Another Hall's deal!!!
#4263
I took a co-worker for a ride last night and the nitrous wouldn't activate. It worked fine on the "fuel leak" night, but last night was the first time I've tried it after the new Hobbs. I put the jumper back on and will try it again tomorrow. Mike @ Preferred tested it and double checked the wiring part of it when he did my alignment Monday, so I'm a little confused. He was like, "Damn, this car get's it." I told him that was only NA and he just shook his head. Kinda funny.
#4265
Luke,
The bolt pattern is the same as a Mustang (5x115mm) but the wheel width is important, I can only fit 7.5-8" of wheel and 225 width tires under the fenders, and I'm LOW, so I can't have any that stick out up top.
Scott,
Is the hobbs set right? They're usually adjustable for what pressure they shut down at, if that's wrong, it would stop it from activating. Usually you start the car, and put a continuity tester on it, and adjust it until it's closed + x amount of turns at normal fuel pressure.
Scott,
#4266
Ha, I was doing this also back in the spring. I made one of my own that was a bit shy of all the way open and it brought the sound down pretty good. Don't even really hear it in the car. I have the total block off plate if you want to use that to make your own. I tried the total block off one once, just to see what it sounded like, and it was awful lol.
Chris how much do you want for it?? I bought one from a guy here on tech and lets just say it wasn't what I expected. Brings new meaning to" home made" that's for sure. Let me know
Thanks
Darren
#4272
Hey, what the hell , how did you include me in this pal.... I want you to know that my extra coat didn't come easy and Im kinds sensitive about it ... Thats alot of extra cheese, and beer to get this hott.... If you recall Luke's Sister thought I was Cute.. Not you
#4274
How much do I want for it? Nothing! I don't need it and it's just laying here. If you want it soon, just come and get it, otherwise I will try to get it to you at Hall's. Just not sure when exactly I'll be up there.
#4277
yeah that's true...she probly couldn't handle the baller-status of the vette so she went for that f-body
