Old 05-13-2016, 02:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevoret Camaro or Pontiac Firebird Brake Guides
Browse all: Brake Guides
Print Wikipost
CTS-V Brake Install w/ Pics
Old 07-29-2011, 01:12 AM
  #341
mac62989's Avatar
Killer I saw a sweet carbon Brembo sticker on here someone had made. Looked ill
Old 07-29-2011, 01:56 AM
  #342
JoshuaGrooms83's Avatar
Originally Posted by armintheman
those look great! paint or powdercoat? as for the skinnies i found out that ccw makes a custom 17 that fits over them! i thought it had to be an 18+ but he said its the same wheels they sell to the c6z06 guys...
THats cool then. Must be specailly made to fit skinnys. My only question is why would you get huge front brakes if your using skinnys? unless you switch em up between the track and street? I dont really do skinnys so im not sure. Not my style. but cool they made 17" fit the ctsv calipers. Wish i could fit them with my regular 17" rims lol
Old 07-29-2011, 02:10 PM
  #343
Killer_Z's Avatar
painted. Medium Blue Metallic.
I'll look into it.
Old 07-29-2011, 05:22 PM
  #344
LPE 403's Avatar
I know that guy.
Old 07-29-2011, 06:43 PM
  #345
mac62989's Avatar
Yes sir. I couldnt remember the numbers so I didnt wanna just say LPE aka the master of subtle detail that really catches the eye.
Old 07-29-2011, 07:24 PM
  #346
LPE 403's Avatar
Old 09-07-2011, 06:54 PM
  #347
zacht's Avatar
gm high tech did a writeup on this mod using 09-10 cts-v calipers, the 6 piston calipers. everything goes the same, but i think its cool that these fit too. instead of having to run corvette calipers and the brackets to get the 6 piston fronts.
only down side: i checked gmpartsdirect and the newer calipers are 330 a piece...vs. 140 for the older 4 piston calipers. still have about 8-900 bucks in the front brakes with 6 piston calipers tho!
http://www.gmhightechperformance.com...bc_rotors.html
Old 09-27-2011, 10:16 AM
  #348
PERFECT Z28's Avatar
Does anyone know if these will fit on my '00 Z28 with CCW 505a's that have a corvette backspacing of 775mm? (not sure of the offset)
NM, CCW told me I would need a 3/4" spacer or more for fit these on my Z since my front offset is 57mm.
They advised me that a C6 Z51 caliper set up would be my best bet based on my setup.
(hope this helps someone else)
Old 09-27-2011, 10:37 PM
  #349
vonskee-z28's Avatar
so from what i read, the 6 piston 06 corvette caliper won't work without using a different mounting bracket? where do you buy the bracket from??
Old 09-28-2011, 04:53 AM
  #350
RONIN LSX's Avatar
I thinking about doing the 6 piston setup or the Strange Dual caliper setup. I know the dual caliper is over kill on a N/A, but it looks soooo SICK!!!
Old 11-16-2011, 01:02 PM
  #351
SpinsB's Avatar
I know this OP is a sticky and is old but is it possible to put the 4 piston ctsv calipers on all four corners of an fbody.??
Old 11-27-2011, 08:49 PM
  #352
bobbo489's Avatar
I have read this entire forum and looked and even tried looking through gmpartsdirect, does anyone know what the loaded calipers are or what all I would need to order to make these, tried calling some salvage yards around me and all of them are completely lost as to what a CTS-V is.
Old 12-15-2011, 07:48 PM
  #353
King Nothing's Avatar
^try the classifieds
Old 12-15-2011, 10:56 PM
  #354
Tudds's Avatar
I have a set I'll sell. One was test fitted. Other side never installed.
Have the flynbye lines brand new and hawk pads
Email me an offer
Toniorusso@gmAil.com
Do not pm me. I don't come on here anymore
Old 12-16-2011, 12:32 AM
  #355
silverboy02's Avatar
how much tudds?
Old 03-11-2012, 06:30 PM
  #356
LPE 403's Avatar
Plan ahead and its the easiest brake upgrade anywhere...
Old 03-11-2012, 07:47 PM
  #357
LS1HIGHLIFE's Avatar
Dude what size and offset are those FM5s? They look pimp!
Old 03-11-2012, 08:23 PM
  #358
LPE 403's Avatar
Thanks! 18x9.5 Profil +38
Old 03-15-2012, 11:00 AM
  #359
Killer_Z's Avatar
I just did the install a week or 2 ago. 18x9.5 C5 deep dish, used the 12mm spacer. and had plenty of room. easily stick my thumb in between the caliper and spoke. its been raining so havnt had a chance to get pics. will get pics soon.
Old 03-15-2012, 04:20 PM
  #360
sweet, can't wait to see your pics.
Quick Reply: CTS-V Brake Install w/ Pics
