Edit: Brute speed procharger in my future
more here
And here are several good threads full of info, pics, write ups, installs and issues with maggies on fbodys.
https://ls1tech.com/forums/forced-in...-fi-route.html
https://ls1tech.com/forums/forced-in...d-adapter.html
https://ls1tech.com/forums/forced-in...s1-f-body.html
https://ls1tech.com/forums/forced-in...y-tvs2300.html
https://ls1tech.com/forums/forced-in...er-owners.html
https://ls1tech.com/forums/forced-in...ail-order.html
https://ls1tech.com/forums/forced-in...ification.html
https://ls1tech.com/forums/forced-in...all-my-ss.html
As far as running out of fuel at WOT the engine goes lean, creates detonation and a piston or pistons siezes. At that point the rod or rods let go and exit through the side of the block.
It's usually just the pump that goes out. By all means do the upgrade with racetronix for piece of mind. I was only mentioning the magnavolt incase you weren't aware the kit is supposed to come with one.
As far as belt issues are concerned the kit comes with a 3.4" or 3.1" pulley depending on who spec'd it. I run the smallest one possible which is a 2.5". My car makes 11.4lbs of boost on stock heads and cam. 463hp 546tq. It runs the same 6 rib pulley system as the factory belt. The kit does come with a crank pin kit (which I doubt you would spin if the motor failed). Belt slip has been an issue in the past, I only run the gator back belts. You can use the factory tensioner but I went with a manual one from Katech. I have heard the ls3 tensioner is better than the ls1 but I dont have any proof. The manual one works just fine for me.
If your expectations are only around 100 hp gain I personally dont see belt slip or fueling issues being much of a concern.
Good luck with it. Mine is a blast to drive on the street.
That was the worst part. Everyone I had talked to said there was no hood cutting at all. It made me sick. But the cut is barely noticeable and there are no issues with hood flexing, cracking, etc. MTI is absolutely worthless, I dont recommend that anyone do business with them ever. You will also notice that their members are all banned from this site.... That seems to speak volumes to me.
http://www.youtube.com/watch?v=eYZZL...ure=plpp_video
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
