Conversion folks please list your conversion in here
Old Aug 1, 2010 | 09:50 AM
  #981
radiowaves88's Avatar
Donor vehicle: 2000 Camaro SS
Into: 1946 Chevy 1/2 ton pickup
LS1/4L60E with Corvette C4 suspension
http://public.fotki.com/radiowaves88...hevy-pickup-s/
Old Aug 2, 2010 | 05:32 PM
  #982
Teetoe_Jones's Avatar
Originally Posted by Teetoe_Jones
1968 Camaro.
1997 C5 chassis, LS1 T56 rear mounted transaxle.
Wicked *** car.
www.t56kit.com
A lot has changed since that post. The car is still being built though and you can follow along here:
http://corner-carvers.com/forums/showthread.php?t=43362
Tyler
Old Aug 23, 2010 | 08:17 AM
  #983
cemlsx's Avatar
98 Firebird 3.8 convertible , lsx 454 , possibly L92 heads and a fast 102 intake
Old Aug 24, 2010 | 07:15 PM
  #984
byrons1502's Avatar
Default 1972 chevelle ls9
1972 chevelle convertible
2009 corvette ls9 6.2ltr.
6speed auto
Attached Thumbnails Conversion folks please list your conversion in here-72-chevelle.jpg
Old Aug 25, 2010 | 04:35 AM
  #985
rsz288's Avatar
6speed auto
Very nice!!!!!!!
Old Aug 27, 2010 | 08:58 PM
  #986
classic79's Avatar
Default 89 suburban
1989 Chevy Suburban R1500 2wd
put a 2002 Chevy 4.8l out of a silverado into it.
Used the burbs 700r4 trans,
Motor was purchased complete with wiring harness, computer, fan, manifolds.
Have approximately 1800 into swap.
Quick run down for those doing the same or similar.
89 burb is the old old body style truck
used carshop inc 1" setback mounts and put the engine where the original trans did not move any.
also used the carshop fuel line fitting adapters.
the GM flexplate adapter and also purchased the bolts recommended but they were the same length as my current bolts it was part #11569956.
used the a/c delco EP381 fuel pump swapped right in.
for guages: oil pressure used the 4.8's sending unit and cut the wire on it and spliced in my 89 burb sending unit wire. works great.
Cooling the 89 burb has 2 coolant temp sensors the guage one is in the driverside head on the 350tbi one wire. used the s&p adapter to put it in the pass. head on the 4.8. no problems there.
voltage guage I did not touch used the wiring as the 4.8 came and just hooked up my battery wire to the alternator and it charges fine and volt guage works.
For wiring the engine followed the lt1swap.com page like a road map. Awesome info there and had Branden program my computer, sent it out monday got it back on friday works great. and great price too.
I used the newer model underhood fuse block I got from a junk truck for 20 bucks along with a mass air meter.
For the 700r4 transmission I used the Bowtie overdrive TV made easy kit for the tv cable. Great piece of enginerring, a little pricey but well worth it, and there customer service is outstanding.
for the lockup I used the tci lock up kit, another member advised to use the b&m kit, it cost more, but i should have done just that. The TCI kit uses vacumm to control lock up and the B&M uses a speed sensor. The TCI I have shuttles back and forth between lock and unlock all the time. Had to install the manual lock override switch to cruise. Hate having to flip a switch just to go down the highway without the convertor shuttling. Lesson learned here, hope others don't repeat my mistake.
I ordered a Novak a/c relocation kit for my r4 compressor just to avoid having to make new lines for saden compressor, buy a saden compress, and buy the brackets for them, and having to refill the suburban with freon. It holds about 5 pounds of freon so its pricey to refill.
That should cover most of it, any questions let me know will try my best to help. I got a lot of help from this board and the search feature.
Thanks,
Chris
Old Aug 28, 2010 | 02:37 PM
  #987
LS1MonteSS's Avatar
1) 1970 Monte Carlo w/ Boss wheels (18" Front, 20" Rear)
2) L96, 6L90E
Wanted Mods: LS3 intake, New cam(unsure of spec yet) 9" w/3.42 or 3.73 gears
Hotchkis springs/shocks all around, ATS Tall Spindles,
C6 Z06 Brakes/Rotors, 08 GTO Seats, Flush mounted glass,
New custom headlights and LED Tail Lights, Shaved door handles,
New accessory drive brackets.... I think that is a good start.
3) Still working on starting a site and getting pictures.
I'm really taking the Ole' Hot Rod approach to this project in that I'm modifying what is already out there for this build..
Old Aug 29, 2010 | 02:23 PM
  #988
boogiewonderland's Avatar
Default disco camaro
1980 camaro losing the late model 5.7 and th350 for a lq4 and 700r4 using a holley carb to feed it and edlebrock intake and ignition. I did not want to deal with the wiring and gremlins that efi can present.
Old Aug 29, 2010 | 05:16 PM
  #989
rao's Avatar
rao
E39 1998 BMW 540i LS@ stroker swap
https://ls1tech.com/forums/conversio...completed.html
Old Aug 29, 2010 | 08:43 PM
  #990
S10xGN's Avatar
Sorry, just realized I never posted my '03 Corvette LS-1 powered '72 Maverick! Details in my sig and pix in my gallery...
Old Sep 1, 2010 | 11:21 AM
  #991
gopokes's Avatar
Default 71 c10
I'm putting a 5.3 out of an 03 Tahoe on my old 71 C10 pickup.
Old Sep 1, 2010 | 09:35 PM
  #992
chevydog66's Avatar
72 GMC Super Custom 1500 with a 01 6.0 LQ4 and 4L65 trans. Doug Thorley 324yc headers, Speartech modified harness. TPI parts adapter plates, Prothane motor mounts.
Attached Thumbnails Conversion folks please list your conversion in here-dsc00205.jpg   Conversion folks please list your conversion in here-img_1158.jpg   Conversion folks please list your conversion in here-dsc00271.jpg
Old Sep 4, 2010 | 02:20 AM
  #993
fabron's Avatar
Talking 1971 Corzilla with L33 5.3L and 5 spd
I am in the process of reviving an old school rear drive 'rolla TE27. Target weight is 2000LBS and under 2000 dollars, including the price of the car! I have so far done all work myself including all welding, machining, designing, wiring, and soon to be painting. I will be purchasing HP Tuners so that I can put LS motors in all my cars. My 1972 Opel Manta will soon receive the same treatment. When my 310,000 mile 454 K3500 retires it'll get a 6.0L.
Old Sep 8, 2010 | 07:05 AM
  #994
1932ls6's Avatar
Default LS6 Long Block Build Up
I am currently building a LS6 for my 1932 street rod. Engine will have the Edelbrock performer manifold and complete MSD ignition/coil system. Edelbrock 800 CFm carb, coil covers and Billet Specialties front end.
Old Sep 12, 2010 | 06:18 PM
  #995
BOWTIECJ7's Avatar
1985 Jeep Cj7
2003 5.3L Avalanche, TH350, NP205
Old Sep 17, 2010 | 08:37 PM
  #996
erox's Avatar
Guess I can throw mine up
93 RX7
LS1/T56
Build photos so far
Old Sep 20, 2010 | 05:42 PM
  #997
grifter757's Avatar
Car has been converted since I think 03 or 04. just finished the RE-Build of the car.
Build is here https://ls1tech.com/forums/forced-in...roc-boost.html
Added pics.
Well I'm still finishing up some things but the car runs and drives (most of the time). Here are a few randoms of the car.
Suspension
Interior
Low...
Old Sep 27, 2010 | 02:31 AM
  #998
the_merv's Avatar
Veteran: Air Force
1998 Camaro V6 -> big *** LS Engine..
https://ls1tech.com/forums/conversio...-6-7l-t56.html
1000th post ftw..
Old Sep 29, 2010 | 11:02 AM
  #999
jojomanx's Avatar
Default LS1 BMW 5 series e34
More than a year ago I finished my 535i (now classified as a 557i) BMW.
Check out my garage and youtube video.
Old Sep 30, 2010 | 10:28 PM
  #1000
dtom001's Avatar
Default Winter Project
1964 Bel Air
6.0L LQ4/4L80
Image enclosed I think...
Should be wicked torquey and driveable
Attached Thumbnails Conversion folks please list your conversion in here-cimg0809.jpg
