Conversion folks please list your conversion in here
Old Jul 25, 2013 | 07:26 PM
  #1381
sfiore's Avatar
Default LS2 swap to 1952 chevy fleetline
Hi all
As title says
I will be putting a L76( LS2) with a 6LE auto transmission into a
1952 Chevy Fleetline. The donor car is a 2009 pontiac g8 gt
I will be trying to use as much of the donor as practicable.
Any help / suggestions will be appreciated
Steve
Old Aug 1, 2013 | 07:55 AM
  #1382
cruisin'73's Avatar
Default 73' Nova Carb'd 5.3
I have anticipated the moment I could add my finished (Is it ever REALLY finished? ) Nova to the LS Conversion page. Her she is:
1973 Nova 4 Door
2001 5.3-all stock
Speed Demon 750
th350
Old Aug 1, 2013 | 04:51 PM
  #1383
s/clsxmagnum's Avatar
Default 2005 dodge magnum lq4 swap
2005 dodge magnum lq4 4l80e big comp cam supercharged
Attached Thumbnails Conversion folks please list your conversion in here-2013-08-01-17.11.42.jpg
Old Aug 6, 2013 | 07:46 PM
  #1384
turby57's Avatar
Hey guys I have a 1990 s10 that I put a 5.3 in. It is a carb conversion, with holley 750 double pumper & pacesetter headers, a built turbo 350 trans, 3200 b&m stall, narrowed 12 bolt with a 390 posi, and moser axles with c clip elim. I want to change the camshaft and valve springs, and pushrods....the problem is I have read so many forums, that I really cant decide what the best combo would be. I would like to put a hefty nitrous kit on it as well, but that all depends on how well it will hook up. Any advice is greatly appr.
Old Aug 9, 2013 | 10:12 AM
  #1385
cajun1955's Avatar
I have an ls1 installed in a s10 extended cab 1998. I can't get the ac to work I have the request signal to the PCM and the wire from the PCM to the relay but the couch will not engage. I connected the cluch wires to a battery and it works so that is not the problem the pressure switch is also connected to the PCM correctly. Help please is it a PCM issue ant I have heard you can bypass the PCM for the ac but I don't know how. Please help
Royce.
Old Aug 16, 2013 | 09:53 AM
  #1386
Ironfreak's Avatar
I have a 1988 BMW 325is that I'm putting a lm7/m6 into. The build is staged out. fisrt step is N/A setup to get it rolling and tune the suspension. Then BOOOOST.
Old Aug 22, 2013 | 02:47 PM
  #1387
X Move's Avatar
Originally Posted by A-man930
1969 IH Travelall
'02 F body LS1 Twin Turbo
4L80e
Build in Progress with pics coming soon!
Way cool! I've always wanted a 69 Travelall with an LS7!
05 impala 4t65e
'06 LS4 4t65ehd
Old Sep 5, 2013 | 08:43 AM
  #1388
Project Daily 57's Avatar
1957 Chevy Pickup Shortbed
Complete Fuel Injected LM7 5.3 w/ 4L60E Trans includes all factory wiring
Flashed computer, Flowmaster 40's, K&N FIPK for 5.3 truck, MSD ignition
Father/Son Project
Old Sep 5, 2013 | 10:31 AM
  #1389
pdlightning's Avatar
Default 914 Porsche
Converting a 1971 Porsche 914 to a 911 suspension with LS1 crate motor with a 915 transaxle with new high geared ring and pinion.
I know.....not a real Porsche after the conversion! Heck it wasn't really a complete Porsche to begin with! Had a type 4 Volkswagen 1.7 L with 75 HP to begin with!
Old Sep 5, 2013 | 12:02 PM
  #1390
Lrn2Go's Avatar
1) 1993 (more or less) Nissan 240sx
2) Ls2 from an '05 C6 Vette and a GTO t-56 transmission.
3) Pics!
Started here:
Then here:
Then here:
And now in progress:
Old Sep 6, 2013 | 11:01 AM
  #1391
Bilster's Avatar
Did a search of this thread and I may be the first to do a 97-03 Ford F150 conversion. Mechanically, it was the easiest swap I've ever done. I'm running a 5.3/T56 combination. I made the couple of mistakes. The first was avoiding automotive electrics for so many years. The second was purchasing the harness from a company with almost no tech support. The wiring took awhile...a long while to figure out. Needed LS1tech support ; ) but got it done. Still trying to figure out gauges but it's my daily driver and I'm enjoying it!
Old Sep 6, 2013 | 11:21 PM
  #1392
PEPS's Avatar
Just starting on my 68 Chevelle. Putting in an LS1 with T56 out of a 2004 GTO. No pics yet. Just doing a lot of research here. Great wealth of info.
Old Sep 8, 2013 | 01:22 AM
  #1393
Mlovett's Avatar
Default 1973 maverick
6.0L 4l80e into a 73 maverick
Old Sep 8, 2013 | 02:52 AM
  #1394
Jwilliams04's Avatar
402 LS2 Built T56 S475 T6 Turbo
04 G35 Infiniti Coupe
Full suspension and interior
Old Sep 8, 2013 | 02:53 AM
  #1395
Very Nice Nova. Clean install
Old Sep 12, 2013 | 10:48 PM
  #1396
Boneyard buick's Avatar
1985 buick regal, 5.3 Lm7, Gts76, 3L80HD (th475), micro
Build thread starting soon
Old Sep 14, 2013 | 03:01 AM
  #1397
MrMichael's Avatar
2005 Mazda RX8 Shinka
LS7, Midway 4spd Seqv, Camaro 2010 rear end
www.facebook.com/project.rise.se
Old Sep 25, 2013 | 10:42 AM
  #1398
swv5's Avatar
www.ls1rx8.com 2004 Mazda Rx8 ls1 swap
Old Sep 28, 2013 | 09:24 PM
  #1399
mg57's Avatar
Smile LS6/T56 57 Bel-Air
Just finished installing LS6/T56 from 05 CTS-V into my 57 Bel-air. Took out 350/700R4.
No engine mods - 400+ HP will get me into more than enough trouble
Ford 9" 3.70 posi, 4 wheel disc
Pypes stainless exhaust, 3/4 length ceramic headers, 1 7/8"tubes
DBW with re-worked caddy harness/computer
Custom driveshaft with slip yoke (no slip yoke on cts-v trans)
Dakota Digital VHX cluster
Old Oct 2, 2013 | 12:45 PM
  #1400
kevleetee's Avatar
1-1969 Camaro 2-00 Ls1 carb, M6, Z06 spec cam, victor jr intake, ford 9 wth 4.11 gears. Swap done on the Cheap!!
