Got a problem with my lights
Hey i got a problem with my signal lights they light up fine in the front and in the back but they don't blink it sucks because i need them to pass inspection. Any help would be great.
Im not sure what it could be but it does not light up at all in the dash and no blinking noise but the signal lights (next to the fog lights) lite up fine. Whats a flasher? Lights where working fine tell I changed out the front two signal lights because one of them went out. No they just stay on no blinking no noise no nothing.
Might want to take a look at these related threads...
https://ls1tech.com/forums/wiring-stereo-electronics/197698-turn-signal-sucks-used-search.html
https://ls1tech.com/forums/appearance-detailing/201238-turn-signal-flasher.html
https://ls1tech.com/forums/general-maintenance-repairs/218683-left-turn-signal-won-t-flash.html
https://ls1tech.com/forums/wiring-stereo-electronics/181587-slow-turn-signals.html
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/167943-blinker-problem.html
https://ls1tech.com/forums/wiring-stereo-electronics/198573-flasher-location.html
https://ls1tech.com/forums/wiring-stereo-electronics/56359-turn-signal-flasher.html
https://ls1tech.com/forums/wiring-stereo-electronics/71795-blinker-problem-not-found-search.html
https://ls1tech.com/forums/wiring-stereo-electronics/87757-turn-signals.html
https://ls1tech.com/forums/wiring-stereo-electronics/56125-help-all-new-bulbs-turn-signals-still-don-t-blink.html
https://ls1tech.com/forums/wiring-stereo-electronics/95024-blinker-problem.html
https://ls1tech.com/forums/wiring-stereo-electronics/160618-does-anyone-know-where-turn-signal-relay-these-cars.html
https://ls1tech.com/forums/wiring-stereo-electronics/76209-blinker-not-working-help.html
https://ls1tech.com/forums/wiring-stereo-electronics/56596-turn-signals-don-t-work-experts-inside-please.html
https://ls1tech.com/forums/wiring-stereo-electronics/130977-different-turn-signal-brake-light-problem.html
https://ls1tech.com/forums/wiring-stereo-electronics/152256-turn-signal-flasher.html
Since you just replaced the bulbs, I'd guess either a broken/damaged/shorting wire jarred into a problem position when you were changing the bulbs, or a problem with the flasher relays...
(The flashers are what turn the lights on and off to make them blink... there's one to control the turn signal flashing, and a second one to control the hazard flashing.)
How do you install the flasher I just bought one now and can't find where to replace it
The flasher I bought is an LF12 Flasher is this the right one?
If not I will have to return it.
Hey thanks for the help I finally got the right part number and found where the flasher was hiding damn it was hard to find. It was a metallic color and the only way I found it was that I saw the hazard flasher on the oppisite side and it had a red piece going into it.
I just want to put this whole bad expirence behind me.
Originally Posted by 98NBM_TransAm
I had the same problem, i just replaced the bulb "socket" and they work fine now.
I got them from a scrap yard, they were pricy, $15, but it works alot better now, there website is www.americancamaro.com theyre based here in oklahoma. Chances are you'll have to call and just ask the best price they'll give it to you.
