Procharger guys
Old Jan 7, 2012 | 09:53 PM
  #581
mikep2002's Avatar
Back to the original topic of this thread. The reason this forum is dominated by turbo setups!!!! Most of them have a ton of problems and they are looking for answers. LMAO!!!!
Procharger power on demand less headaches!!!!
Old Jan 9, 2012 | 07:34 AM
  #582
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Thumbs up
I agree! Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jan 9, 2012 | 08:24 AM
  #583
TermnEatr's Avatar
Who is running the SDCE setup I may look into selling mine to get the aster bracket but wanted some opinions on the SDCE I have yet to use it.
Old Jan 9, 2012 | 08:25 AM
  #584
lmt0705's Avatar
i have access to a cnc lathe where I used to work, ill get in there and machine it out so it locks in
Old Jan 9, 2012 | 08:36 AM
  #585
LS1Tech Sponsor
KP got his '98 T/A into the 8's in the 1/4 with his SDCE bracket, he never had any problems with it that I know of. Bob
__________________
Old Jan 9, 2012 | 09:45 AM
  #586
xFLG KING PIN's Avatar
Thumbs up
Amen brother!!! +2
Old Jan 9, 2012 | 10:11 AM
  #587
LS1RedZ's Avatar
Originally Posted by Bob@BruteSpeed
The first thing I would check for is belt slippage, do you have any black dust on the blower housing?
Next is the air filter clean? A dirty air filter can reduce boost by several psi.
If you still haven't found the problem I'd start checking for a boost leak, I'd check all the tubing to hose connections first, since you have made more boost in the past. It could also be a hole in the intercooler(s) or a faulty bypass valve.
It sounds like you don't have a boost gauge in the car, I'd install one so that you can troubleshoot your combination. You can even temporarily install a boost gauge out on the cowl by taping it to your windshield wiper, if you don't want a permanent installation. Bob
There might have been a tad of black dust on the s/c but not that much to worry about it slipping i wouldnt think, plus I have Asters bracket setup on the car.
I just cleaned the air filter before I dynoed it the day before.
Is there like a smoke test you can do or something like that to test for leaks?
I have a boost gauge in the car.
Old Jan 9, 2012 | 01:00 PM
  #588
The Alchemist's Avatar
UNDER PRESSURE MOD
Are you running a 2-3 bar map sensor? I'd confirm with the map sensor first exactly how much boost your are really seeing.
Old Jan 9, 2012 | 07:20 PM
  #589
lmt0705's Avatar
How much did power drop off
Old Jan 9, 2012 | 08:47 PM
  #590
mikep2002's Avatar
Best way to test is cap off the piping at the intake and at the supercharger. And for best results put air on the top side of the bypass valve to simulate boost holding it down (but if you feel really good about your bypass valve just remove it and cap it off). Then charge the piping with air pressure and listen. Worst case spray soapy water and look for something. Tiny leaks can be expected but hearing air coming out not acceptable.
Old Jan 10, 2012 | 09:09 AM
  #591
LS1Tech Sponsor
Thumbs up
I agree, this is the most fail safe was to check for boost leaks. Bob
__________________
Old Jan 10, 2012 | 10:01 AM
  #592
LS1RedZ's Avatar
I switched from a MAF tune to a 2 bar SD.
I'll have to try this to see if that is the reason.
Hell I should be seeing more than 11-12psi with a 3.4 pulley shouldnt I?
Old Jan 10, 2012 | 11:37 AM
  #593
383camaroz28's Avatar
Cant wait to have my engine built for my d1sc, made 525 at 10-12psi threw a shitty converter,
Old Jan 10, 2012 | 12:12 PM
  #594
UNDER PRESSURE MOD
The reason I asked about the map sensor was to check those values rather than a boost gauge.
I am seeing over 14psi of boost with a 4.0" pulley with a 7.65" crank pulley at 6800rpm. I'm running Performance Induction 215 heads (Mast), 227/235, 113 cam, FAST 90/90 intake, long tubes, ory pipe on a stock cube motor if that gives you a comparison. I'm running a FMIC with 3" charge pipe, truck inlet and the biggest filter Bob sells.
Old Jan 10, 2012 | 09:13 PM
  #595
LS1RedZ's Avatar
Yeah it was seeing like 11.7, and the power would drop off pretty bad past 5400 Rpms. The last dyno it was carrying power past that point.
Old Apr 3, 2012 | 01:20 AM
  #596
badinfluencelsx's Avatar
ive seen this thread everywhere but now that i need it, i cant find it!
what size intercooler are you using on a trans am d1sc fmic to keep the fog lamps? 31x12x4?
Old Apr 3, 2012 | 04:14 AM
  #597
LS1Tech Sponsor
Yes, the 31x12x4 intercooler can work with the fog lights. Bob
__________________
Old Apr 3, 2012 | 07:05 PM
  #598
mrdragster1970's Avatar
6 & 8 Second Club
Can I join the group??
I just bought a F3R for a BBC and would love to talk ProChargers!!!
I have A LOT to learn, and all I hear is you should have got turbo's??
Old Apr 3, 2012 | 07:10 PM
  #599
UNDER PRESSURE MOD
F3's are badass.
Old Apr 3, 2012 | 07:44 PM
  #600
6 & 8 Second Club
This is the system I bought. Just a blower, & alcohol injection, not his engine or truck!!
I'm putting it in my red car shown in my signature.
