thermostat thought
thermostat thought
I was just cruising the internet like normal looking at parts. I have seen the 160* stat multiple times but ive never thought about it. after a few minutes of thinking i have come to the conclusion it is a waste of money. correct me if i wrong but the only thing that it would do is make it take longer to warm up to operating temp. i dont see how it would help the engine run cooler during operation. i see that it will be cooler for all of the 10 min max that it would take for the engine to warm up but it doesn't lower the operating temp at all?
right or wrong?
right or wrong?
LS1Tech Administrator
Received 1,686 Likes
The thermostat only regulates minimum temperature, post warm-up. Max temp will be determined by several factors, including fan settings, cooling system condition and capacity, engine operating parameters, and outside air temp.
Personally, I would not want a 160 stat in an NA LS1. Coolant temps in the 190-205° range seem to produce ideal results.
Only time that the engine would run cooler without changing the fan settings would be at steady cruise for extended periods.
if your racing it will help consistancey and prevent hot spots in the engine by flowing the coolant sooner and more often. you want it open but you don't want full temp durin the run and you don't want the fans goin on and off durin it either. also at highway speed it should stay cooler and not use the fans.
1 Post
Well I look at this, the ls1 was designed to run good in all conditions ranging from the extremely cold(northern winters) to extremely hott(southern summers) everyone I see that says not to put in a 160 stat seems to live in the northern states. What about the people down here in the south where temps see 105+ on a daily basis?
It's better to keep the stock temp thermostat in the motor. The engine suppose to operate optimal in a certain temp range, the stock thermostat and fan settings work to keep the engine in that range. Therefor changing the thermostat and fan settings will more then likely lower engine performance and/or efficiency. If anyone is worried about the motor getting too hot, like during racing for example or diving in a climate with very hot weather, then the better thing to do is get a more efficient (bigger) radiator.
I currently run a 160, I have no complaints what so ever. Although, OP I wouldn't recommend it for what your wanting it for.
