Procharger guys
Old Mar 17, 2011 | 09:52 PM
  #541
g8lover's Avatar
Default Injectors 82 lb siemens for F1d setup 408
Car is up and running but now wondering if my selection on injectors was wrong..... I have a Pontiac G8 with a 403 cu in procharged F1d with a Lonnies fuel system... I used 82lb siemens injectors... (or 80lb?)...
Is this too high or are these injectors seem about right for my setup... I am running 17.5 psi boost at 6000rpm...
(tune is very conservative now)...
the g8 has hard coded limits for the injector size and tune had to be scaled due to this hard coded limit... thoughts????
Old Mar 17, 2011 | 11:34 PM
  #542
blue00ZZleeper's Avatar
Not sure on the PCM and code but those injectors should be just right in size for your setup. Should be a great setup!
Old Apr 13, 2011 | 05:55 AM
  #543
FlyingFinn's Avatar
Default My Procharged '98 T/A
Couple of pics about my P-1SC-1 build. Stock bottom-end with only ARP rod bolts. Patriot CNC ported heads, CC 216/220 114 LSA, LS6 intake, tune by PCM for less, Hooker LTs & cat-back. I can see only 1 psi of boost at the time. Got to do a pressure check...
J-P
Attached Thumbnails Procharger guys-img_1818.jpg   Procharger guys-img_1820.jpg   Procharger guys-img_1825.jpg   Procharger guys-img_1827.jpg   Procharger guys-p11.jpg
Old Apr 13, 2011 | 08:05 AM
  #544
383camaroz28's Avatar
I bought jerrys d1 setup, cant wait to install it!
Old Apr 14, 2011 | 06:37 AM
  #545
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Thumbs up
J-P
Looks good! Let me know what you find out when you pressure check the system. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Apr 15, 2011 | 03:02 AM
  #546
Blown06's Avatar
8 Second Truck Club
Here is my setup F2 procharger
Old Apr 15, 2011 | 06:02 AM
  #547
LS1Tech Sponsor
Thumbs up
That looks sweet! Bob
__________________
Old Jul 5, 2011 | 11:58 PM
  #548
68 SS's Avatar
Bump this is too good to let it die!! Updates guys, I will add some pics of mine tomorrow.
Old Jul 6, 2011 | 07:41 AM
  #549
SS LeadFoot's Avatar
D1SC at 7lbs. Trying to get the rubber hoses replaced with some sort of black metal, having a hard time finding something.
Old Oct 28, 2011 | 04:36 PM
  #550
STLWS6's Avatar
I just put on asters bracket wow this thing is great finally got to 15 psi on a 3.4 pully with a good k and n filter. This bracket is the best hands down tried the poormans belt wrap did not work out for me. I over tightened the super charger and blew out my front seal. So i would skip the stock procharger bracket the best i could ever get was 13 psi. THANKS BOB your the man
Old Oct 29, 2011 | 08:06 AM
  #551
LS1RedZ's Avatar
^^ Hell yeah its a bad *** bracket.
Old Nov 24, 2011 | 10:13 PM
  #552
I8UR4RD's Avatar
Default pinning for ati damper
well i just got my d1sc and im in the pulley process on my car. it says to pin the crank....i cant find any pics...or any directions on how to install the a/c pulley, damper, and the other pulley. i think ive got the right idea...but i sure would like to be SURE.
Old Nov 25, 2011 | 03:26 PM
  #553
The Alchemist's Avatar
UNDER PRESSURE MOD
Yeah, I'm in the process of using the ati kit to pin the crank on the side, and realize that I have to drop the sway bar to do it. Talk about a pain in the *** considering I haven't unbolted the sway bar in probably 8 or 9 years since I put on the BMR back then.
Old Dec 20, 2011 | 05:53 PM
  #554
I8UR4RD's Avatar
Only thing sweeter than that whistle and purr of the blower is the times I will post at the track this spring. Enjoy.
http://www.youtube.com/watch?v=4zQ5iBw8qTY
Old Dec 21, 2011 | 07:51 AM
  #555
LS1Tech Sponsor
Thumbs up
A little late, but you're welcome. Chris builds a bad *** product! Bob
__________________
Old Dec 21, 2011 | 09:16 AM
  #556
LS1RedZ's Avatar
Lets get this thread going again. Anybody planning on new builds for next year?
Old Dec 21, 2011 | 11:41 AM
  #557
taws6m6's Avatar
I've got a build i hope to finally get goin correctly in jan. I've had nothing but problems out of my car. Running the 3.4 pulley. Finally got the car to boost right and the 4l60 lasted 1 tuning session and 2 passes down the track. 1st pass blew a pipe, 2nd blew the trans. I was getting about 16lbs with the poor mans method, but belts dont last long. Currently waiting on a th400 with a brake, and have a yank eliminator going in. I'd like to see a high 9sec pass outta the car
Old Dec 21, 2011 | 04:33 PM
  #558
stevo8's Avatar
I have a question for you guys who have run both, and or tuned both sc and turbo. Which would be a easier setup to learn to tune on the street? I would like to build a turbo setup but like the cleanliness of the sc as well as keeping ac, if tuning was easier then it's a no brainer for me.
Old Dec 22, 2011 | 05:55 AM
  #559
LS1Tech Sponsor
Back at the old shop we use to do a lot of tuning, and while I wasn't the one doing the tuning, it seemed to me the supercharger tunes were always much easier to get dialed in. I know time wise the supercharger tunes took much less time. Bob
__________________
Old Dec 22, 2011 | 05:57 AM
  #560
LS1Tech Sponsor
It sounds like you need the Aster bracket!
http://shop.brutespeed.com/Aster-Aut...er-Bracket.htm Bob
__________________
