F1A-390ci-E85
It was a joke. I was just throwing out a little bit of sarcasm... relax.
http://www.streetfire.net/video/8-second-ls1-procharger-11102007_710762.htm
after watching something like this i figure why even go through the trouble of putting something as involved as an s480 in when i already have the potential to do this. It does not matter to me how i get there as long as I can get there and stay there.
the transmission is in!
the driveshaft is back in!
getting packed up to go to LS fest, so i wont be able to fire it up this weekend, but next week i see no reason why i wont be putting some E85 in it and firing it up.
were just doing a few finishing touches like radiator hoses and finding out the best place for the regulator.
the converter refuses to go into the ******* trans. it goes in pretty far then stops and is hard to turn, i keep waiting for the second click, but it never happens. i put a 60e in a 2000 the other day and it went in so easy it was ridiculous. i have talked with Jake and Chris and they say the 80e converters do not change from the old style 80 to the new. so i guess im going to go mess with it some more.
I plan on having a fireup video next week.
I called Chris. He said since they use brand new parts they are sometimes very tight fitting. We busted out a grinder and smoothed some things and put on some grease, line the dogs up and twisted and pushed for 45 minutes. We ended up lining it up as near to perfect as we could and put a piece of wood on the nose of the front plate, and gave it a couple of light smacks with the hammer and it popped right in, and spun like it was a bicycle wheel. Its mounted to the crossmember, and all we need now is the starter to be put on. I just got my flex hoses on the radiator, and were mocking up the new texas speed exhaust and cutout. Sux having to take this thing up and down but at least we have a lift and a jack. I did a 60e on the ground the other night and it was definitely a pain.
. I plan on picking up 15 gallons of E85 tomorrow. ok
Got Half the blower piping on.
Got half the exhaust on, but I am swapping the U bolt clamps to the band clamp style like you see on the headers for a better fit, finish. It fits really well. Waiting to take my new Dual QTP low profile cutouts to be tig welded on here soon after this thing fires up.
Those god forsaken nuts, that almost drove me nuts.
driveshaft, Forged Yolk, 80e U joint, and new DS straps are on
80e is in. BMR crossmember fit like a glove, although I think they could make it lighter with little effort. Thought We'd come up with a new idea on mounting the shifter cable linkage , but apparently everyone puts it there that does the 80 swap. It's just about the only place i think you could get it. had to oval the holes a little but it works great.
Trans cooler location is behind the intercooler and in front of the radiator, and the air splitter should divert even more air flow than the fan will provide.
working on swapping all the band clamps over to T bolts. also going to have to modify the lower portion of the rad support to clear the inlet hat. not much though. just a notch.
had to bevel the edges of the converter to pass the dog ears. Circle D apparently uses all new machined parts that dont fit initially. A little smack on the *** and it popped right in. Got the SFI flexplate on and , there you go.
You know when I start pouring oil in this MF that shiz about to get seruss. You can also see the flexible ribbed black hoses I am using for the double pass radiator. They are 1.25 and 1.5 inch hoses both about 18 inches.
you can see the Y block here being used to split the feed to the back of the rails. Even distribution. Got talked into it.
as it sits now. waiting for me to find out how to get the starter to work.
