Another Hall's deal!!!
Training days are long and painfull at times with the amount of study and hard work needed just to get by, but the flying is awesome, and if all continues to go well, I'll get my wings at the end of April.
Nitto finally released their new NT05r drag radial. I'm hoping it's a nice compromise between the stickyness of the ET Street radials and the tread life of the 555r.
http://www.nittotire.com/#index%2Etire%2Ent05r
I'm gonna have to get a price quote on a set of 285/40-18s this week
1. There Nittos
2. Theres NO sidewall
3. You have to run to much air pressure in them
4. They are a roll race tire if anything
5. They will be on back order forever
6. They will never go on your car
7. You will never drive your car
8. You will never race your car
9. They cost to much money
10. They are overpriced, m/t copying, no sidewall having, roll racing bs, pos tires!!!
Ya I agree with Joe, Nittos suck. Thats the last tire I would consider if I had your power level, Nick. Your not going use the RX-7 for a daily are you?
I thought about you on Friday. I flew my friends dad's 2005 Beechcraft Bonanza for about half an hour on the way to Knoxville, TN.
Top 10 reasons why these tires won't work?
1. They're Nittos Paging Dr. Obvious
2. There's NO sidewall I can't fit any sidewall
3. You have to run to much air pressure in them Better MPG
4. They are a roll race tire if anything You say that like it's a bad thing
5. They will be on back order forever http://www.youtube.com/watch?v=5sMKX22BHeE
6. They will never go on your car Technically they'll be going on my rims, that will be going on my car
7. You will never drive your car Hello pot, it's kettle
8. You will never race your car Racing is dangerous
9. They cost to much money Sponsorships FTW
10. They are overpriced, m/t copying, no sidewall having, roll racing bs, pos tires!!! ECHOECHOechoecho
Yessir, it's going to be my daily
^ I flew a low level (500 ft) flight near Chatanooga on Thursday (small world).
Unfortunatly that won't be the end of my training. That will just be the end of my initial pilot training where I will get my wings and officially become an Air Force Pilot. From there I will get 3 weeks off and then start training in Oklahoma where I will learn to fly the KC-135 I will fly back in Indiana at Grissom. I'll finish up in Oklahoma sometime in October, then I'll be back home for good (until I leave on missions and deployments).
That's a Dana out of a C4 Vette that is getting swapped into my RX7. It was cut/narrowed to fit by me, and Matt's Dad did some beautiful welding/filling to make it look like you see here. The additional metal is to tie it together where it was cut.
Thanks for the pics sir, I took some, but I've been slacking at getting them online.
Anybody know what the Fuel Psi should be on a 92 park avenue non S.C.? Need some ideas where to check to get this car running right.
symptoms- Runs great for about 10 minutes, then acts like its not getting fuel, or timing is off. Car will act like it wants to start but then will not. If car sets for a few hours it will fire right up.
Sidenote- I've ran this car really low on fuel about 100 times since i've owned it. Usually it bogs down when going around corners. Fuel gauge is off by 1/4 tank. I'm sure that didn't help prolong the life of the fuel pump.
Parts that are new=
ignition module- burned out 2 cylinders last fall.
"magnavox" coil assembly- pulled out terminals when replacing plug wires last week.
Plug wires- chipmunk decided to chew through plug wires and leave left hot side of wiring laying on Alternator.
Alternator- Due to chipmunk chewing on plug wires and arcing through alternator.
Fuel filter- replaced last LOF.
Parts that are new=
2800/3100/3400/3500 motors have no relationship to the vastly less shitty 3800s.
Luke. PSI should be around 42-45, but as long as it's around 40 you should be fine.
Cam sensor will not stop the engine from running. I've seen them started and driven without them. Crank sensor will 100% stop it from starting though. Typically the sensor is fine, but the harness gets damaged.
I know on the supercharged SII 3800 motors (and I believe the N/A SII) the harness for the crank sensor runs through a plastic routing deal that circles the top of the crank pulley and is a MAJOR PITA to reach. That's worth checking. Do you have access to a scanner (or does the car have a tach)? If the RPMs move when you crank (assuming the gauges stay on) the crank sensor is fine.
Parts that are new=
Parts that are new=
I agree it sounds like a crank sensor, but its hard to give you an accurate diag without seeing the car. Does the vehicle have a tach? do you have a scanner so you can see the datastream values or PID's?
I've seen 3800 ckp sensors fail when they get warm and I've seen a bunch of the wiring connectors fail, you will notice the engine cut out when you wiggle the connector, the connector is beside the harmonic balancer (right side)
One way you could rule out a fuel issue is to give the engine a false fuel source when its not running, try spraying brake clean into the throttle body during the cranking no start, if it starts and dies then you know its a fuel delivery issue, if it doesn't change anything then its most likely not the problem
