s10 ls1ers
Old Jun 13, 2006 | 10:37 AM
  #501
firefighter's Avatar
I've been making some calls and doing some figuring, while dodging tropical storms. The larger axle tubes (3") should not be a problem it's just a matter of putting the right end on them the ends give you some versitilaty. So I'm working on it I am gonna have a major distraction here in a couple of weeks soon. My first kid is due. So things are gonna get back burnered for a lil bit. But I'm still gonna get it done.
Old Jun 14, 2006 | 02:16 PM
  #502
Hey does anybody know if a Maggie fits under the stock S-10 hood on top of a LSx?
Old Jun 14, 2006 | 02:42 PM
  #503
RedSpeck09's Avatar
i'm not sure. i want the new kenne bell for mine. never gonna happen though.
Old Jun 14, 2006 | 03:34 PM
  #504
Jake the SSnake's Avatar
Looks like it does http://www.s10forum.com/forum/showth...1+supercharger
Old Jun 14, 2006 | 04:22 PM
  #505
Bad4Point3SS's Avatar
Heres another one I found dont know if he post on here.
Its a 6.0 with the turbo from a duramax <---- thats what i was told
Old Jun 14, 2006 | 07:54 PM
  #506
Looks like the Maggies got a lot of room. That 6.0 wit tha turbo looks hot with the GTO covers.
Old Jun 16, 2006 | 10:20 PM
  #507
97noma's Avatar
yikes!
Old Jun 18, 2006 | 05:25 PM
  #508
s10-den's Avatar
do these trucks actually drive everyday ?anyone?
Old Jun 18, 2006 | 05:58 PM
  #509
I don't see why not. The one with the Maggie especially it is a pretty standard set up. Alot of people have tried to tell me I was crazy to want to put an LSx in a
S-10 but my Blazer. It has a wheel base 1/2 inch shorter than a 4th Gen Camaro although the track width is narrower but what ever to that also the Blazer weighs more than all of them (3800 lbs stock but mine is allready about 250 lbs lighter) it's got the right set up RWD and enough room for a V8 perfect if you ask me although I still wish I bought the Camaro SS.
Old Jun 19, 2006 | 11:34 PM
  #510
BluLS1's Avatar
would it be any harder or easier to do a cammed 5.3 swap into a 99 blazer.
Old Jun 20, 2006 | 07:17 AM
  #511
'JustDreamin''s Avatar
Harder or easier than what?
Old Jun 20, 2006 | 10:11 AM
  #512
RedSpeck09's Avatar
than an ls1? it would be the same really. its the same motor externally really, minus a few accessories and such. you're going to have to go through the same issues.
Old Jun 22, 2006 | 02:59 PM
  #513
TTT..... Hate to see this thing get to page 2 but I don't have anything important to add.
Old Jun 22, 2006 | 03:24 PM
  #514
bww3588's Avatar
page 2? dude were on page 26
Old Jun 22, 2006 | 05:42 PM
  #515
I'm talking about when you go to conversions you gotta go to the second page of threads.
Old Jun 23, 2006 | 01:23 AM
  #516
ok I gotta a question.
How about using the corvette oil pan? I heard its i guess not as deep and has fins to keep cool.
Old Jun 23, 2006 | 02:39 AM
  #517
XtremeDime's Avatar
the "batwing" i dont think it would work.
Old Jun 23, 2006 | 05:48 AM
  #518
AceHaag's Avatar
I found out that there are two different stock coil packs on the ls motors if you use the 19005218 coil packs you do not have to relocate the back coils on each side. I got lucky and scored a full set with the brackets for less than $35.
Old Jun 23, 2006 | 11:37 AM
  #519
I believe the Vette pan goes too far forward.
Old Jun 23, 2006 | 08:46 PM
  #520
Wades SnS's Avatar
the vette pan will not work unless you plan on moving your firewall back about 8" or so. It won't even start to fit. If you look in this thread I posted some stuff on fitment. I used all f-body stuff, even the oil pan but i also change to a rack and pinion so that I could run the alternator. Hope this helps. I just ordered stuff to build my 9" I'll post pics when I get it done. 2 10-bolts in less than 200 miles wasn't cutting it anymore
