Operating Temps
Old May 3, 2020 | 02:31 PM
Shownomercy's Avatar
Man-Crush Warning
Default Operating Temps
Its been a long time since I have regularly driven my car so I forget what "normal" is temp wise.
EWP, 160* thermostat, bled coolant system, 80* OAT and cruising at ~70mph puts the temperature from waterpump at 195-200.
Is that normal? At idle it cools right back down.
Old May 3, 2020 | 04:30 PM
SS RRR's Avatar
Village Troll
I think that may be around normal. Aren’t you running more than stock CID? That’s about where mine is on the freeway. How many GPM on the w/p? Imma ‘bout to do the HD Meziere to see what happens.
Isn’t this also a rebuilt engine?
Old May 3, 2020 | 05:55 PM
Man-Crush Warning
383ci, motor has been running 5-6 years now since its broke the oil pump drive.
55gpm HD meizere pump
Old May 4, 2020 | 01:54 PM
moehorsepower's Avatar
That's about normal, usually your operating temps will be around 20* above the thermostat rating, like a 160 will usually run at 180, add in the extra cubes, that's ok.
Old May 6, 2020 | 10:33 AM
Man-Crush Warning
To add to this, any one want to share what the cruising timing is set for? 2000rpm, 70mph area
Old May 6, 2020 | 09:19 PM
Supercharged111's Avatar
ALL my motors run the thermostat temperature unless they're really getting beat on hard. Even then, they usually don't go up much if at all. The stock radiator shroud on these cars is a joke. That and being bottom feeders they get a lot of crap lodged into the AC and radiator. I'd blast those clean and think really hard about a better shroud. I had to make my own.
Old May 7, 2020 | 09:00 AM
Germansheperd1's Avatar
When I replaced my water pump last fall I flushed the block 4 times through the WP holes (took opti off), I flushed the radiator 4 times through the cap and hoses, I flushed and back flushed the heater core 4 times as well. I was amazed on how much crap came out of the entire system the first couple of flushes. Along with the new water pump I installed a new OE AC Delco thermostat 131100 and a new AC Delco cap RC94 with a 50/50 mix of green antifreeze.
In just about any drive condition the car runs at approx 192*. It may run 190* at times, it may get up to 195*.
As stated above make sure there is no debris in front of the radiator or condenser. Maybe I’m lucky but after I did those things I just dont see the cooling nightmares people claim about an LT1. My cooling system is spot on perfect.
Old May 7, 2020 | 09:39 AM
Man-Crush Warning
I plan on dumping the mystery mix of coolant and flushing it, perhaps this weekend. Then refill with a 75 water/ 25 coolant ratio.
I have a large intercooler blocking the radiator, if that counts as debris.
Old May 7, 2020 | 10:36 AM
SS RRR's Avatar
Village Troll
warsh out those radiator/intercooler fins, brah!
Old May 9, 2020 | 03:00 PM
What kind of shroud do you have? Anything at all?
Old May 10, 2020 | 07:38 AM
Man-Crush Warning
I fabbed up some cardboard to seal the area around the hood latch and then the sides of radiator into engine bay.
Old May 11, 2020 | 09:06 PM
SRZ's Avatar
SRZ
What are you fan settings? I run 210 with a 160 stat but I think the fan settings are wrong. I've got a big IC up front too.
Old May 11, 2020 | 09:24 PM
Got pics? If it's sealed well you may be limited by the size of the bottom breather opening. It's a good bit smaller than a C5 Corvette's opening.
Old May 12, 2020 | 05:46 AM
Man-Crush Warning
Below 40mph: Fan 1 is on at 185, off at 180. Fan 2 is on at 190, off at 187
Old May 12, 2020 | 06:06 AM
97Z28SS's Avatar
I wonder if the FMIC is having any effect on your coolant temps as I'm building a turbo 4th Gen Camaro with a huge FMIC (31x12x5) and I'm going to install dual 11" draw thru fans with a shroud to my intercooler and wire the relays to come on with the engine fans and/or when the A/C comes on for this very reason.
And I think I will copy Shownomecy's radiator sealing parts to aid in cooling.
Old May 12, 2020 | 06:51 AM
Man-Crush Warning
Well, IAT match ambient when cruising so can't complain there.
As of now, drained the block (least half of it) and then filled/flushed/repeated a few times. Its now full of water and a water wetter bottle, plus whatever was left in the block that did not want to drain.
Sits at 180* at 70mph with 50-60* ambient temps. Curious to see what it will do when the hotter weather comes back.
Old May 14, 2020 | 07:13 AM
SRZ's Avatar
SRZ
Any way to blow those pics up? I am old and can't see! LOL Thanks for the fan settings too btw.
Old May 14, 2020 | 07:48 AM
ive had a few with the stock set up run per the thermostat like 160, but bost will run 15-20* higher.
Old May 14, 2020 | 08:53 AM
Man-Crush Warning
Old May 14, 2020 | 08:57 AM
Wouldn’t have been easier to get those two pieces used from a yard or Hawks and just bolt them on?
