Mach at the track
#1861
Why would I compare your car to mine?? That's what you were trying to do for about 60 feet. and you need a full slick to even do that.
Another lose for team Mustang.
Stock master is 3/4" bore. Ours is 7/8". It is also adjustable so that you may increase or decrease the stroke that the rod has which in turn moves more or less fluid. Our line is also larger and heat shielded from accidentally boiling the fluid from getting too hot.
I have never had a hydraulic failure. Tried to blame some issues on the hydraulics in the beginning but they were not the problem. I ran some new fluid threw my clutch a couple years ago.....but I do the same for the brakes every once in a while.
I changed the master when that was the "in" thing to do in 02.....but it made no difference.
#1863
How? Because racecar
#1864
NA 4.6L stock motored Mustang with a "ram air" intake, shifter, catback, gears, and a tire that can out 60' a Camaro with a built crate motor, faceplated built transmission, drag tires, aero mods, holes drilled in it to lighten it to 2900lbs, and a $700 used 3.5" tripple disc clutch.
I bet you exaggerate your ***** length too. I'm sure you got ***** length and my clutch diameter confused.....lmao
Modified 32v v8 Mach 1 Mustang.....can't get to 110 in the 1/4 on slicks.
#1865
#1874
Why don't you compare yourself to Notch's car......oh that's right we already did that. You lost there too.
#1877
Then I guess you need to mod up or .......cause right now you and your Mach 1 is getting wore out.
As soon as i get my Mustang done it's gonna be faster than you too. You'll probably commit suicide then......but it's gonna happen so prepare yourself.
#1878
My race on the street against Sepno was on a different setup.
I don't really care to mod up right now. You are the one that seems concerned, not me. Ill add more power mods in fall, maybe. Need struts and coil overs next. After that probably battery relocate.
#1880
I just saw the vid of you vs him at the strip he reels you in bad, and on street tires too vs you on a DR. Thats only a 110 mph car too. Your car really does lose its steam bad up top.
I know your trolling hio but damn if a 110mph car reeled you in that bad i can imagine a 130mph car :x
