F1A-390ci-E85
Update of the day. Got the trans strapped onto the jack. The block is tapped and the Aster Bracket is on. Just collecting **** and sorting through all the hardware. Going to haul the motor to the car and get truly started within a week.
Got my MWC CM A-Arms. Lowers only. No need for uppers as far as what I have read and what I have been told. I think it should save around 20lbs off the front, and the VFN hood will be another 20ish. so theres another 40 gone soon.
Awesome. However I have first dibs on the F1A
your right. i dont know what the hell is going on. apparently i need to do something to the shocks and something is wrong i dont know. all i know is its not right. eric told me something about a T bar or something. i dont know.
Per MWC email:
"Those are 2 piece lowers. The long skinny rod attaches to the main arm(with the ball joint). Connect the two by inserting the slot clevis(opposite the heim jointed end) onto the 1/4" thick tab near the ball joint. They are correct for what you need, see the attached pic and the process is basically the same."
Also, the shop is cleaned up, and we got this thing ready to rock and roll. Ill keep updates rolling regularly again here really soon. I want to take the update out of my thread name but it will not let me. Someone fetch admin to take it off.
Alot done in the past few days. 9-10pm on work nights. My buddy from StreetCarr Fabrications Donnie Carr has been a real big help lending me his fab skills for boxing in the upper radiator support. He measured twice and cut once to say the least. Focusing on making it look factory. Also we dropped the K member out, I am going to clean up the steering rack with some gunk and a wire brush. Also that heavy *** transmission is strapped down and up in the air. I started mocking up the MWC K member and it fit like a glove. We got the 2 piece lowers installed as well. Once the alignment is done ill tack the washers into place. Mike @ Vengeance Racing has the PCM and is putting a startup motor tune on it. The motor arrives saturday. AES is going to need to send me the correct valley cover. Other than that all went smooth. Even the BMR crossmember is fitting really well. Got the clamps on the fuel lines and ran them and removed the old hard lines. Also bought a 98-99 Throttle body cable so I can do ahead and pull the traction control and cruise out to clean up the engine bay even more. I got my Yofab power steering covers in, and the Wazee billet pulley arrives tomorrow. Julio at alkycontrol hooked me up with a second 15gph nozzle and recommends the level 7 setting. We should have the radiator support completely boxed and painted tomorrow and get some supports for it and some rubber pieces to keep it from rubbing. Progress, how sweet it is.
Side note, I would cover any glass(windshield) when cutting, grinding or welding anywhere near it. Those little sparks will embed in the glass and mess it up quick.
