Street Racing & Kill Stories Basic Technical Questions & Advice
Mach at the track
Old 05-15-2013, 05:35 PM
  #2441
HioSSilver's Avatar
It don't take much to get a lt to run 13.0's........it sure don't take a slick.
HioSSilver is offline
Old 05-15-2013, 05:38 PM
  #2442
Demon 383's Avatar
In all seriousness I have NEVER in 10 years seen a stock Mach 1 go any quicker than 13.5@ like 103.xx, and I frequent both local tracks A LOT! So can someone tell me where to find these Mach 1's that run 13.2 stock and whoop on LSWon's?
Demon 383 is offline
Old 05-15-2013, 05:39 PM
  #2443
Demon 383's Avatar
Yep, bolt-ons will do it no problem. Full weight, no slicks.
Old 05-15-2013, 05:46 PM
  #2444
MACHXLR8's Avatar
Those times you quoted are more for automatic MACH 1s. The 5 speed is a much quicker car.
Regardless, the car is quite capable of running low 13's but like anything other car, it has to be driven to its potential.
MACHXLR8 is offline
Old 05-15-2013, 05:51 PM
  #2445
Demon 383's Avatar
This is what always throws me for a loop. How's a 3400# car with 27XRWHP a low 13-second car? Albeit, in prime conditions maybe, but on average the times I've seen out of them seem on par for the power/weight.
Old 05-15-2013, 05:57 PM
  #2446
ThoR294's Avatar
The one i raced was stock (owner of a dealer got one on a trade in. 40k miles was yellow/black). that's why I figured they were mid-low 13 cars
ThoR294 is offline
Old 05-15-2013, 06:08 PM
  #2447
MACHXLR8's Avatar
Gearing...The Tremec 3650 in addition with the 3.55 gear ratio work well together. In addition, the car does not weigh much. As you stated 3450lbs. It also makes good torque at 320ft/lbs and continues to makes power to about 6300rpms. It is not always about Hp..sometimes it is the combination of things that can make a car quick.
Not trying to blow sunshine up the MACH1's a$$, just trying to come up with some possible reasons.
MACHXLR8 is offline
Old 05-15-2013, 06:21 PM
  #2448
Demon 383's Avatar
What's a typical trap for a Mach?
Old 05-15-2013, 06:26 PM
  #2449
Theblacknightls1's Avatar
That actually sound about right. It takes 300whp to hit 12s at that weight. So maybe that's why a stock ls1 can break 12s easy with a good tire
Theblacknightls1 is offline
Old 05-15-2013, 06:38 PM
  #2450
S8ER95Z's Avatar
The truth of the matter is for every bottom 13 stock Mach there is a high 12 stock ls1 car (evidence on here suggest its one is more common than the other.) Neither are 'easy' feats and both take near perfect conditions and a great driver (Evan smith, stopsign, etc ).
S8ER95Z is offline
Old 05-15-2013, 06:43 PM
  #2451
adamantium's Avatar
Originally Posted by S8ER95Z
The truth of the matter is for every bottom 13 stock Mach there is a high 12 stok ls1 car (evidence on here suggest its one is more common than the other.) Neither are 'easy' feats and both take near perfect conditions and a great driver.
adamantium is offline
Old 05-15-2013, 06:55 PM
  #2452
Tech Apprentice
Stopsign32v's Avatar
If that LT1 has any motor work done to it then what are you going to do, order a blower right?
If the imaginary LT1 with full bolt ons that could "prob" beat me had some imaginary "motor work" done to it, I guess I could slap on an imaginary blower. f'in tard
Stopsign32v is offline
Old 05-15-2013, 06:56 PM
  #2453
Tech Apprentice
And I've never seen a stock LS1 run better than 13.7
And since when do a Mach 1 dyno 27Xrwhp? This site ooozes with Mustang knowledge.
Old 05-15-2013, 07:09 PM
  #2454
oChristiano's Avatar
I'll let you know what I run tomorrow in the 1.8 96Z28 LS1/4L60E swapped, LS1 intake stock manifolds into SLP LM1 LT1 Intake 3.23 rear gear. Motor and trans are stock. Its essentially a 2000 SS I used as a donor.
oChristiano is offline
Old 05-15-2013, 07:34 PM
  #2455
topendrunner's Avatar
what do they make then?
topendrunner is offline
Old 05-15-2013, 09:11 PM
  #2456
Demon 383's Avatar
I agree.
Always swift with the insults huh? Yep over the internet...
Be honest with yourself. Don't lie just to prove a point.
Old 05-15-2013, 09:12 PM
  #2457
Demon 383's Avatar
Mach 1 = average mid/high 13sec car
Old 05-15-2013, 09:15 PM
  #2458
HioSSilver's Avatar
You do realize full bolt-on lt's have been in the 11's right. There was a recent thread on here where another guy did it.
You must not get out much.
Old 05-15-2013, 09:45 PM
  #2459
***Repost Police***
Irunelevens's Avatar
If you want a realistic comparison of what a particular car can do, why bother talking about "average" times? If I'm trying to figure out if I can beat somebody, I wanna know what they can do on a great day. Stopsign ran a 13.2 with just an H-pipe and a shifter. His first time at the track with that car. So it isn't much of a stretch to imagine that a good driver in good conditions with some practice couldn't equal that time minus the ~5hp that the H-pipe gives.
Irunelevens is offline
Old 05-15-2013, 10:11 PM
  #2460
S8ER95Z's Avatar
I agree completely... When I first had my car I never looked at a stock Mach 1 and laughed.. I assumed it was going to run right with me every time and I needed to be on top of my ****. Maybe I had very little to worry about but I always assume the other driver is going to run their best.
S8ER95Z is offline
Quick Reply: Mach at the track
