Procharger guys
Old Dec 18, 2009 | 08:25 AM
  #101
Rickys S/C Z28's Avatar
come on guys keep this alive!!!
Old Dec 18, 2009 | 08:31 AM
  #102
http://www.youtube.com/watch?v=q0pIFpppQEc
http://www.youtube.com/watch?v=DtjaYnXSbHg
http://www.youtube.com/watch?v=6FNC4tNNiKg
I STILL DONT HAVE ANY VIDS OF THE 10.XX PASSES BUT ILL TRY TO GET SOME UP
Old Dec 18, 2009 | 09:53 AM
  #103
'Trust''s Avatar
Originally Posted by BriancWS6
Did you have some bracing welded into yours for it to survive then? What made you stick with the plenum over a front mount?
I had to get the whole bottom removed, then had a new plate installed, 1/4" thick aluminum, it held after that. I did this to the stock one just having a litte fun on the highway:
Old Dec 18, 2009 | 03:13 PM
  #104
dschmittie1's Avatar
Here is a video of my car going 10.404@134 in august.
http://www.youtube.com/watch?v=PCNuWL97FYY
Old Dec 18, 2009 | 03:18 PM
  #105
Mightymike2000ss's Avatar
From: Home town Clive,IA current town FORT BENNING GEORGIA
so what is the max boost you guys can get out the 4.5 twin intercoolers, im trying to keep it hidden
Old Dec 18, 2009 | 06:48 PM
  #106
Old Dec 18, 2009 | 07:11 PM
  #107
EPP's Avatar
EPP
We've done 16 psi in this 740 rwhp Corvette with methanol with the twin intercoolers, they're nearly identical to the f body intercoolers. http://www.exoticperformanceplus.com...Car.php?car=54 Bob
Old Dec 19, 2009 | 06:48 PM
  #108
BTLBABY's Avatar
Finnaly get to ***** mine out ProCharger FTMFW!!!!!
F1A, A2W, Built LS2:
Fabbing the aluminum tubing and inter cooler mounts
Some what a finished project.
-Coleman
Old Dec 19, 2009 | 08:29 PM
  #109
Taubr Unit's Avatar
now THAT is what im talkin bout!!
Old Dec 19, 2009 | 10:26 PM
  #110
TWS's Avatar
TWS
Horizontal front mount.
I'm starting to see a small trend.
Old Dec 19, 2009 | 10:29 PM
  #111
airforcemanss's Avatar
it seems a lot of people lately are going with a f1c rather than a f1a. whats the difference?
btw bob if your still in this thread, how much psi are you running on that graph you posted with your cts v?
Old Dec 19, 2009 | 11:28 PM
  #112
helicoil's Avatar
Default D1 Procharger
I am making 14# on a 403 LS2 with twin 4.5" intercoolers and a D1. The meth keeps the IAT's in line. They work well for what I am doing.
I have blown that aluminum plenum box up a few times. Last time I think I got it fixed. No troubles so far. I think I am in the Top 5 with making a FULL weight car with the twin 4.5"s and a D1 go single digits. Still got cold AC too!
Here is my plenum handy work 3rd time around.....
There is another gusset all the way along the bottom not visible where they like to split too.
Here is a video of a 9.80 pass. Nothing special, still got a 4L65E to boot! This car weighed in at 3810# across the scales at the shootout this year.
Old Dec 20, 2009 | 12:47 AM
  #113
Taubr Unit's Avatar
i have been wondering... i have a 7.65/4.0 pully combo, what kinda of boost numbers should i be looking for? stock short block with 224/230 in.567 ex.578 on a 114 LSA cam, stock 317 heads.
Old Dec 20, 2009 | 09:49 AM
  #114
BTLBABY's Avatar
Horizontal Air to Water
-Coleman
Old Dec 20, 2009 | 10:51 AM
  #115
Hey man are you foot braking the car?
Old Dec 23, 2009 | 05:14 PM
  #116
Taubr Unit's Avatar
heres a turbo car for example........
" bone stock shortblock with bone stock 317 heads, the only aftermarket parts being cam, valve springs, pushrods, and head studs. 3300 lb raceweight, s400-80mm turbo, Jgs 44mm wastegate, Tial 50mm bov, 4l80e transmission, 3.50 gear. Stock pcm, 2 walbros, 80lb injectors, #10 feed, and return. All done on $1.99 (e85) The car made 796 rwhp through the locked 4l80e on 15 psi...9.304 @146.59"
How fast do you think you can get that same car to go with a procharger? Do you think a procharger can hang with them times at all if set-up and everything maxed out?
Old Dec 23, 2009 | 05:44 PM
  #117
sixpack_2_go's Avatar
awsome thread!
Old Dec 23, 2009 | 05:51 PM
  #118
AFASTYZFR1's Avatar
Old:
Old Dec 23, 2009 | 05:58 PM
  #119
BTLBABY's Avatar
If you put a ProCharger of equivalent size, yes. One thing we must remember, the turbo will be able to spin way more RPMs then what the equivalent PC would. So the power poteitial for the turbo is a little higher.
There is no doubt that turbos make more power and can run faster, bit I like knowing that with my SDCE 8 rib ProCharger, I will have more trouble free miles, and NO LAG!! Plus I love the sound
-Coleman
Old Dec 23, 2009 | 06:07 PM
  #120
BTLBABY's Avatar
Originally Posted by AFASTYZFR1
Very Nice, Love that color!!
I see you went back with a LS6 intake, any particular reason?
-Coleman
