MGW Fbody shifter!!
Old 12-11-2008, 11:25 PM
bballr4567's Avatar
Im going to adjust it tomorrow to make the stick as short as it can go. I didnt realize it could go down that much farther but I have the stick as high as it can go. Should be interesting and Ill put up some more pics.
Originally Posted by transAm-98
I 'll have to find someone with one of these to try out. I just can't imagine how anything could be better then a properly setup Pro 5.0.
Thats what I thought too but after hearing all the praise that MGW gets for their Corvette, Mustang and Viper shifters I was willing to give this a shot. Im VERY happy with it.
Old 12-12-2008, 05:09 AM
scorpion_z28's Avatar
How much does it cost??
i'm on the market to buy a pro 5.0 but i would rather wait & see what this shifter will do.
Old 12-12-2008, 05:54 AM
bigsticksupra's Avatar
so this shifter doesn't have set screws for stops like most of the aftermarket shifters?
Old 12-12-2008, 06:12 AM
alharbi's Avatar
well , i'm runing pro 5.0 shifter in my trans am and i like much more any others exept the MGM one coz it's the only one that i've not try it yet
so ... should i try it or it will just be a waste of time ... ??
Old 12-12-2008, 06:31 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Correct.
Old 12-12-2008, 09:46 AM
Well the MGW seems like a nice shifter since its used in Veets & Vipers,so i dont think its a waste of time to try something as good as the 5.0 but for a better price.
Old 12-12-2008, 12:01 PM
MeentSS02's Avatar
Got an answer from George at MGW as to what the grey goop is on the bottom of the shifter in the first set of pictures but not on mine.
According to him, some of the shifters' mounting holes were a little too far offset, allowing the relief holes (the four small ones you can see in the picture I posted) to hang over the mounting flange on the transmission. He said that it could cause some transmission fluid seepage, and that they put regular RTV on that area to keep that from happening.
He said that if it was the case (you could tell by looking at how it is mounted), you don't even have to remove the shifter to fix it. You can just squirt some RTV up under there, let it set, and it would seal it no problem.
Old 12-12-2008, 05:35 PM
bballr4567's Avatar
Again, the price is $200 plus shipping. Comes out to $210 total.
Reinstalled the #6 boot and its a TIGHT fight to get it under the console but it fits. Now my car is much quieter for sure. If you like to ride in a little bit of silence and dont like road noise keep it on the car. :lol
Meent, that makes total sense. I checked mine today and I had zero leakage. Can you adjust your stick up and down though? Mine has a lip machined into it so I cant move it any lower.
Old 12-12-2008, 05:37 PM
Coppertone's Avatar
What is the #6 boot? Sorry if I missed it.
Old 12-12-2008, 05:42 PM
bballr4567's Avatar
Its the stock boot in the car that goes over the shifter opening.
Stole a pic of it from MeentSS02 thread about his shifter as I dont have any.
Basically you install the shifter, then put the stock noise boot back over it. Makes it MUCH quieter! You can try to leave it off if you want but it was annoying for me especially if you get up into the upper RPMs as you can actually hear the transmission and output shaft really easy.
MeentSS thread:
https://ls1tech.com/forums/manual-tr...-shifters.html
Old 12-12-2008, 06:14 PM
Josh@KY-Turbo's Avatar
You have to call and order it? I didnt see it on thier website.
Old 12-12-2008, 06:18 PM
  #32
bballr4567's Avatar
Search the net for MGW Ltd and youll find their site. You need to call them up and ask them about it because they dont have it on their site yet.
Sure do.
Old 12-12-2008, 07:00 PM
  #33
99T/A_Marine's Avatar
I got mine in today. Looking forward to installing it tomorrow afternoon. I'll let you guys know what I think of it.
Old 12-12-2008, 08:13 PM
  #34
MeentSS02's Avatar
My stick didn't have a lip, but it really couldn't go any lower before hitting something (I tried).
Old 12-13-2008, 02:52 PM
  #35
Just got done about 2 hours ago with the install on mine. This thing is the real deal. REALLY short throws but it could just be because I had the stocker on before. Took me about 3.5 hours but I took my time so I wouldn't **** it up. Anyone who is looking at purchasing this shifter, DO IT! You won't regret it.
Old 12-13-2008, 03:20 PM
  #36
slowscott's Avatar
Does the MGW "click" into gear or is it a smooth transition? I loved my pro 5.0 because it was so solid and accurate, but it was also notchy feeling. Basically it could have provided the sound effects for the shifting action in fast and the furious. Not really a bad thing, but smoother would have been preferable.
Old 12-13-2008, 03:32 PM
  #37
MasterEvilAce's Avatar
I think there are two options for the throw reduction or something isn't there? Something like 25% and 35%, right? What do you guys prefer
Old 12-13-2008, 04:37 PM
  #38
C Murda's Avatar
what if i already have a short stick? can it be used with this or must i only use the supplied stick? also what if the stick is cut down at all to really lower the shifter ****, will that work? from the looks of how the stick mounts to the shifter it looks like a clamp and bolt to tighten it down right?
Old 12-13-2008, 06:11 PM
  #39
MeentSS02's Avatar
Correct...the stick mounts to the shifter with a clamp and bolt style connection.
Old 12-13-2008, 06:17 PM
  #40
qwikz28's Avatar
its quite notchy
i've had mine since early summer and i love it.
Quick Reply: MGW Fbody shifter!!
