Street Racing & Kill Stories Basic Technical Questions & Advice
Epic SRK B/S thread of 2019
Old 07-20-2019, 07:35 PM
  #2421
6gmarc's Avatar
My big hesitation on the 2018+ Mustangs is how much I see for sale threads that state “fresh transmission” and the car has 25k miles on it.
Hopefully just an early fluke but eeeek owning that outside of a warranty. At least with my 2013 the 5.0 and 6r80 were stout.
Old 07-20-2019, 08:02 PM
  #2422
Chris25's Avatar
Originally Posted by JayplaySS2
Yea very simple - update tune only needed
Just being my DD
I guess I could get used to the locations
Just was curious I've been on the fence about doing mine got everything in the garage just like you it's getting used to which locations carry it .
Old 07-20-2019, 08:13 PM
  #2423
Mike Morris's Avatar
2018s seem to be hit or miss for motors too. Lot of them here have failed. Then some other people boost the daylights out of them, they run single digits and then drive home.
Old 07-20-2019, 08:14 PM
  #2424
Moderator
JayplaySS's Avatar
Mine doesn’t make noise either I bought it new
Who knows
Old 07-20-2019, 08:16 PM
  #2425
Moderator
JayplaySS's Avatar
Didnt you live in South Florida?
Old 07-20-2019, 08:18 PM
  #2426
Moderator
JayplaySS's Avatar
I may pick up another C6Z
But it won’t run 8’s
https://www.cars.com/vehicledetail/d...1852/overview/
Old 07-20-2019, 08:26 PM
  #2427
Good. Hope it stays together
The motor noises have been labeled from anything from valve train ticks, piston slap, direct injection type ticks, charge motion plates rattling and so on. As of about early 2018 when the new 3rd gen 5.0L cars started to come through local shops and dealers here, even while still entirely stock; you could hear some of these various ticks and noises on several of them. Some of them had what clearly sounded like a old school collapsed lifter type tick coming from the top of the motor, some had what clearly sounded like piston rattle/slap under very light load while motor temps were still cold. Some of these noisy 5.0Ls had gone back to the dealer for fixes while under warranty only to get the car back with no clear answers as to what fixed it, and some even received new motors (under warranty) only to have the ticks or noises return shortly afterwards. So far there has been no definitive word or explanation on what is going on or what is being done (if any) for a permanent fix. Then again there are others that are quiet, others that make racket and run single digits. Very odd.
More ammo for Hio
https://ls1tech.com/articles/ls-dest...UpwsRNbZVDEK_U
Old 07-20-2019, 08:31 PM
  #2428
Old 07-20-2019, 08:48 PM
  #2429
Moderator
JayplaySS's Avatar
More ammo for Hio
Very odd indeed
I’d like to see a turbo build but it will cost more to build a coyote from scratch.
With that said though, honestly I don’t know of any built LT in the 7s like Lund’s car. Now LMR has a C7 with 2 power adders, built engine, blower and nitrous.
Lunds turbo Mustang with a coyote, not an S10 swap or foxbody swap runs 7.67 @ 183.5 - no nitrous
LMR C7 runs 7.55 @ 184 with 2 power adders
8.13 with blower only
The Pony Wars show (pretty good) just had the dynos between the LT, 392 and Coyote but they didn’t release the Coyote numbers as a cliff hanger
Pretty good show
Old 07-20-2019, 09:17 PM
  #2430
7 Second Club
islander033's Avatar
Originally Posted by BlkMach1
LMAO ok ma'am. Thanks for the new stips. Im still SBE/SLB.
She sure goes full semi automatic trigger easy. LOL
Old 07-20-2019, 10:05 PM
  #2431
UltraZLS1's Avatar
An early large batch of the 18s had a major valvetrain problem. Heard this directly from a guy at Watson racing in Detroit when I had my dyno done. Huge ford sponsored performance shop that races mustangs. That’s only thing concrete I’ve ever heard
Old 07-20-2019, 11:07 PM
  #2432
6gmarc's Avatar
I’m from Iowa.
I could definitely see us retiring to Florida though down the road as we vacation there often.
Old 07-21-2019, 06:39 AM
  #2433
Chris25's Avatar
That's clean. Pull the trigger lol
  #2434
Chris25's Avatar
I’m from Iowa.
That's like two different worlds lol Iowa to Florida.
Old 07-21-2019, 07:09 AM
  #2435
7 Second Club
Iowa is a nice fly over state.
Old 07-21-2019, 07:55 AM
  #2436
6gmarc's Avatar
That it is. Give me a beach and a cold beer and I’m a ok.
islander has a loose butthole.
Old 07-21-2019, 11:41 AM
  #2437
kinglt-1's Avatar
so now OPGs makes a car not SBE. Lol damn, good thing I’m still SBE then.
You made any passes on your proper LT1?
Similar to a LS, The Coyote's oil pump is bolted to the block and crank driven...so it's located behind the timing cover and you are opening up the engine to gain access. However, the amount of work involved in order to swap those gears compared to a LS( which sounds relatively simple), I could probably do H/C/I swap on a LS. So please explain to me how you can rationalize a billet OPG being a mod that doesn't alter the engine from being SBE? My opinion is, if you open up the engine on either platform by removing any of the covers and changing any of the factory parts behind those covers, then the engine is no longer truly SLB or SBE.
Nope I haven't. It's not proper according to SRK standards anyway. It needs drag pack, seats pulled, race brakes, race seat, custom ram air, light battery, rear spoiler removed, lexan windows, short belt, and rockers...then it might be getting close.
The following users liked this post:
Mike Morris (07-21-2019)
Old 07-21-2019, 11:56 AM
  #2438
BlkMach1's Avatar
What about changing to a heavier full synthetic oil compared to stock lighter weight blends?? Still SBE??
Old 07-21-2019, 12:11 PM
  #2439
7 Second Club
Originally Posted by blkmach1
what about changing to a heavier full synthetic oil compared to stock lighter weight blends?? Still sbe??
owned!
Old 07-21-2019, 12:14 PM
  #2440
kinglt-1's Avatar
Aside from removing a drain plug, You don't have to open the engine up to change oil...oil isn't a mechanical part, So yes still SBE.
Quick Reply: Epic SRK B/S thread of 2019
