Fireball Outlaw Drag Radial Rebuild Thread
Old 12-17-2009, 02:22 PM
  #221
Restricted User
98Z28CobraKiller's Avatar
Any reason that you couldn't go down and forward with the headers in order to get better plug access from the top? Looks great!
98Z28CobraKiller is offline
Old 12-19-2009, 01:41 AM
  #222
Super Moderator
Reckless's Avatar
Originally Posted by Fireball
haven't had time to work on it...been busy at work
Take vacation man! WTF is wrong with you!
Reckless is offline
Old 12-19-2009, 08:03 AM
  #223
Fireball's Avatar
well...plug wires stay cool with this design...that goes a long way. Driver side is super easy to get to...just reach up from bottom. PS was pretty easy too...remove one v-band clamp, drop downpipe section and they were right there...
Fireball is offline
Old 12-22-2009, 04:22 PM
  #224
Fireball's Avatar
cut out the secondary door bars (they were 1.25" which 25.5 called for, but need to be 1.5" for 25.3)
Got the driver side rebuilt with the 1.5" tubing and added the two 1" gussets up front as required by 25.3
need to reinstall a kidney bar (cut it out to make installing new bars easier) and then do the passenger side....those welds are a major PITA to do
Fireball is offline
Old 12-22-2009, 04:43 PM
  #225
mikep2002's Avatar
You crack me up!!!!! Looks good overthere...
mikep2002 is offline
Old 12-22-2009, 04:46 PM
  #226
stangeater01's Avatar
hows my intercooler treating you?
stangeater01 is offline
Old 12-22-2009, 08:09 PM
  #227
Fireball's Avatar
sitting in a corner..gonna be quite some time until I get to the cold side plumbing
Fireball is offline
Old 12-22-2009, 08:26 PM
  #228
Shawn @ VA Speed's Avatar
looks good Brian-keep up the good work,just remember-when in doubt,cut it out.lightweight is our friend
Shawn @ VA Speed is offline
Old 12-23-2009, 06:49 AM
  #229
yea yours is doing the same collecting dust it does make a good paper weight though lol
Old 12-23-2009, 01:56 PM
  #230
Fireball's Avatar
reinstalled the kidney bar and got the passenger side about done....need to learn how to become a contortionist so I can weld 100% around some of those bars
Fireball is offline
Old 12-23-2009, 05:00 PM
  #231
Josh@KY-Turbo's Avatar
I know what ya mean there. I have had the best luck setting the TIG up with a good Pulse setting and the Max amperage I would need then using a simple Torch with a non adjustable on / off switch. No worrie swith a foot pedal or thumb control then.
Looks really good so far as always. I just go the Pricing in for the Southern Outlaw 25.2 Cage kits. Has me thinking of going ahead and doing my 99 SS up.
Josh@KY-Turbo is offline
Old 12-23-2009, 05:40 PM
  #232
Fireball's Avatar
I've been playing with my thumb wheel control...hard to get used to...thats for sure
Fireball is offline
Old 12-28-2009, 09:04 AM
  #233
7 Second Club
ty_ty13's Avatar
the pedal is the only way to go for me... you can always find a creative way to control it.... usually between my legs....lol
ty_ty13 is offline
Old 12-28-2009, 09:15 AM
  #234
Boosted One's Avatar
hmm... You must be in good shape!
Sorry, I had too! lol
Boosted One is offline
Old 12-30-2009, 02:49 PM
  #235
Fireball's Avatar
worked on it a few more hours today...
got the old 25.5 roof diagonal cut out and fit up the 25.3 roof "X"
still need to fit and weld in the 6 required roof gussets
Fireball is offline
Old 12-30-2009, 03:34 PM
  #236
Race your car!
JL ws-6's Avatar
Damn they want gussets everywhere on that thing. 6, that's every side but the halo. I'm almost surprised they didn't want them in the middle of the x too
25.3, that's a serious spec, and surly makes for a safe car. Pita to build and get in and out of too.... the interior cubic feet is drasticially being reduced, one tube at a time!
JL ws-6 is offline
Old 12-30-2009, 04:20 PM
  #237
Fireball's Avatar
2 on each corner (every corner except for where it meets the F/C cage)...
entry and exit is identical to a 25.5 cage...only real difference is the secondary door diagonal is a hair larger in diameter
Fireball is offline
Old 12-31-2009, 04:36 PM
  #238
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Pull a Phil and cut the roof off. That'll make it easy....
Beaflag VonRathburg is offline
Old 01-01-2010, 08:50 AM
  #239
Fireball's Avatar
I have ttops....that helps a bunch
Fireball is offline
Old 01-01-2010, 01:08 PM
  #240
SanitysBane's Avatar
How are you securing the t-tops? Looks a little different than factory.
SanitysBane is offline
Quick Reply: Fireball Outlaw Drag Radial Rebuild Thread
