My Stock shortblock/cubic inch cam-only entry:) 56k beware
#422
Looks stellar. When ya shooting to have it back out? Im hopin mine will be done in a week or so, nothing as cool as this but i did get a blue nose pitt yesterday, gonna teach him to drive to keep the raceweight down.
#423
Yes sir!!!
You aint seen nothing yet![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Hoping this Saturday will be the day, but it might be next weekend. I've got a NX SAFE stand alone fuel system coming right now they built for me with a walboro 255lph pump and an aeromotive regulator along with some really trick solenoid brackets.
This is the way I was going to mount everything
![](http://i1105.photobucket.com/albums/h344/fbodyjunkie06/0806122229-1.jpg)
NX is sending me these.....The kits should hit very, very hard being that the solenoids are this close to the plate.
![](http://i1105.photobucket.com/albums/h344/fbodyjunkie06/IMG956570.jpg)
![](http://i1105.photobucket.com/albums/h344/fbodyjunkie06/IMG956385.jpg)
![](http://i1105.photobucket.com/albums/h344/fbodyjunkie06/IMG954241.jpg)
#430
Thanks Sof! I'm loving it too and I haven't even used it yet!
I told ya those brackets are P.I.M.P.!
Hey now, without pioneers where would be in this stock shortblock stuff?![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
I got something else yesterday that really makes it a copy of yours!
Thanks man I'm re-doing most of the wiring this coming week when I bring my car up to the shop finally so it can stay here for customers to see and so I have all the tools I'll ever need to work on it. *Love my job*!
Here are some more parts pictures!!!
![](http://i1105.photobucket.com/albums/h344/fbodyjunkie06/0816122012.jpg)
![](http://i1105.photobucket.com/albums/h344/fbodyjunkie06/0816122012a.jpg)
![](http://i1105.photobucket.com/albums/h344/fbodyjunkie06/0816122012b.jpg)
#432
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Cam if you could have compression where you wanted it to be fully optimized for nitrous on a 275-300 shot of nitrous where would you put it? I'm trying to decide on what chamber size on the new heads. I'm using a flat top as I was told my the fastest lsx nitrous car in the world to use one and to not run the compression where I wanted to at 14.2:1. Too high and it won't make a difference in how it runs after so much compression, and just closes the tuning window. I knew the tuning window will be small but I run my motor now low on timing compared to most people on race gas and try to run it lean and clean, but that wasn't working for me on the higher jetting I tried for my set-up.
And of course let me know what happens this weekend. Shoot me a text with some run info. What time does your race start?
#434
If it looks half as good as yours does I'll be good with it. I'm actually really trying to make it look like your set-up does because it is clean, that should be a compliment me copying you.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Id run it 12:1-13:1 to keep an open tuning window. Once past that its not worth the power to the tuning window you have. Weather changes so often that having that window large enough for some error is always a good thing, becuase you arent always gonna nail that tuneup. Domed also gives more edges and bends for detonation and dislocations to occur. Boom
first pass should be at 10am pacific time tomorrow. We shall see what happens
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#436
Why thank you sir. We work hard to make it run good and look good at the same time. We dont like to throw things together.
first pass should be at 10am pacific time tomorrow. We shall see what happens![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
I'm really leaning towards 13:1 maybe 13.5:1 for compression and 65-70 thousandths quench with heavy chamber softening and a flat top. Maybe even more quench. I'm going to have the head set-up with 65-70 thousandths and however far down in the hole we set the piston will determine what the final numbers ends up being.
#439
Yes, I love my job I couldn't ask for a better fit for me than to work in the high performance industry and around guys that are as selfless as the people I work with to get me going even faster, not to mention the help from NX!!!
I got to give a shot out to Kyle@NX for making all of this happen for me and I can't leave out Mike and Trey either!
#440
Here's some new pictures for you guys to look at....
Finally got my car up to the shop where it belongs with the rest of the pack. Be looking for these two cars in a 275 drag radial class near you!
![](http://i1105.photobucket.com/albums/h344/fbodyjunkie06/IMG_20120823_112107.jpg)
We also got some new rubber for both of the cars, Mickey Thompson 3574x FTW!!!
![](http://i1105.photobucket.com/albums/h344/fbodyjunkie06/0823121131.jpg)
I'll also have some updates for the nitrous fuel cell and wiring here shortly. We are fabricating the mount for the fuel cell right now and we're fabricating a fuel pressure gauge mount that will be welded to the radiator support so that I can see the fuel pressure gauge when I'm adjusting pressure. Where the cell is going to sit you'll never be able to see the gauge if it was mounted to the regulator.
Also NX has stepped it up AGAIN for me!!! They are custom bending some hard lines for me to run from my solenoids to my plate!!! I couldn't ask for a better sponsor than NX!!! Thanks for all you do for me, and if ANYONE needs the best product available AND some of the best if not THE best customer service and support in the industry, do not hesitate to pick up the phone and call NX! We're also a dealer for NX(and Nitrous Outlet) here at the shop so you can also call me and I'll get you taken care of one way or the other!
