Procharger guys
Have been a 6.10 @112mph on 12lbs boost with the TH400 at 3750lbs raceweight.
Went 10.63 @125mph on 6lbs boost with the 4l80e at over 3800lbs. Getting the belt slip issue fixed soon
so i just got done w/ my build and got it tuned, still got a lil ways to go (need a single intercooler setup) but i put down some ok numbers for now
/rant
/rant
* Cubic inch. The larger the engine the less boost it will make with a supercharger.
* Headers and exhaust. A better flowing system will produce less boost, requires a smaller pulley to regain the loss in boost. Ultimately though, more power will be gained.
* Camshaft and heads. A camshaft with some overlap will leak out some boost through the valves. Better flowing heads react a lot like a better flowing exhaust system.
* Altitude. Elevation plays a big part in how much boost is produced. Those people living in the higher elevations have to spin the blower harder to see boost.
* Condition of engine. An engine with real good sealing rings will ultimately produce more boost than one with worn rings.
* Rpm. An engine that is spun up higher in the rpm range will normally produce more boost.
I recommend raising your intended boost up to 7 psi. 5 psi would hardly make it worthwhile installing the ProCharger, and you wouldn't feel the boost come in until 3500 to 4000 rpm in the power band. Bob
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
anybody with just a brether have any issues with oil blowing every where??
and also i currently only have the procharger supplied fan, havent installed it yet, but is this thing no good? should i just sell it and buy the spal?
The ProCharger fan works just fine until you are stuck in heavy traffic in the Summer on a hot day, and you have the a/c on. If you encounter situations such as this, then you may want to go with the Spal fan. Bob
i might be able to get by with the supplied fan i dont drive the car much and rarely am in traffic around here
What head unit? F2? F1-X? This is the truck you shot the video of with the water blowing out of the overflow bottle? Anymore videos?
-Coleman
Here is a compilation vid from that day, its a bad *** vid:
The vid of it pushing the crazy water was on 24 psi.
24psi with an F2 is a lot of air for a small block!
