Procharger guys
" bone stock shortblock with bone stock 317 heads, the only aftermarket parts being cam, valve springs, pushrods, and head studs. 3300 lb raceweight, s400-80mm turbo, Jgs 44mm wastegate, Tial 50mm bov, 4l80e transmission, 3.50 gear. Stock pcm, 2 walbros, 80lb injectors, #10 feed, and return. All done on $1.99 (e85) The car made 796 rwhp through the locked 4l80e on 15 psi...9.304 @146.59"
How fast do you think you can get that same car to go with a procharger? Do you think a procharger can hang with them times at all if set-up and everything maxed out?
https://ls1tech.com/forums/drag-raci...rocharger.html
Glad to see you finally put that F1A to use.
Car should run high 8's.Yes, I leave at about 2000 RPM against the converter.
-Coleman
some more info/pics here:
https://ls1tech.com/forums/forced-in...1-c-build.html
