Street Racing & Kill Stories Basic Technical Questions & Advice
Mach at the track
Old 04-01-2013, 09:43 PM
  #161
Tech Apprentice
Stopsign32v's Avatar
Originally Posted by Theblacknightls1
OP, Your mach moves out pretty good for having a NA 4.6!
Thanks man!
Stopsign32v is offline
Old 04-01-2013, 09:49 PM
  #162
Turbo2vGT's Avatar
Definitely good run OP. Two of my buddies with Machs were running mid 12s at 109-111 with midpipe, catback, k&n filter and a dyno tune.
Turbo2vGT is offline
Old 04-01-2013, 09:50 PM
  #163
HioSSilver's Avatar
Originally Posted by Stopsign32v
All you are pointing out is GM owners need an average of atleast 50rwhp to keep ahead of a Mustang at the track. Bravo....bravo
Take them slicks off. I'm sure his et would drop with a slick, the rear would even have it a little easier. But you see we don't need a slick to outrun you because our engines out power you enough that we can do it in STREET trim.
HioSSilver is offline
Old 04-01-2013, 09:51 PM
  #164
Turbo2vGT's Avatar
Go away already.
Old 04-01-2013, 09:54 PM
  #165
Tech Apprentice
You need sticky tires and more power to run what my car runs with sticky tires and less power. Again I say, bravo.
Old 04-01-2013, 09:56 PM
  #166
Tech Apprentice
Originally Posted by Turbo2vGT
Go away already.
He will never shut up. Last time when he bitched and all about how I ran 12.5 he brought up the low MPH. I then said "What are you going to say when I go back next time and run low low 12s?"
I guess now we know.
  #167
HioSSilver's Avatar
Go away already.
lol...don't like the truth?
It was all good until he posted that slip about his Mach running a calculated 11.96. Then I posted a slip of what he would have to mph at to get to the 11.96 from a car that 1/8'd better than him.
Old 04-01-2013, 09:57 PM
  #168
HioSSilver's Avatar
Like I said....Do it in street trim. That's what he did.
Old 04-01-2013, 10:01 PM
  #169
clonedws6's Avatar
They won't understand...
clonedws6 is offline
Old 04-01-2013, 10:03 PM
  #170
Tech Apprentice
Where did I do this? I don't even know how you post a calculated slip as you put it. Do you ever get tired of hearing how stupid you are?
I run my car at the track to be as fast as it possibly can be with the power I have. It's called a drag strip for a reason. Not a street trim strip you dumbass.
Old 04-01-2013, 10:05 PM
  #171
Turbo2vGT's Avatar
Why don't you do yours in street trim on 17" radials with factory wheels on the front and rear of the car? Maybe with a stock unfaceplated trans too? The point (most of the time) to go to the track is to get the best time you can, any way you can.
  #172
Turbo2vGT's Avatar
inb4"yourcarhasaturbo"
Old 04-01-2013, 10:06 PM
  #173
clonedws6's Avatar
Lol looks like someone struck a cord. So much name calling.
Old 04-01-2013, 10:07 PM
  #174
clonedws6's Avatar
Except, no one cares. Lol
Old 04-01-2013, 10:08 PM
  #175
HioSSilver's Avatar
You posted a calculated bullshit time....my bad no slip involved but still the same amount of bullshit on your part.
Because you know it would be .5 off w/o that tire. You do it for bragging rights. We do it just to see where our cars are....because after all these are street cars. if not then your in the wrong section.
Old 04-01-2013, 10:09 PM
  #176
Turbo2vGT's Avatar
Everyone cares.
Old 04-01-2013, 10:10 PM
  #177
lemons12's Avatar
Fact: Any way you dice it, Kevin's car works.
MPH means absolutely nothing at the drag strip, ET is all that counts.... 60' matters more than ANYTHING in drag racing. If you can't 60', you can't ET what you should, no matter the top end.
lemons12 is offline
  #178
HioSSilver's Avatar
For sure.
Why don't you take your turbo off and run 14's?
Old 04-01-2013, 10:11 PM
  #179
clonedws6's Avatar
And possibly the wrong website completely. Lol. Drag racing videos on sr&k! Winning. He sure knows how to build a car! You know with that cold air and shifter and those gears that someone out in for him haha
  #180
Mike Morris's Avatar
Nice job Kevin. Got to get a real cable set up for your clutch though
Mike Morris is offline
Quick Reply: Mach at the track
