3.75" Stroke Crank?
You can offset grind a stocker to 3.70" easy with a 2.00" Rod Journal, other than that I would guess Callies or maybe Scat would be willing to grind you a forging to size.
Bret
Chuntington what I got going in my head is to basically build a 400ci with a good rod ratio 4.125" bore 3.75" stroke and a 6.2" or maybe even a 6.3" rod. I'd either use a LS7 or a L92 top end of course have it all worked over especially if I use the L92.
I kinda got a soft spot for the 400 ci number but I don't like the small bore ones that are out there (well actually I'm hung up on the 4.125" bore) you see I had an OLD ('72) 4 bolt 400ci SBC for years that I was gonna build and put into something but I got distracted by the LS1's and sold it well now I want to put a 400 in the X. It's gonna be a DD and I want to keep it to where I feel it's gonna be durable ie. why I'm concerned about the rod ratio.
Really I'm just kicking the idea around.
You may not be aware of this, but the 400SBC had the "worst" rod ratio of any conventional American V-8 with a rod/stroke ratio of 1.484.
Coming in close tying for second place is BBC 454 and 502's at 1.533.
None of these engines had any real issues that would keep anyone from building them.Many, many moons ago performance engines used production heads, which we all know they were horrible flowing (especially by today's standards).
Long rod ratios (aka "good rod ratios") helped these heads flow more air to make more power. Nowadays, even production heads flow good, and thus the need to enhance flow from long rods is negated. Long rods only help today when you can shave excessive piston weight, beyond that, don't bother.... there's not enough to potentially gain to waste one's time.As git_sum has said, don't worry bout r/r. I put in the stroke I *need*, make the compression height on the piston what I *need*, and fit a rod between the two, and not let the rod ratio bother me.
I've attached a rod ratio chart, it's kinda interesting how the r/r's are all over the map.
Update: I said screw it, I can sleep later and fixed the chart to include 4.8L thru 7.0L LS engines.
But all in all I wonder if I really need a 427ci maybe a warmed over LS2 is enough it's just gonna be a DD. I'll get crazy on the next motor.....
Shirl Dickey
SD Racing Enterprises
That paired up with a stock crank would put you right at a 401, plus with the bigger bore you can open up the heads more.
Shirl Dickey
Nate
