Another Hall's deal!!!
What the **** is wrong with the driveshaft??? It was about the strongest one you can get!!! Denny's nitrous ready driveshaft!!!
The Torque arm set up sucks period, doesnt matter what brand you get!!!
My setup got 1.5 short times on 17 in DR full weight on motor...with a 10 bolt and 3.42 gears...not too bad...not many beating that now...
Killer rear end with new setup will be NICE!
Nate...take some more weight out of the front/nose of Masseys car, make it launch better....
MASSEY....you may have to get a new driveshaft with the new rear, so don't forget that piece too!!! OR...just go borrow Darren's car and tell him your going to dix his tranny for him! lol...
Well, sounds like a thank you is in order to JPH (and Nate?) for taking a look at Nick's car. I didn't catch that ground strap before I left. There's a lot left to do on the tune to get it happier, though I think right now the fuel injector kpa vs. flow table is WAY off which is what's drowning it. I'm going to play with it a bit more before we enlist the hired guns.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
[QUOTE=SDB;12194366]NATE>..
what evered happened to the guy with the blue corvette with the TT kit you swapped motors in????? IS it running right?? I always wondered how that thing turned out, saw him on corvette forum with some issues, never heard if he got it running right?
Well, sounds like a thank you is in order to JPH (and Nate?) for taking a look at Nick's car. I didn't catch that ground strap before I left. There's a lot left to do on the tune to get it happier, though I think right now the fuel injector kpa vs. flow table is WAY off which is what's drowning it. I'm going to play with it a bit more before we enlist the hired guns. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
[QUOTE=SDB;12194495] Wont run, wiring issues I think? Dunno.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
What the **** is wrong with the driveshaft??? It was about the strongest one you can get!!! Denny's nitrous ready driveshaft!!! Driveshaft is nice but fits for **** cant get the bolts out very easy and its almost too long barely comes out, had to roll the lower control arms back to give me enough room to remove it from the trans tail housing...
Its non adjustable and hits the under body in so many spots it really hurting the rear end drop on a launch...just my opionion![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
Nate...take some more weight out of the front/nose of Masseys car, make it launch better.... I would but he wants a fast street car with all options still I totally understand a/c is nice on a hot day... If every summer was like this one we wouldnt need it and Id yank mine too.
![Shiner](https://ls1tech.com/forums/images/smilies2/shiner.gif)
X2 on the thank ya's! I'm just glad the feeling of it being hard to turn over was the higher-than-normal seat pressures, and not a mechanical failure
what computer do you have running the engine? Is is just a LS1 ECM? Could you have CHad tune it from GMS?
It'd be running alot better had I told Blake the injectors are 80lbs at 3bar, not 4bar. The current fuel pressure is around 4bar which puts the injectors in the 100lbs range. My bad
Already getting bids for a new rear. Most likely a Midwest Fab9 like Darren has. Erik says 31 spline axles are Ok, but recommended the 35 splines with a locker. Backbraced, aluminum center, locker, powder coated, new chromemoly driveshaft and shipping was $3550. Pretty good deal considering it comes with a fully adjustable TA, too.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
When do you expect too see the Fab9 setup?? is his build time down now??
Funny, keep your illegal ideas to yourself...phucker. Tranny is being taken care of so don't worry pal.....by the way "NO Auto" being installed, thank you very much.
My stock bottom end 5.3L with 10 psi of boost survived fine under my tuning (tuning didn't cause the cam bearing failure...) and aside from being a bit rich (which was intended) the pistons and plugs looked fine when it came apart.
Nick's car just needs to get the fueling sorted in the PCM, right now it's drowning. Getting the sizing right and adjusting the minimum pulse widths, etc. will get it idling fine.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
That said, I'm not a expert FI tuner by any means, but, as Nick said, I can get it drivable.
edit: I'm about 99% sure I found the problem with Nick's car. When the tune file was converted to 3 BAR for the turbo, the VE table took a crap and went to all 518%. I don't think it's 518% at WOT + 25 psi of boost, let alone idle. That forced the injectors static and drowned it. I'll get that sorted this evening and it should run and idle just great.
Thats my buddy Seans (Air Force friend of mine) car. Yeah, he had a bunch of issues with it. The vibration ended up coming from the motor mounts, but it took him a while to get that figured out. He now is waiting to get it put on the dyno. It was supposed to be put on this week, but due to the shops scheduling issues, now will more likely be done in a couple weeks.
Seeing the APS turbo's leak like that, and being as they havent even been under any boost yet since the new motor, I have a feeling once its on the dyno and making boost, their going to be toast. Theres a nice long thread in the FI section of how APS is no longer selling kits to GM cars anymore, and how they also aren't offering any warranty or maintenence work for them either (basically a huge rip off for anyone with their turbo's).
Anytime you put a car through that much work, theres bound to be issues/bugs to work out. When it runs, it will run well. Probably in the 750 RWHP range. He seems pretty set on putting the smack down on CALL911 since it was in the race that his car went
He already has a place in mind to rebuild the turbo's if they go.
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
Kenny, still want to run STFU Subaru? He said he's down to run whoever this weekend.
Also, Blake put in the new tune. Car starts, idles, and revs like a champ!!!
