s10 ls1ers
Old Sep 28, 2007 | 12:14 AM
  #1241
01WS6/tamu's Avatar
Ok next topic. How many kept their battery under the hood or moved it elsewhere. As much as I hate to move my battery it looks like that is the best spot for the air intake. The filter fits the battery tray perfectly. I am thinking about moving the battery to the bed in a stainless sealed box with bolts so it can't get jacked since I do not have a bed cover.
Old Sep 28, 2007 | 07:34 AM
  #1242
Jhankinson's Avatar
I moved mine...and YES the air filter fits SOOO nice in the battery tray. I would def move it to a box in the bed and route your intake over to the battery area. Mine works great. I am in the process of making a custom tube that goes over the a/c compressor and turns down into the battery area. But until then I have my tubing squished between the A/C and radiator getting HOTT!
Old Sep 28, 2007 | 08:48 PM
  #1243
almostfast's Avatar
Originally Posted by 01WS6/tamu
...How many kept their battery under the hood or moved it elsewhere...
Mine is still in the factory location... IAT is reaaaaly hot though... like 148* I will move it someday... when I put in a turbo...
Old Oct 8, 2007 | 06:38 PM
  #1244
BluLS1's Avatar
back to the pedal delima, does anyone have the automatic assembly for a 2000 blazer??? i NEED one,
Old Oct 8, 2007 | 06:54 PM
  #1245
01WS6/tamu's Avatar
Just grab the auto pedal from a local salvage yard. you do not have to change the aluminum main bracket. Just discard the clutch pedal, and manual trans brake pedal and then bolt in the auto pedal. It just has a through bolt at the top. If not I am sure some one here has gone from auto to t56 and may have changed the pedal asm out.
Old Oct 11, 2007 | 12:55 AM
  #1246
BluLS1's Avatar
what exactly do you mean bolt at the top? like where at?
from what i saw it looked like the clutch and man brake pedels had a tube that went through them which they hinged on but i could be wrong though cause i didn't look that hard.
Old Oct 11, 2007 | 04:41 PM
  #1247
PPI Typhoon's Avatar
Hey rollinphat4me, are those the F-body manifolds??
If so.......is there any chance for an experiment? I am curoius how the passenger side manifold fits on the driver's side.........backwards, so it's pointing forward and down.
Reason being is the fitting for my T76, but I don't want to spend the money and find that they don't work. Is there any chance you can swap those and take a pic for me?? If not, that's cool, but it looks like you're right at the right point of the conversion to check that. I'm wondering if there is a clearance issue with the steering shaft.
Or anyone for that matter....but I am running the AWD, so the 4x4 setup is where I'm curious. If anyone also has the Sanderson shorty headers........maybe a pic of that too?? The passenger side of that looks like it hugs the block rather well.
Thanks all.........I love this thread.
Old Oct 11, 2007 | 05:47 PM
  #1248
philntx's Avatar
On the driver's side, it would point right into the steering gearbox.
this should help:
This is an older pic, but it shows the relationship of the steering box. My truck is a 4x4 Autotrac.
Old Oct 11, 2007 | 05:57 PM
  #1249
BluLS1's Avatar
hmm must be nice to have that big o shiney blower like that
Old Oct 11, 2007 | 06:20 PM
  #1250
this should help:
Yeah, but enough to cut the end off and put a bend / v-band flange on? I'd really like to not have to make a driver's side from scratch if I dont' have to.
Thanks for the pics!
Old Oct 11, 2007 | 06:22 PM
  #1251
Oh.....and so you all don't think I'm just blowing sunshine up your skirts....
I am actually collecting parts. The UPS, FedEx and USPS guys were very nice to me all at once today:
Old Oct 23, 2007 | 05:41 PM
  #1252
almostfast's Avatar
not bad ^^^ but why did you put all that rusty stuff on your bed for pictures?
what oilpan is that??
Old Oct 23, 2007 | 08:23 PM
  #1253
Ls2Sonoma's Avatar
i believe its this one
http://www.turbotime.us/
Old Oct 24, 2007 | 08:05 AM
  #1254
'JustDreamin''s Avatar
Yeah, its Turbotime's pan...
'JustDreamin'
Old Oct 25, 2007 | 11:13 PM
  #1255
01WS6/tamu's Avatar
I will try and get some pictures of mine up here shortly. It is almost done bleeding me dry.
Old Nov 5, 2007 | 03:26 PM
  #1256
blazerls1's Avatar
I don't know if this is anywhere in this thread,But A Hummer H3 5.3 liter oilpan will clear the crossmember without cutting.I saw it on S-10forum.com,and they say it should clear a 2wd and 4wd.....
Old Nov 5, 2007 | 03:29 PM
  #1257
Bigdeezs's Avatar
I'd like to see a pic of this thing!
Old Nov 5, 2007 | 06:15 PM
  #1258
BluLS1's Avatar
yeah i would too!!! i thought the h3's came with the I5 like the colorado, at least thats what i was told.
Old Nov 5, 2007 | 08:49 PM
  #1259
philntx's Avatar
I stuck a pic of the pan here:
https://ls1tech.com/forums/showthrea...=409614&page=2
post #33
Here are a couple of pics of installed in a 2WD Truck (SPARKINAK)
No cutting on the crossmember!
Old Nov 5, 2007 | 11:31 PM
  #1260
BluLS1's Avatar
i wonder how this pan would work out on a blazer with the mount towers?
