STS install pics... and stuff...
Ok, for an oil FEED restrictor... I'm running a 1/4 inch feed line to the turbo, and the drain line is a 3/8 inch return connected directly to the Turbowerx Exa Pump scavenge pump, capable of 3 GPM and it then returns to the oil pan. I'm running the factory new ls6 oil pump which runs ~45-60psi I believe.
Word is NO RESTRICTOR necessary. Even on my ball bearing
We will test this and see, I do however believe that we will be fine without.
It should be in my sig... TC76mm from Turbonetics, 0.81.
Also figured I would throw this in the mix....
Startup
Needs some more magic flashes but its almost there
She is back from the grave:
damn it is a blast to drive. And let me tell you, the TC76 makes some noise!!! i love it
god the turbo sounds like a freaking jet engine throttling up.
running NO restrictor w/turbowerx exa-pump and 3/8 return line, no problems whatsoever. good straight return path also.
BIRD SHOT
Where in the hell are all of you that said you wanted to copy my front cutout?? I said you could copy me BUT YOU HAD TO POST PICTURES!!! WTF!!!
Hehehehehe, its stock
