Ls1 Carb/distributor
Old Aug 11, 2006 | 10:10 PM
crvttguy76's Avatar
Default Ls1 Carb/distributor
i have a 98 ls1 engine that i have been wanting to put into an older vehicle, i will be going with a carb conversion. i see that gmpp has come out with a new front timing cover that allows the use of a distributor and a mechanical fuel pump. i am wondering if anybody has used this setup, and is there a waterpump out there that will clearance this new cover? also what distributor and fuel pump will work with this? i can't seem to find much info on this setup. any help is appreciated. i have thought about using the msd timing module, but i like the idea of being able to tune my engine the old fashion way. thanks
Old Aug 12, 2006 | 12:05 PM
86 IROC's Avatar
I'm in the same boat as you, VERY limited info on this set up. I did however see several cars using it on the Power Tour this year. Mostly on cars at the Year One booth, I'm considering giving them a call to see if they can point me in the right direction. I was told the distributor they use is sourced from a ford 351W.
Old Aug 14, 2006 | 08:43 PM
crvttguy76's Avatar
thanks for the info, i did read the article in hi performance chevy, about this setup, but still not much info on parts availability. my main concern is that darn waterpump, there is just no way the stock one will clear. i work at a chevy dealership, and i can get the parts at cost, but there is no listing yet. hopefully soon though!
Old Aug 14, 2006 | 09:04 PM
Mke Vee's Avatar
Why use the dissy when you can get the MSD box that drived the stock coils?
It is prollt cheaper too. MV
Old Aug 15, 2006 | 03:37 AM
WILWAXU's Avatar
Here's some reading for you:
https://ls1tech.com/forums/generation-iii-external-engine/105407-carb-intakes-ls1-s.html
https://ls1tech.com/forums/generation-iii-external-engine/112195-new-edelbrock-ls1-intake.html
https://ls1tech.com/forums/generation-iii-external-engine/148639-new-carb-ls1-setup-made-40-hp-over-ls6.html <<results
https://ls1tech.com/forums/generation-iii-external-engine/158658-gmpp-ls1-intake-availbility-update.html
https://ls1tech.com/forums/generation-iii-external-engine/168311-war-intake-accel-teaser-pictures.html
https://ls1tech.com/forums/generation-iii-external-engine/173568-more-war-gmpp-intake-pictures-big-pictures.html
https://ls1tech.com/forums/generation-iii-external-engine/198601-gmpp-singleplane-tested-new-popular-hotrodding-mag.html
https://ls1tech.com/forums/generation-iii-external-engine/267311-carb-ls1-intake-converted-efi.html <<pictures
https://ls1tech.com/forums/generation-iii-external-engine/305750-why-more-people-not-running-gmpp-intake.html <<pictures
https://ls1tech.com/forums/dynamometer-results-comparisons/311005-spm-hptuners-dyno-results.html <<dyno results
https://ls1tech.com/forums/generation-iii-external-engine/314549-carbed-intake-converted-f-i.html
https://ls1tech.com/forums/generation-iii-external-engine/320023-gmpp-carb-efi-conversion.html
https://ls1tech.com/forums/forced-induction/327044-new-intake-arrives.html
https://ls1tech.com/forums/generation-iii-external-engine/334178-who-do-machining-gmpp-single-plane-manifold.html
https://ls1tech.com/forums/generation-iii-external-engine/354540-vic-jr-intake-ls1.html
https://ls1tech.com/forums/generation-iii-external-engine/379735-edelbrock-victor-jr-intake-pics-specs.html <<pictures
https://ls1tech.com/forums/generation-iii-external-engine/381677-various-single-plane-intake-pics-big-pics.html <<pictures
https://ls1tech.com/forums/generation-iii-external-engine/392724-putting-carb-ls1.html <<Lots of Pix
https://ls1tech.com/forums/generation-iii-external-engine/414468-gmpp-intake-vs-edelbrok-victor-jr-ls1.html
https://ls1tech.com/forums/drag-racing-tech/425512-search-down-what-edelbrock-victor-jr-worth-over-fast-90-90-a.html
https://ls1tech.com/forums/generation-iii-external-engine/449835-any-ls1-carb-engines-out-there.html
https://ls1tech.com/forums/generation-iii-external-engine/460478-my-vic-jr-conversion-pics-thoughts.html
https://ls1tech.com/forums/generation-iii-external-engine/463438-msd-wire.html
http://www.edelbrock.com/automotive_...ds_chevy.shtml
Old Aug 15, 2006 | 06:47 PM
TJ's Avatar
TJ
i put an lsx motor in to get rid of a dist, no reason to backtrack technology.
edelbrock and MSD both have their versions to fire the stock coils.
Old Aug 3, 2009 | 01:50 PM
Ls1Mx-5's Avatar
Any success with set ups like the msd 6010?
Old Aug 4, 2009 | 08:36 PM
TJ's Avatar
TJ
ive been 6900 rpms with it on a 6.0 and nitrous 6.50's 1/8 mile.
now have it on a 7500 rpm stroker running 6.30's 1/8 mile on motor.
never had an ounce of trouble out of it, but have heard stories of people having issues.
Old Aug 8, 2009 | 09:46 PM
Ls1Mx-5's Avatar
Glad it works for you. What type of issues? Can it run an EFI without a pcm?
Old Aug 8, 2009 | 10:10 PM
Notmyvette's Avatar
Horsepower tv actually just did this conversion and was on this morning...should be on tomorrow morning since I always see the same episode the next morning...
and from what I remember them saying the dizzy is from a ford 302
Old Aug 8, 2009 | 10:22 PM
TJ's Avatar
TJ
something to do with the coil drivers. i dont think anyone or even msd knows how many is in the box. LOL. with high rpm, it breaks up.
also, even more so on a new motor, the box has to see 150 cranking rpm or the box will not fire.
i had 2 batteries on my 408 to get it fired over the 1st couple times. after a heat cycle, it fires up on the 1st hit.
buddies 6.0 rebuild did the same thing. voltage is very important.
it wont work as a standalone. it only sends spark. no fuel.
youll need the stock pcm for fueling, or some other type of aftermarket setup.
for 300 bucks, it does a good job, IMO.
Old Aug 8, 2009 | 10:24 PM
Ls1Mx-5's Avatar
Thanks, but it will stand alone with a carb right?
Old Aug 9, 2009 | 09:48 AM
TJ's Avatar
TJ
yes sir. you wont have a bit of trouble getting it all hooked up.
only 3 wires that actually require labor.
PWR
GRD
IGN
everything else is clearly labeled and plugs right in to the factory sensors.
Old Aug 9, 2009 | 12:33 PM
Ls1Mx-5's Avatar
PWR
GRD
IGN
Thanks allot, thats why I love msd, and carb set ups
Old Aug 9, 2009 | 12:49 PM
hammrman31's Avatar
Just saw that episode. Very interesting!
Old Aug 9, 2009 | 03:33 PM
zamora7's Avatar
I've seen that episode this morning, too. Can't remember what carb and intake it was, but they used a double roller timing chain, meziere electric water pump, and some spacers for the water pump so that it would clear the cover. And the distributor was a msd for a ford 302. Pretty interesting set up I think, made real good power on their dyno, too much work to do IMO, I would just keep it with the coils. I also remember them saying that the fuel pump was too much for the carb and would cause overflow or something, but great set up anyway.
Old Aug 9, 2009 | 07:44 PM
deadmanTA's Avatar
It was a GMPP intake and holley 750 carb.
