Projected horsepower
currently
#1 iac kick
#2 ac shut off
#3 flex fuel
#4 second fuel pump
#5 trans cooler
#6 2 step
#7 spare
#8 spare
I want to be able to run boost off the holley so i know i need 2 outputs for the mac valves and 1 input for dome pressure sensor and i also have the transbrake now in which i need and input for the transbrake and an input for the bump and also a pwm negative out for the SSR holley solenoid 2 step wire will be re used as 1 of these. I was thinking of pulling the ac stuff off the because i can turn the ac off by hand so that no big deal and was also thinking of just running both pumps constantly and that should give me the 6 inputs/outputs I need. What do you guys think??
currently
#1 iac kick
#2 ac shut off
#3 flex fuel
#4 second fuel pump
#5 trans cooler
#6 2 step
#7 spare
#8 spare
1. IAC kick
2. Dome pressure
3. Ethanol sensor
4. 2-step
Outputs
1. Engine fan?
2. Second fuel pump
3. Boost +
4. Boost -
You can probably run the transmission fan with the key on. There AC Shutdown is also an output and you do not have space. The I/O expansion module is an option and you can offload non critical inputs and outputs to it.
Andrew
1. IAC kick
2. Dome pressure
3. Ethanol sensor
4. 2-step
Outputs
1. Engine fan?
2. Second fuel pump
3. Boost +
4. Boost -
Andrew
*inputs
iac kick
flex fuel sensor
2 step
*outputs
ac Shutdown
2nd fuel pump
Trans cooler
What im wanting to do is add a second mac valve with dome pressure sensor controlled by holley and Viair air compressor. Im also wanting to wire in the transbrake and bump switch with the SSR holley nitrous solenoid driver.
*inputs
iac kick
flex fuel sensor
2 step
*outputs
ac Shutdown
2nd fuel pump
Trans cooler
Andrew
-holley edi can input/output module
-holley communication cable
-holley can splitter
-mac valve
-dome pressure sensor
-pressure sensor cable
-push lock union for mac valves
-viair (10000) ultra light air system
-air compressor regulator
-second button for my bump
I put a metal bracket around the steering wheel and put the transbrake button like that and it worked out ok. I think I'll put the bump on the dash. I thought it through and I don't want 2 cords on the steering wheel.
-mac valve
Andrew
Any I/Os that are created in the I/O ICF can be configured to be wired to the expansion module.
The reason that you don't want critical I/Os to be on the expansion module is their signal come over the CAN network, which has some latency. It's a data network, like Ethernet, and send packets of data instead of electrical signals.
Andrew
Andrew
Andrew
Follow that link. Scroll down and you will see links to two different PDF documents. I suggest that you download them, read every word, twice, then proceed accordingly.
If you have questions, post them.
Andrew
Andrew
