Procharger guys
Old Mar 15, 2010 | 05:41 AM
  #401
Taubr Unit's Avatar
i was thinkin about using the red-x as mine also, lol
Old Mar 17, 2010 | 07:29 AM
  #402
EPP's Avatar
EPP
Thumbs up
Originally Posted by Taubr Unit
heres my finished build pic, go to my build link in sig. to see more pics and mods i did...
It's looking good! Bob
Old Mar 17, 2010 | 11:20 AM
  #403
383camaroz28's Avatar
Do you have to sit the rad. Up stright? Or can it stay as is
Old Mar 19, 2010 | 02:54 PM
  #404
-Q-'s Avatar
-Q-
Once again, need a little help here guys...posted this in the Fueling and Injection forum and got no response...
I'm installing Siemens 60lb injectors, and there are two grooves on each injector for the little clip the holds the injector in the fuel rail to fit into. I put the clip on the first three or so injectors on the top groove before I realized I might be installing them wrong. Does the clip need to go in the top or bottom groove? Not even sure I can press the fuel rail down far enough to reach the bottom groove, but thought I'd ask before I screw something up.
Old Mar 19, 2010 | 06:55 PM
  #405
negativeswitches's Avatar
sorry for the big pic i dont know how to make it smaller
i made a thread and a couple people commented i try elsewhere, it's a procharger related question
I'm new to boost, i got a supercharger setup off my neighbors EFI 502 boat and it came with this procharger regulator FV006A2 and i e-mailed tech support at procharger and they were no help at all.
it's hard to see but there are two nipples on the unit, one on top and one just below the diaphragm. i need to know if i put both of these to intake vacuum, do i need a check valve on one? how does it work, I've never seen a secondary nipple on a FPR before.
any help would be appreciated.
thanks in advance,
link to the thread and pic is here
https://ls1tech.com/forums/forced-in...l#post13055026
Last edited by negativeswitches; Mar 19, 2010 at 06:57 PM. Reason: picture to big when linked from attachment
Old Mar 19, 2010 | 11:12 PM
  #406
BTLBABY's Avatar
It's probably some type of universal reg. The top one is for boost and the bottom for vacuum. Just my guess......
-Coleman
Old Mar 19, 2010 | 11:41 PM
  #407
-Coleman
well you cant have boost and vacuum at the same time, unless the t/b is closed and you have 2 sources and at that moment you wont be spraying fuel anyways...
-Erik
Old Mar 19, 2010 | 11:50 PM
  #408
BTLBABY's Avatar
Right, I was saying it could be used as either a boost reference out of the top port or as a N/A setup pulling vacuum out of the bottom port. If you are wanting to run both ports for some reason, you would want your one way check on the bottom one obviously.
-Coleman
Old Mar 20, 2010 | 05:09 PM
  #409
cant wait to piece mine together next month !
Old Mar 21, 2010 | 08:22 PM
  #410
badinfluencelsx's Avatar
ive been saying that for a couple months now! lmao
Old Mar 21, 2010 | 08:27 PM
  #411
im hopeing for 3-4 weeks to start it lol
Old Mar 21, 2010 | 11:46 PM
  #412
blue00ZZleeper's Avatar
I wish. I'm still waiting for all my parts. My 2" ARH headders a huge!! I'm gonna have to pull some tricks to make them fit lol. Their the 2" race headders. My heads still aren't here and all the other **** is taking forever!!!
Old Mar 22, 2010 | 11:03 AM
  #413
Im gonna try an piece a kit for 3000-3500 an try an fit a s60 in my 5k budget
Old Mar 29, 2010 | 06:44 PM
  #414
This kid i know his friend has a p1 for a lt1, he got bracks for a lt1 an hes gonna put it on his 1986 350 motor, question is would this work?
Old Mar 29, 2010 | 08:51 PM
  #415
dschmittie1's Avatar
Well I guess it is time to post up a little update on mine. Well I Finally got the car running and took it out for a quick spin tonight to make sure things are ok. Still needs tuned but that will be happening over the next week or 2. Here is a run down
The last 2 years the car was a forged 347. Stock crank, Callie's rods and -8.6cc dished Diamond Pistons. The Motor had stock heads, 224/232 .581/.595 115 lsa cam with stock ls6 intake, ALKY control, 1 7/8 Kooks and 4" mufflex exhaust. Car put down 676rwhp through a M6 and MWC fab 9 at about 14psi. Car went 10.33@136mph with clutch issues@ 3525lbs.
The new setup:
Same 347 short block 243 heads with sodium intake valves and 1.60 exhaust valves that I ported. 235/251 .621/.624 115Lsa Comp LSR blower cam, Victor JR and Swapped to a TH400. Pulley combo is the same as before 7.25/3.7 as last year but I have a 3.4 waiting to get installed. once I see what it does like this.
Cage gets Certified this Saturday so I should be hitting the track in about 3 weeks to shale this thing down. I can't wait. Here is a start up and idle video from tonight
http://www.youtube.com/watch?v=uNMDdJGLsaQ
Old Mar 29, 2010 | 09:13 PM
  #416
tripblackls1's Avatar
^^^^^ nice ^^^^^^
question is anybody on this forum have a cog drive setup
i know epp has made a kit but i haven't seen any pics or videos of a fbody with a cog setup
eventually in the next few months i plan on running a cog f1c on my camaro
so any pics or video would be awesome
Old Mar 30, 2010 | 04:58 PM
  #417
Anyone know?
Also can i use a lt1 p1 on a ls1?
Old Apr 2, 2010 | 05:27 PM
  #418
NemeSS's Avatar
any frontal pics of the ls1 fbod 8rib upgrade crank pulley being installed
Old Apr 2, 2010 | 06:33 PM
  #419
Taubr Unit's Avatar
what do you mean? I have 8-rib belt on mine but not sure what ure looking for. If u want pics of it being installed its just 3 bolts on front of the ballancer
Old Apr 2, 2010 | 07:53 PM
  #420
Well good news here. I finally, after 2 months have recieved my Patriot Stage 3 LS6 heads!!
