STS install pics... and stuff...
but I have implemented pretty much a dump and turn down off of the turbo. Will post a picture by sunday
Connecting long paths to the wastegate, as long as they don't restrict it any is fine, but once a restriction happens you get less control of your WG and pressures
Verdict: AWESOME!!! One thing I hated about my rear mount was that after shutting it off and say walking into a store, the turbo would cool and I hated the way the car would run after starting it up and driving it off again till I got some heat built up again. That issue is all most gone all together. Spool time difference was NOTICEABLE. Hits a lot harder now as well. It might sound over kill maybe using this stuff where the exhaust flanges line up may hold more heat in lol!
Id recommend one to all the guys running rear mounts, or just have it coated, this however was way easy to do.
I will eventually have my tips back on, haven't quite had the time to do so. All it will take is a few hours of welding, sanding, painting and cleaning and its all done.
Then my new front bird
This is all thanks to my dad as he ordered a new front bird and did all the cutting and painting....we won't even go into how many hours were put into it.
AND
By the way, the Turbowerx Exa-Pump that I purchased is WAAAAAAAY quieter then the STS pump.
You know how you replace your fuel pump with say the Racetronix kit (255) , and you can then hear the hum of it.... WELL, the exa pump is just ever so slightly louder than it.
Also, whoever will be in Charlotte, NC this upcoming weekend and knows about the Food Lion Autofair April 4th and 5th, I will be showing with Triad Fbody. Saturday we are under the grand stands I believe, and Sunday we are down in the grass on Pit road area.
I think I'm going to dyno towards the end of this April or beginning of May. There is a Dyno Day May 2nd at Pro Dyno, we can talk and maybe meet there and see what is going on, I may have some other friends also going to it.
