LQ4 into a 3rd Gen/1972 Nova
Old 01-02-2013, 05:58 PM
  #1161
frojoe's Avatar
He had the triple adjustable Ridetech coils in the front, 550lb springs, and single adjustable Ridetech coilovers in the rear, 200lb springs.
Standard Speedtech subframe, hi-clearance control arms, torque arm rear suspension.
Old 01-02-2013, 06:31 PM
  #1162
frojoe's Avatar
Thought about starting the DSE minitub install today. Got as far as unwrapping the tubs, haha. They're very nice pieces. It goes to show you the level of quality of a company like DSE, when they'll go ahead and open the [large & expensive] steel stamping tooling that would allow their product to be that much closer to OEM-quality...
I didn't feel like cutting, so instead moved onto the front suspension. Before I start jigging together some new tie-rod/steering-arm bumpsteer setup, I need to measure what my bump steer is currently.
Before I can do that, I need to mockup the new Ridetech coilovers to figure where my max bump (bottom out) and ride height are, as they have 1.25" less stroke than the QA1's they replacing, however have a longer overall body (new 3.625" shock travel vs. QA's 4.875" shock travel, also FYI the leverage ratio of a stock arm is ~ 16:9 or 1.78" of wheel travel to 1" of shock travel).
Lower bearing eyelet as measured from where stud bushing would be contacting the shock support on the subframe..
The QA1's had a standard rubber bushing/stud arrangement like a stock shock or sway bar end, but the Ridetechs have this neat spherical plastic 2-piece setup..
Mocked in there..
At full compression, the control arm has about another 0.75" at the shock that it could compress before the LCA's bump stop is even contacted, as well as the rim lip is just barely tucked at current full compression.
The tall upper aluminum spacer (as seen in the disassembly pic) can be purchased in a lower height to reduce the stud-bushing-to-lower-bearing length, without reducing stroke, however since the supper coil perch would be raised relative to the shock mounting point on the subframe, I'd have to cut out the stock spring perch on the subframe to gain clearance for the Ridetech's coil to partially pass thru the subframe, and I think too much cutting would need to happen and it would compromise the upper perch's strength. Plus I just don't want to have to cut a lot on the frame, too awkward and messy.
What I plan to do is switch the trunion-style lower shock mount over to a double shear bolt setup, so I'll grind out some clearance on the LCA to allow the coil body to pass thru, and then weld on two L-tabs on the bottom side of the LCA's spring pocket, at a lower height to lower the front a bit.
Attached Thumbnails LQ4 into a 3rd Gen/1972 Nova-1.jpg   LQ4 into a 3rd Gen/1972 Nova-2.jpg   LQ4 into a 3rd Gen/1972 Nova-3.jpg   LQ4 into a 3rd Gen/1972 Nova-4.jpg   LQ4 into a 3rd Gen/1972 Nova-5.jpg
LQ4 into a 3rd Gen/1972 Nova-qa1-1.jpg   LQ4 into a 3rd Gen/1972 Nova-qa1-2.jpg   LQ4 into a 3rd Gen/1972 Nova-ridetech-1.jpg   LQ4 into a 3rd Gen/1972 Nova-ridetech-2.jpg
Old 01-08-2013, 11:48 PM
  #1163
frojoe's Avatar
Not a car update but thought I'd share a side project I've been tinkering with over the holidays. I like drinking beer. And shifting gears. Why not combine the two (legally)? Besides, prettymuch none of my friends know what the inside of a trans looks like.
Old 01-09-2013, 01:13 PM
  #1164
frojoe's Avatar
Also, was cleaning out the pictures on my phone and found this.. you guys have these down in the states??
Attached Thumbnails LQ4 into a 3rd Gen/1972 Nova-0723012004.jpg
Old 01-09-2013, 02:38 PM
  #1165
-TheBandit-'s Avatar
Man those Ride Tech shocks looks niiiiiice. I may need to rethink my setup. Do those use the upper spring pocket & 4" (or is it 4.5") springs?
I like what you did with the tranny but you have way too much time on your hands now that the car is running.
Old 01-09-2013, 02:49 PM
  #1166
frojoe's Avatar
Too much time on my hands.. haha. Guess that's why I got this?
Attached Thumbnails LQ4 into a 3rd Gen/1972 Nova-0105031529.jpg
Old 01-09-2013, 03:38 PM
  #1167
That will make for a great TT LS swap.
Old 01-09-2013, 04:07 PM
  #1168
tsnow678's Avatar
******* cops, yeah we have cops too many to be exact. Lol I know you were talking about the S/C 5.4, I haven't seen any in North Carolina. Most of our State Troopers are riding around in AWD V8 Dodge Chargers. I usually only see the Crown Vics locally. Next time I swing by the doughnut shop I will take a look for the S/C badging. I thought you guys cops rode horses, weird!
Old 01-09-2013, 04:12 PM
  #1169
tsnow678's Avatar
Badass shocks for sure! I like the bike, I had a Yamaha 400 Special many moons back. I had a 1973 Suzuki GT 185 two stroke as well. It even had disc brakes up front. Pinned it would only run 81mph. Of course my bicycle had wider tires so 81 was fast enough. I say swap out a modern engine off of say an FZR and turbo it. Make a cafe' out of her.
Old 01-09-2013, 05:04 PM
  #1170
frojoe's Avatar
I had no idea that they even crammed that S/C 5.4L into those Crown Vics.. even for a heavy fullframe car that thing must go well on the highway..
I'm not going to go full cafe racer on it, not sure I like that hipster style. I'm going to go for more of an upright scrambler/brat/bobber style. I have still yet to find a single build of any-make twin that captures what I have in my head, but elements of these are along the lines of what I'm going for...
Old 01-09-2013, 06:09 PM
  #1171
tsnow678's Avatar
With the treaded tires it appears to be more on the enduro style. Sort of militarian. You going for the jockey shifter? Get an Army helmet, paint the bike OD green and build a side car!
Old 01-09-2013, 06:13 PM
  #1172
tsnow678's Avatar
I like the Salt Flats Yamaha but the naked steel frame of the Kawasuki.
Old 01-10-2013, 10:50 AM
  #1173
hookemdevils22's Avatar
I like the cafe look. Sadly, the old lady said I couldn't have a bike until I get the damn student loans paid off.
Found a couple helmets that would be perfect (sadly, not snell rated, otherwise I'd have one):
Diesel Mowie
Diesel Hi-Jack
I rather prefer the Mowie. Also, I'm a huge fan of triumphs (the bikes, not the cars). A TR6R would be juuuuust about perfect, though that bonneville you posted is quite sexy.
Last edited by hookemdevils22; 01-18-2013 at 10:15 AM. Reason: make Hi-Jack pic smaller
Old 01-10-2013, 10:59 AM
  #1174
frojoe's Avatar
Wow you guys are really hammering away at the military look eh? Haha. I kindof like that Hi-Jack helmet actually, but in all reality I'll probably just get a regular matte black or plain whatever Shoei or HJC fullface. I need to go helmet shopping to fits my oddly-large noggin.
Old 01-18-2013, 12:20 AM
  #1175
frojoe's Avatar
Mmmmmmm... grippppp....
Old 01-18-2013, 10:14 AM
  #1176
size??? and are you having the rims widened in the rear?
Old 01-18-2013, 12:15 PM
  #1177
Full face is so much better than having your jaw ripped off. I'll admit that "hijack" helmet looks sweet. The Diesel Mowie reminds me of Spaceballs.
Old 01-18-2013, 05:16 PM
  #1178
frojoe's Avatar
Those are 305/35/18 Nitto 555R's, 100 treadwear. My current 275/40/18 are going on the front. I'm going to have a local place that specializes in alloy rim widening & repair widen the wheels to 9.5" front and 11" rear. 11" rear will be good for these sticky 305's, or 315's in a more normal 200+ treadwear if I ever choose to have a higher wear rating..
Old 01-18-2013, 08:39 PM
  #1179
gjestico's Avatar
555R Drag Radials ? How well do those work when you want to take a corner fast ?
Old 01-19-2013, 09:27 AM
  #1180
LS1NOVA's Avatar
They work really well. Had them on the back of my Nova autoXing. Sticky and the sidewall wasnt an issue. Prob would want them on the front though.
Cant wait to see it with some more rubber!
Quick Reply: LQ4 into a 3rd Gen/1972 Nova
