New Orleans Put the greasy talk here...PiMp
shreveport/bossier hang out!
Old 03-11-2009, 07:59 PM
  #2801
01ssreda4's Avatar
havent had a chance to fool with them....been really busy. for what it cost to clean them i may just not worry about it. im trying to figure out when im gonna swap them and how im gonna get it tuned.
Old 03-11-2009, 08:02 PM
  #2802
02blackbeauty19's Avatar
I gotcha.
Old 03-11-2009, 08:44 PM
  #2803
taws6m6's Avatar
You swapping for some bigger squirters?
  #2804
cainsw's Avatar
Well, I started to tear into the th350 today and found a broken retainer as soon as I pulled the pump out. Then found two burned frictions/steel bands before I stopped. I will finish it off tomorrow and see what else I might find. I knew this thing wasn't right, it's been acting stupid ever since I installed it. There is no reason that this thing has never ran anywhere near what it did with the 6 speed
Old 03-11-2009, 08:53 PM
  #2805
nitrobusa's Avatar
Theres your sign.... j/k
Old 03-11-2009, 08:55 PM
  #2806
01ssreda4's Avatar
yeah i got hiltons old SVO 30's.
Old 03-11-2009, 09:03 PM
  #2807
cainsw's Avatar
I have a feeling I haven't found the really messed up stuff yet
Old 03-11-2009, 09:05 PM
  #2808
nitrobusa's Avatar
All I know is I want to see chad's car with some slicks. 2.1 60's and mid 11 sec times That thing is gonna be retarded with those qtp's. Make sure you get some arp studs if you havent already, dont go out there and pull a chris and get the the rim off. Car is damn stout with a cam only. I ordered some from thunder yesterday bout 3pm and they were on my doorstep at 11am when I went outside with ground service
Thanks for the compliment, My tires arrived today and the car already has ARP studs in it. I should have the front and rear Qa1's by friday and I'm taking my car to Raceteck tomorrow to put everything on. (when) I get it to hook I think it will run low 11's on motor. Thats my goal...
Old 03-11-2009, 09:11 PM
  #2809
taws6m6's Avatar
there goes my .03 lead
Old 03-11-2009, 09:16 PM
  #2810
nitrobusa's Avatar
Originally Posted by blue98Z
Hey Chad, I meant to ask you what the specs are on that S cam if you don't mind sharing?
Cody/Steve, the vids were great fellas. It was nice finally getting to see mine rolling down the track.
Its no secret. This is the same cam that was in Jacobs silver vette. I has the HPE C-cam in my old car and it was an awesome cam too. I think it actually made the same power this one did through an auto trans.
HPE S Cam (238/240, 112 LSA, .605/.609
Old 03-11-2009, 09:21 PM
  #2811
taws6m6's Avatar
I thought raceteck was closed?
Old 03-11-2009, 09:32 PM
  #2812
01ssreda4's Avatar
well it wont make car any faster but it accomplishes a couple things. first, im getting rid of 105K mile injectors, second it opens me up for a small shot or heads later, and they are red tops so they are purty and match my car
Old 03-11-2009, 09:48 PM
  #2813
taws6m6's Avatar
get you a small shot I could probably squeak out an 11.99 with a pulley and a few passes. Never did bother buying one
Old 03-11-2009, 09:54 PM
  #2814
cainsw's Avatar
You can get in the 11.8x's with nothing more than seat time. Take a look at your mph
Old 03-11-2009, 10:01 PM
  #2815
taws6m6's Avatar
I have noticed my mph was pretty decent. I wish RRR would open back up. I could at least make it out there any friday, it would be late, but I could make it
Old 03-11-2009, 10:14 PM
  #2816
01ssreda4's Avatar
well hopefully i will be in the elevens w the gear swap and maybe a tiny bit more weight reduction. and if i could get my converter to hook from idle i bet i could see at least a low 1.6 or high 1.5 sixty foot. it kills me that i baby it off the line and can still cut the same sixty foots some of the 6K clutch dropping 6 speeds cut ..6 speeds
Old 03-11-2009, 10:17 PM
  #2817
taws6m6's Avatar
what were your 60's? What do you mean hook from idle? I thought as an auto you wanted to stall it up on the line?
Old 03-11-2009, 10:26 PM
  #2818
01ssreda4's Avatar
my best sixty foot was a 1.69 i believe. with a converter you have a stall speed it will jump to then a hit of power to the wheels. well if you stall it up then take off you have no momentum built up, you just get the advantage of the converter stall speed. if you come from idle and punch it, it free revs to stall speed then hits the tires with a lot more force therefor catapulting you forward a lot like a manual. its way harder to hook that way obviously. when i was cutting the 1.69 and 1.70s i was stalling it as high as possible so the intial hit would be soft on the tires. i came off at about 1000 rpms the first run and blew the DRs off. the car has more 60 foot in it, i think maybe enough to see elevens, but i have to hook it.
Old 03-11-2009, 11:55 PM
  #2819
blue98Z's Avatar
I figured it had to be a big cam, cause I was looking at our first run together and that thing really wakes up after the 1/8th. That's the reason I asked.
Old 03-11-2009, 11:59 PM
  #2820
blue98Z's Avatar
Wait til I get my 2-step. MSD makes one for the LS's now, so I can't wait til I get one. I've been watching the vids over and over listening to the car and the launch. It was still bogging a little at 6k, so next time I'll try about 6200. So when I get the 2-step I'll know where to set it. I'm gonna have that thing leaving alot harder and more consistently soon.
Quick Reply: shreveport/bossier hang out!
