar
with a p1sc?!
Whoops! Just saw you said P1SC. I have a D1SC. sorry about that
