Fireball Outlaw Drag Radial Rebuild Thread
#1283
Wow with friends like that who needs enemies! There's nothing like a "friend" to kick you in the junk right after something like that happens. Chill out dude. There's no reason to be an *** about his misfortunes. You wouldn't like it if someone was riding your butt after you melted down your all billet block, billet intake, custom one off turbo build on the first run. There is such a thing as karma and it sucks when it comes around.
#1284
For those of you who want to see something sad
pics of the rhs block damage
its still fixable though...good thing this wasn't an iron block or it would be scrap...at least aluminum blocks can be welded up.
#1288
I assume it would be a PITA to weld the inside of a block back up as all the welds would have to be perfectly milled down to the original specs b4 the "explosion"?
I like that second pic showing the liner just hangin in the wind... must be tough with no block around it. That thing would prob be done for good if it was a stock block, no?
#1291
staying bs3...just need to be a hawk in the tables and not let it bite me again in the ***
we collectively have alot of tuneup data for BS3. Which comes in handy when you want to share information...
#1292
some minor updates...
Repainted the damaged hood while I painted the golf cart...stupid wind
painted the exhaust pipes coming through the fenders with a high temp black paint...also had to clearance some for the front tires, they were rubbing when the wheels were turned...
set up the EGT system to kill the ignition if any of the egts get too far out of line...this should help prevent serious carnage in the future.
Also, made some modifications to the turbo oil return to help the scavenge pump work better. it was pulling a vacuum on the turbo and then not pulling sufficient oil back to the pan causing oil to get into the compressor and turbine housings I added a vent system to prevent this from happening
All I need now is a bullet
#1293
https://ls1tech.com/forums/parts-cla...-sale-new.html
If he really takes $12K this seems right up your alley for a new bullet
#1299
Race your car!
