Old 05-13-2016, 02:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevoret Camaro or Pontiac Firebird Brake Guides
Browse all: Brake Guides
Print Wikipost
CTS-V Brake Install w/ Pics
Old 07-09-2013, 10:50 PM
  #481
cancam99ss's Avatar
Anyone have the link for the lines needed for this swap
Old 07-10-2013, 05:22 AM
  #482
LS1HIGHLIFE's Avatar
Google Kore3 or flynbyme.
Old 07-15-2013, 01:33 AM
  #483
TX RED's Avatar
went to my local autozone and got z06 rotors for $65 each
Old 07-20-2013, 10:54 AM
  #484
JetMech99's Avatar
Not sure if it's been asked or not, but would increasing the front brakes stopping power and leaving the rears stock screw up the brake balance at all? Under hard corner braking on a track for instance?
Also, has anyone done any testing on how many feet it takes 60-0 stockers vs. these? This is most likely the next upgrade with my new found power, just curious about a few things.
Old 07-21-2013, 06:05 PM
  #485
itsme4g63's Avatar
Don't know if the abs system is a carryover from the gm parts bin for 2004-2006 gtos, but I design both 4/6 piston front and 4 piston rear mounting kits for them and just with the 4/6 piston front you feel the abs is at unease under some hard braking situations, once the 4 piston rears are installed all issues are resolved.
Old 07-25-2013, 10:58 PM
  #486
z28jimmy's Avatar
Does anyone know if the 2010 camaro ss calipers front and rear will fit a 97 camaro? Will the fronts fit like the ctsv ones do? and has anyone done the rear brakes?
Old 07-26-2013, 05:27 AM
  #487
No & no. You will have to sitch to LS1 spindles & drill out the mounting holes to 9/16".
Old 07-26-2013, 08:42 AM
  #488
UNDER PRESSURE MOD
The Alchemist's Avatar
What I have found is that with the larger brakes up front, you are able to push them harder before abs is ever engaged. When I have had to use the abs, it works fine. Thankfully it hasn't been that often.
Old 07-31-2013, 03:29 PM
  #489
SSInnovations's Avatar
Can someone recommend a machine shop in SE Michigan to take the rotors to? I need the hubs opened up....
Old 08-07-2013, 09:26 AM
  #490
I found a guy that did it for $10 a rotor!
If anybody in SE MI needs the contact send me a PM.
Old 09-01-2013, 10:09 PM
  #491
badformulaLS1's Avatar
I didn't read all these pages but I remember seeing somewhere that someone figured out how to make them fit a 17in wheel? Can someone link me to that thread? Need to see how hard it is before I make my wheel purchase.
Old 09-06-2013, 02:44 PM
  #492
FASTFATBOY's Avatar
Is the search function broken for you?
Search CTSV 17
Old 09-06-2013, 02:46 PM
  #493
FASTFATBOY's Avatar
You never brake in a corner on track, you get all the braking done prior to turn in.
These cars have way to much back brake in the first place. Bigger fronts help that.
Old 09-24-2013, 10:51 AM
  #494
trans_am7935's Avatar
i completely agree. i have not activated my ABS yet since my CTS-V brake install, but when braking to a quick stop is just fantastic now! around town it has a great feel to the pedal.
Old 10-11-2013, 06:55 AM
  #495
Sy99T/A's Avatar
https://ls1tech.com/forums/suspensio...s-17-rims.html
Old 01-16-2014, 12:54 PM
  #496
CranMaro99's Avatar
BAM!
Old 01-29-2014, 02:49 PM
  #497
unstable Vic's Avatar
Do we order pads for the camaor 2010+ or pads for the ctsv? I got the ctsv calipers, pin kit, kore3 lines and the 2010+ rotors. Just need to know what brake pads to use. Thank yiou
Old 01-29-2014, 05:42 PM
  #498
bluestreak98's Avatar
Old 01-29-2014, 07:28 PM
  #499
Originally Posted by bluestreak98
Dude, that's nice! I bet you cant get an RCH in between those and the barrel.
Details of set-up?
Old 01-30-2014, 09:12 AM
  #500
Details of set-up?
Thanks, I need to take better pics when the car is clean.
I have 18x10.5 C5Z06 wheels on all 4 corners. The brakes are GEN 2 CTSV with kore3 lines, C6Z06 stop tech rotors, and Hawk pads.
Quick Reply: CTS-V Brake Install w/ Pics
