Time for more power
Old Jul 19, 2019 | 09:23 AM
  #221
AINT SKEERED's Avatar
Originally Posted by LaBLKv6Z
Yeah, I'm also running the ram air box.
If I am not happy with the temps after water pump change, I'll pull the slp ram air and see if its causing it. If it is, I'll get the chris1313 pro stock.
Old Jul 26, 2019 | 10:53 AM
  #222
The Transmission and converter will be here today, hope to get time tonight to put it in, maybe tomorrow.
I am wanting to have the transom working properly before attacking the water pump and vacuum pump install. I want to drive a while tuning drivability then will take it to the dyno. Hopefully before September 1
Old Jul 27, 2019 | 06:04 PM
  #223
Transmission is in and working as it should . Converter drives good but looser cruising than the PTC did.
Cruising temp on transmission is around 175 , goes up to 180 when I get in it hard but cools back down.
Engine coolant temp is running on the hot side. Idles at 185 until I go drive ,then goes 201. After a while its creeping up to 215 at 60 mph and 225 at 70 after a 5 mile at 70 pace.
I have to install the electric water pump them then I'll work with getting temp right if that dont fix it. Maybe a big aluminum radiator is next.
Old Jul 27, 2019 | 06:47 PM
  #224
Kfxguy's Avatar
I had the same issue. I brought temps down by:
1) flushed the system.
2) less than 50/50 mix
3) water wetter
4) 180 thermostat
Those changes were worth about 7-10 degrees
Then I changed out my trans cooler to a better one. That helped a lot with the creeping temps at cruising speeds. Then I was having problems still with temps creeping up in stop and go and low speeds. The convertor slippage was the culprit I suspect. I put a 7” fan on my trans cooler and that stopped that and my temps don’t creep anymore. I started out at a max of creeping to 217 and now I may see 205 on extreme situations but normally 190-200. I have a dual row aluminum radiator to go in it now because I’d rather have it around 180-190 if I can.
Old Jul 27, 2019 | 10:11 PM
  #225
3) water wetter
4) 180 thermostat
I have an electric water pump to install and looking at bigger radiator too.
I have 2 bottles of water wetter to put in when I do water pump as well. For now I changed the stoich in my tune to 14.12 as commanded air fuel for cruising and that helped a lot. E10 gas should be set there anyway so I figured I'd see what it done. It cruised after at 198 and got up to 207 on a hard pass so its helped.
Old Jul 30, 2019 | 09:52 AM
  #226
I have it cruising at 201 for now. I was able to make some good hits on it, this fti converter is a bad bitch 😁. Flashed to 5300, and in top of 2nd gear it has 5.5% slip .
It falls about 1200 to 1400 on the 2-3 shift from what I've seen so far but I guess to make it drive good non lock up, it has to.
Which is fine ,it will hold a 100 shot if that's all its falling
Old Aug 3, 2019 | 03:23 PM
  #227
JakeFusion's Avatar
Super Hulk Smash
Mmmm FTI.
Old Aug 3, 2019 | 04:58 PM
  #228
Kfxguy's Avatar
Originally Posted by JakeFusion
Mmmm FTI.
Is fti better than yank?
Old Aug 3, 2019 | 06:28 PM
  #229
I've never used yank. But this fti is ****
Old Aug 3, 2019 | 06:29 PM
  #230
Mmmm FTI.
Flashing 5300 as of logs in 2nd gear hit from a roll. 5.5% slip at wot in 2nd gear at 7200 rpm
Old Aug 3, 2019 | 06:36 PM
  #231
Kfxguy's Avatar
How do you know how much slip?
Old Aug 3, 2019 | 07:02 PM
  #232
It was 7230 (if I remember correctly) @ 92 mph
Locked up figures would be 4.10 gear x 92mph x336 = 126,739 x1.48 (2nd gear ratio in tra s)= 187,574.
÷ that by tire hieght 27.4" and locked up would have been 6846 rpm.
Add that plus 5.5% to get 7230
Old Aug 3, 2019 | 08:48 PM
  #233
Ive always wondered how convertor slip is measured. Autos are not my skill set. Thanks for this.
Old Aug 3, 2019 | 09:14 PM
  #234
This 8" is more efficient than the 9.5" I had
Old Aug 3, 2019 | 10:38 PM
  #235
JakeFusion's Avatar
Super Hulk Smash
5.5% is good.
My CircleD is about 5%.
Yank is somewhere around 12-15% most of the time. That's eating a ton of power.
The FTI sitting here is a triple disk. So I can lockup at WOT. 0% slip.
Old Aug 3, 2019 | 10:45 PM
  #236
5.5% is good.
I've never owned a yank. 2nd fti and both perfect
Old Aug 7, 2019 | 03:07 PM
  #237
Water pump and new radiator in. Still have to wire up the pump and fill with fluid and also change an ac line. Broke it trying to get the condenser lined up with radiator and lost all the oil and freon.
Had to leave to come to the nursing home with wife for her mother, hopefully get it finished this evening then change ac line.
Slow process But im getting there
Old Aug 8, 2019 | 10:00 PM
  #238
Not sure why but it's still getting up to 219.degrees. I've bleed the system several times today, water pump works great but still not cooling.
I drilled and tapped the front and back of the heads and run 4an lines from rear,tie in to front then to the radiator
Has a nice stream from steam ports to radiator, might move those into 2 separate lines returning into upper radiator hose instead. Back 2 y into a single 6an into the hose and front 2 doing same thing.
Not sure what else to try
Old Aug 9, 2019 | 01:09 PM
  #239
LaBLKv6Z's Avatar
Are your fans are pulling strong? That's 219 while moving or just idling?
Old Aug 9, 2019 | 01:49 PM
  #240
At 70 mph. I jacked the front up today and brought it up to temperature. Used my mighty vac brake bleeder to pull a vacuum and got a good bit of air. After doing so, I shoot a ir gun and get same temp on both heads and the water pump.
About to leave for the weekend, all drive monday and see if it helps
