Fireball Outlaw Drag Radial Rebuild Thread
#621
OWN3D BY MY PROF!
You're light years ahead of me on working on the car. I'm still trying to figure out all the details. My rear is narrowed 5.5 per side, has narrower LCA and PHR mounts. I'm planning on the 315/60/15s also on a 15x12 4 / possibly 3.5 BS. How much is your rear end narrowd and what BS are you running? I'm trying to figure out how much you've moved the tires in from a relatively stock width.
#622
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
#623
99% finished with the rear housing...ran out argon so I still have to weld on one brake line tab...but its painted with exception for a small area so I can weld that tab on the back of the passenger LCA bracket.
![](http://home.comcast.net/~tfranklin5580/finished_rear_1.jpg)
Just need to install my 3.40 gearset in the 3rd member and once I do that and my axles arrive...I'll final assemble the rear end.
#627
7 Second Club
#628
I did weld on the brake tab last night...cleaned up the area and painted that spot.
#633
hey man sorry for asking you this questions but i realy need 1 of this... 24-tooth external crank wheel and grounded sensor you have in your engine, where exactly did you get this parts ive been looking for them but i havent find any... same as your thanks.
#634
the wheel and sensor are made by BS3. Can order from any BS3 vendor. Va
Speed made the mount for the sensor for me that bolts where the alternator went.
#635
Race your car!
Car looks great Brian. Wanna do mine ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Seriously, for a guy that's not a chassis fab person by trade, you've done a hell of a job on the whole thing. That's a serious undertaking that you've done, and it's come out great. Makes me want to buy a welder and just start cutting
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
#636
Seriously, for a guy that's not a chassis fab person by trade, you've done a hell of a job on the whole thing. That's a serious undertaking that you've done, and it's come out great. Makes me want to buy a welder and just start cutting![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
you'll be surprised at how quick you learn...
well...I suppose I'll be tackling how to mount the hood this weekend... I need to get that on for good so I can figure out mounts for the headlight covers and other front-end parts.
#639
Race your car!
Believe me, I'm starting to think about it. I need to talk to DMH, see what he can come up with for a price, then go from there. Some of the stuff I'm gonna try to do anyway, the cutting portion, I just need to talk to him first about what not to cut out, for the rigidity of the chassis while bringing it there, that sort of thing. All small details.
If I can get a welder though... I'll see what I can do about borrowing a tubing bender (know someone with one), and I'll buy a notcher, and a benchtop sander to prep tubing up, and start trying to do some stuff on the table. If that goes well.... then I may give it a shot.
Maybe I can get lucky and find someone in CT that's got a hack project that they'r trying to throw together on the WAY cheap and learn with that... that would be great. Just charge for material and supplies, and make no promise that it will look good![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Wish you were closer, be nice to have someone to give good direction to the process... biggest thing I don't really feel comfortable with, is where to start.
