s10 ls1ers
Old Feb 19, 2008 | 09:38 PM
  #1501
Horsepwraddict's Avatar
thanks guys, i'll give it a go.
Old Feb 19, 2008 | 09:39 PM
  #1502
RDTA's Avatar
if u decide to cut the middle of the frame all the way out. make sure weld braces to the frame. the frame likes to spread in the front. and also when u add the tube, make sure u use some gussets on the tube.
Old Feb 19, 2008 | 09:46 PM
  #1503
yea, ive seen it done a bunch of times to g-bodies. Do you have any pictues of yours?
Old Feb 19, 2008 | 09:52 PM
  #1504
RDTA's Avatar
before gussets.
Old Feb 19, 2008 | 11:04 PM
  #1505
Ls2Sonoma's Avatar
lift your cab up a few inchers
Old Feb 20, 2008 | 12:29 AM
  #1506
Bigdeezs's Avatar
Thats what I have to do when I pull the motor and trans in and out. Not really all that difficult.
Old Feb 20, 2008 | 07:04 AM
  #1507
i tried it real quick, my bolts are in their pretty damn good. Im gunna go yank em off this morning and try to drop it in again tonight.
Old Feb 20, 2008 | 07:46 AM
  #1508
just tried, driver side bolt came right out, passenger side just spins. Any ideas, now that i need new mounts and bolts too lol
Old Feb 20, 2008 | 08:27 PM
  #1509
cut a hole in the floor. their was a beehive in the box that was probably collecting water and rusting over time. I dug it out, welded the nut back to the box and the bolt came right out. Jacked it up and got the motor/tranny right in. I have to fix a small hole in the cab mount box and put new bushings in..i sort of wanted to do new bushings anyway though so its not that bad.
Old Feb 20, 2008 | 10:53 PM
  #1510
Ls2Sonoma's Avatar
glad you got it to fit!
Old Feb 20, 2008 | 10:57 PM
  #1511
RDTA's Avatar
sweet, glad u finally got it in there. btw i love the d/r on the front. lol
Old Feb 21, 2008 | 08:31 AM
  #1512
haha...ya, no rear end and i sold my front wheels. I was kind of out of options.
Old Feb 21, 2008 | 10:16 AM
  #1513
Frank02L's Avatar
We're trying to get a syclone guy to put them on all 4 corners on his ride.
Old Feb 22, 2008 | 11:03 AM
  #1514
lt1s10's Avatar
Just joined s10dragracer.com . Looks to be alot great info on that site. Not too much into the fuel injected stuff, but lots of suspension and set up help!
Old Feb 23, 2008 | 08:23 PM
  #1515
NaturalMystic831's Avatar
I'm looking to buy some headers for my rig. I was thinking of going with the JBA GTO LS1 shorty headers to keep it smog legal. The tubes are supposed to be 1 5/8". Anybody have any experience fitting similar headers in an S10? Worse comes to worse I can have a guy in town cut, re-weld flanges, etc to make them fit.
Old Feb 23, 2008 | 09:55 PM
  #1516
rdrage728's Avatar
Thumbs up i found the right oil pan for the swap
just got done mocking everything up and my 08 hummer H3 oil pan clears with no cutting but whent ahead and cut a 1/2 deep and 8 inch across just to be safe. The bottom of the oil pan is level with the bottom of the crossmember too, its almost like it was made for this swap and at just under $200 you can't beat it
Old Feb 24, 2008 | 10:02 AM
  #1517
black2002ls's Avatar
pictures and details? A lot of guys are having problems with this pan hanging below the crossmember. Do you have the front clip on the truck? Does it look like the hood is going to clear?
Old Feb 24, 2008 | 11:19 AM
  #1518
Frank02L's Avatar
Thats how the Fbody pan fits in ours (height wise) It may be slightly lower than the crossmember. But it did require the notching of the crossmember.
Old Feb 24, 2008 | 03:28 PM
  #1519
ls1blazer's Avatar
The h3 pan fits extremely close,almost touches. I just raise the trans up 1" with an aluminum spacer for additional clearence.
Old Feb 24, 2008 | 10:15 PM
  #1520
drwoowoowoo's Avatar
New owner of a LS1 s10. Its an 89 with 2000ls1 LTs t56 and a cal-trac'd 9in 3.55. Took her to the track today. Made like 20 passes in it. I could only best a 8.33
With a 28x10 hoosier leaving at 2500 she would only do a 2.0 60ft
Gonna take the 3rd member out and put a mini spool and some 4.11s. The stock p-trac crapped out on me by the end of the day
Ill take some more detailed pics later on
