WS6 S475 official build thread.......
Old Aug 7, 2013 | 05:25 PM
  #421
mrstepheneades's Avatar
Originally Posted by Preston99WS6
I wasn't racing it every weekend. LOL. Yes it was factory no girdle extra bracing or anything special. It didn't catastrophically fail either. Rear lasted a good bit as I DD'd the car at 640 RWHP for a couple years putting the slicks on with a 76mm STS kit, then swapped to the front mount.
Time line went like this. Stock up to 50K miles,
heads/cam/exhuast 430 RWHP from 50K to 77K motor blew up.
Went FI with STS kit 77K to 98K with the stock rear staying together.
(Wish I would have listened to David MIGHTYMOUSE when he told me it was a bad idea LOL, This was when MM2 got into the wall. Nothing but problems with that kit, required weekly maintenance to keep it going. Oil problems, turbo dragging, catback twisting and breaking, boost leaks, just no good. David was right)
98K swapped to S60/ S480 front mount setup. Stock rear was a trooper for me.
Maybe I'll have luck like you lol.
Old Aug 7, 2013 | 05:53 PM
  #422
Preston99WS6's Avatar
Seen them go both ways, some take a beating some break the first time you dump the clutch on sticky tires. I always thought mine was going to go but it took the abuse like a champ.
Old Aug 7, 2013 | 07:17 PM
  #423
Do you have any video of just your car runs.
Old Aug 7, 2013 | 07:46 PM
  #424
Nothing really posted on youtube.
Old Aug 7, 2013 | 08:19 PM
  #425
Well post some lol lol.
Old Aug 7, 2013 | 09:05 PM
  #426
Ill get to it, most of what I have now is after the auto swap was done to watch how the suspension was re-acting so their not great quality. I put some up though.
Old Aug 8, 2013 | 07:13 AM
  #427
Did you launch off 2step? What rpm?
Old Aug 8, 2013 | 09:20 AM
  #428
4500 RPM with the T56, 3500 RPM on the footbrake, and 5000 RPM on the trans brake.
Old Aug 8, 2013 | 11:02 AM
  #429
Thanks for the info. When I get some wheels and tires and a 2step I'll try my luck.
Old Sep 16, 2013 | 09:20 AM
  #430
Will be at Ticks customer appreciation day dynoing at 16-17 psi.
Here is mine on ground and Collins on lift behind. Nice picture I thought.
Old Oct 5, 2013 | 06:06 PM
  #431
Sales@Tick's Avatar
A little birdy told me this car made 755/655 today shutting it down at 6000rpm on Tick Performance's dyno.
I was also told that pull was good for the King of the Dyno Shootout win and $500+ cash!!!
Congratulations Stephen!
Now we just need to get you a 9", a built trans and some low 6 second passes on slicks.
Old Oct 5, 2013 | 06:20 PM
  #432
Ford_Assassin's Avatar
Talking
Sick!! How much boost?
I will be happy with 600 to the wheels with mine....
Old Oct 5, 2013 | 06:41 PM
  #433
Rise of the Phoenix's Avatar
Those are some very stout number. I bet it's fun as hell to drive.
Old Oct 5, 2013 | 06:59 PM
  #434
Birdy was right Martin lol lol.
Little less than 18 psi I believe. Dyno doesn't load like the street. Was set for 18 psi on street pull. Probably only made 16 or so on Dyno. Jonathan said he wasnt sure he was just watching my wideband. Lol. I'm happy either way. Very happy.
Old Oct 5, 2013 | 10:10 PM
  #435
Sales@Tick's Avatar
The level of anguish in your voice when the 555/550 popped up due to the tach lead losing signal@4800rpm is so depressing. Then the sheer joy in your voice when I clicked drum speed and I shouted out "755 baby" is pure awesome. LOL!
Old Oct 5, 2013 | 10:40 PM
  #436
T/ALT1's Avatar
Most people break the stock rear after changing to lower gears like 4.10's etc.. My factory rear with 3.42 m6 gears went 10.17@134mph before I decided it needed to be upgraded because it was whining and I wasn't spending anymore money on it. I also raced it for a couple years like that running mid 11's on motor and mid to low. 10's on n20 but this was with an auto that is more forgiving. Good luck
Old Oct 5, 2013 | 10:43 PM
  #437
Sales@Tick's Avatar
I would never do that with a 6 speed lol.
Old Oct 6, 2013 | 02:57 AM
  #438
big reg's Avatar
Is your meth tuned in or do you spray it for safety? Nice numbers man.
Old Oct 6, 2013 | 06:49 AM
  #439
MUSTANGBRKR02's Avatar
Congrats on the numbers.
Old Oct 6, 2013 | 07:21 AM
  #440
armyboyatc's Avatar
This thread needs a "Like" button.
