Bolt on 5.0, beats 4th gen 427 stroker camaro SS
#461
324, na 10.9:1 +1valves, big cams, Sullivan
Let's see. So less cubes then hiho machine, similar compression as hiho, aftermarket mani like hiho, valve train work like hiho, heavier then hiho, ported stock heads about like hiho ls6 heads. Yet is faster and quicker hmmm modular suck so bad lolz
#464
mce day 11/17/12 na mach 1 - YouTube
In case you have not noticed I try to stick to cars I am hands on with. But when you pull stupid out of your pocket it gets hard to.
#467
Actually no I didn't....I tried to then went back and looked. I didn't. You assumed I had a fast intake on it then. That's on you. You should've asked before you assumed anything. But you got to caught up in trying to catch me at something and made yourself look stupid again.
#468
you stated "NOW" meaning RIGHT now and you didn't mention anything about your intake and said only thing not stock on the engine NOW is the springs and rockers......What does NOW have to do with that Dyno sheet that I've yet to mention a single number from.......Keep reaching though its fun to watch you squirm its been a while since I've toyed with you....
You were wrong it's okay to admit every once in a while no one will judge you any different you already made a name for yourself here....
#472
So you want to compare a completely built car against my bolt-on ls6 dd car. Figures......Was that car on 93? Do you personally know the car? Car weight?Is it yours? You do realize it was on slicks right? Do you realize it is not as fast as a cam only ls1? Do you realize it is not as fast as the fastest bolt-on ls6?
I wouldn't consider your purpose built car to be a DD.
I'm sure it's just as modded, if not more modded that the car you just called a race car.
#474
So what happens when you lose this SRK competition? Are you going to cry foul because some of the cars are going to be on "slicks"?
#475
Auto you cant this stupid well i wouldn't put it pass you. Just because it has been out for awhile doesn't mean the 5.4L is comparable to the 5.7 dipshit.... but bc you wanna compare an engine thats been out for a while lets compare the 572 to the 5.4L. Using your logic btw auto now try and twist **** and try to explain how much better the 5.4L is over a 572 bbc. Ill wait...
#476
any time a car gets a single mod its purpose built. If there was no purpose then it wouldn't me getting a modification. Even an air lid is for a purpose. Cant draw lines here.
#477
#478
#479
7 Second Club
Too bad it could never be contained in one place and would continue to spill out errywhere on SRK as normal. lol
#480
Can draw lines here, big difference between bolting on a air lid and making your car look like swiss cheese.
Bolt on's are one thing, taking a hole saw to your car, removing key safety equipment and face plating a transmission is a whole different thing.
