AES 390ci - Now with Callies Dragonslayer crankshaft
Old 06-21-2011, 10:01 PM
  #241
ProVK's Avatar
At what power level on the LSX/ERL blocks with 6 bolt heads are larger head studs required?
Old 07-06-2011, 02:17 PM
  #242
T-FATTY's Avatar
Hello Fraser,
Could i send you my LS2 aluminum block in for your 385 short block, what would be the price with my block?
What would the compression be with stock cc LS3 heads? I would like 10:5 comp. and could mill the heads but would like to keep as much meat on the heads as possible.
Thanks, Todd.
Old 07-07-2011, 12:22 AM
  #243
AES Racing's Avatar
Originally Posted by T-FATTY
Hello Fraser,
Thanks, Todd.
$3245.00 + shipping
add: Surface block, $150 (recommended with used block)
To make 10.5:1 compression, need to mill heads .030" (64cc) and use factory MLS .053" thickness gasket.
let me know if you have any other questions?
Old 07-07-2011, 01:31 PM
  #244
AES Racing's Avatar
LSX block, from what i've seen
MLS gaskets with 1/2" head studs (6bolt) 1800hp, gaskets leaked. Speaking from 3 similar builds.
Up to 1300hp area good time for upgrade to 1/2" head studs.
Over 1500hp i'd consider using copper head gaskets/O ring
Old 07-22-2011, 08:51 PM
  #245
eyecell007's Avatar
PM sent - very interested in the 390
Old 08-14-2011, 02:36 AM
  #246
99bluefirebird's Avatar
I know several weeks ago he was out of the 3.8" C series cranks, only the drgonslayer were available. Did you ever receive more of the cranks Frasier? And is the 398" LS3 available yet?
Thanks
Old 08-14-2011, 02:46 AM
  #247
4bangermustang's Avatar
Thanks
Callies discontinued their C-series crank I believe.
Old 08-14-2011, 11:25 PM
  #248
So what is the plan for newer built 390 engines? Only the dragonslayer option or will you be going with another company? If so could you post up the updated pricing?
Old 08-20-2011, 03:42 PM
  #249
djjonesivs's Avatar
Running around 11.5 cr
On a ls2 Gto with 62cc heads
What would the heads needed to be milled to
Maitain that cr with the ls3 or ls2 short block
Old 08-23-2011, 12:42 PM
  #250
02blackbeauty19's Avatar
Hey Fraser,
I may be in the market for a new shortblock and I like the idea of the ci somewhere close to 385-390 using my twin turbos (twin 60's that flow ~70 lb/min.). A little more detail on the car: 2002 Corvette, 6-speed, will probably use a "budget" type head, but thats still in question.
I like this shortblock:
New 390ci = $4550
6.0 Block
Callies Compstar H-beam rods
Callies Dragonslayer 3.800" crank
ARP main studs
Would this setup support somewhere in the neighborhood of 1,000rwhp reliably? If not, what other specifics would you recommend? O-ring? 1/2" head studs? Also, if I supplied an LS2 block, what would the price look like vs you supplying it? Same with a iron 6.0.
Old 08-25-2011, 01:43 PM
  #251
Bueller??
Old 09-19-2011, 07:07 PM
  #252
madmax4499's Avatar
Ready for tuning!
Old 09-20-2011, 05:57 AM
  #253
djfury05's Avatar
Originally Posted by 02blackbeauty19
Hey Fraser,
New 390ci = $4550
6.0 Block
ARP main studs
If it were me and wanting 1000rw reliably I'd plan to do both the o-ring and 1/2" head studs... TFS 220cc as cast are a good budget head also.
Old 09-20-2011, 08:25 AM
  #254
I probably won't do either of them.
I've had shops that build/tune many 1,000rwhp cars and they said neither were necessary with a cylinder head with a thick (3/4") deck and good ARP studs.
Old 09-20-2011, 11:37 AM
  #255
djfury05's Avatar
that's fine I was just saying if it were me.. I figure 1/2" head studs are cheaper than a 6 bolt coversion.. good luck to you!
Old 09-28-2011, 08:16 PM
  #256
Old 09-28-2011, 08:37 PM
  #257
AES Racing's Avatar
We have a few C-Series Cranks left
Have another 4 390 engines going together this week.
Expect a special to come out soon for a limited few 390 engines.
Old 09-30-2011, 11:45 AM
  #258
LM1 Clive's Avatar
Very interesting thread. I'm in the process of selling my unused LS7 once sold i want to build a twin turbo LS3 motor. Didn't want to over stroke the motor to much and liked your early reply about the strenght of the pistons being better with the 3.8 stroke crank... I have a very light car (Even with a turbo'ed motor will be under 2400lbs) and therefore need it to rev very quickly to take advantage of the power. Can you build a complete bottom end as in recomended cam shaft and timiing gears ect ?? I do like the Mast heads but is there an alterative heads thats say alittle cheaper maybe under $1700 ??
Looking for 800-850 bhp at the flywheel.....
Ps will be using the Daily Dry Sump system as the engine needs to be very low in the car, I take it a Dry sump would also be better for a Turbo motor with a multi stage scavenge system Yes ???
Old 10-05-2011, 10:43 AM
  #259
LM1 Clive's Avatar
So if I dont want any more than say 1000bhp then which turbos would you fit to this LS3 399 Combo package ????
Old 10-15-2011, 10:34 PM
  #260
Verse1's Avatar
Hi Fraser, what sort of coin would it take to get one of these bad boys over to Aus?
Quick Reply: AES 390ci - Now with Callies Dragonslayer crankshaft
