s10 ls1ers
Old Nov 20, 2007 | 08:09 AM
  #1301
Frank02L's Avatar
Again, does anybody have a picture at the back of the firewall to show how close the heads are to the firewall?
Old Nov 20, 2007 | 10:52 AM
  #1302
philntx's Avatar
They are close.
I'm using hydroboost so my clearance on the drivers side will be more than a truck with a standard booster.
Old Nov 20, 2007 | 10:53 AM
  #1303
philntx's Avatar
Originally Posted by Horsepwraddict
these are pictures of PhilinTX truck, good shots of the mounts for comparison.
and mine.
i just went out and checked again, they are set up the exact same way. The longer mounts is on the passenger side.
Preciate the pics, but this one isn't mine.
Old Nov 20, 2007 | 11:01 AM
  #1304
Horsepwraddict's Avatar
sorry, got it from one of your posts so I just assumed, my bad. Still gets the point across though.
Old Nov 20, 2007 | 11:46 AM
  #1305
Frank02L's Avatar
Thanks for the pics phil. We're going to put a manual m/c on our build. And the heat and a/c stuff is gonna be gone.
Old Nov 20, 2007 | 12:43 PM
  #1306
lt1s10's Avatar
hey phil, what is your steering set up??
Old Nov 20, 2007 | 01:55 PM
  #1307
philntx's Avatar
Using a quick ratio gearbox, high output pump (for the hydroboost), double-D steering shaft, but stock from there out.
Old Nov 20, 2007 | 06:11 PM
  #1308
jimjim's Avatar
Default Lurkers LS1 Xtreme
Hi Guys; Just thought I'd throw in a couple pics of my '00 Xtreme. Its got a "00 LS1, LS1 type 12" front brakes, Exploerer 3.73 posi rear w/ 11' disc brakes and the complete leather (w/ wood trim) interior from a '00 Bravada. I've been driving it now for about 6 months with little or no problems. (Does anyone know of a Doctor who can remove lead from your right foot?)....Jim
Old Nov 20, 2007 | 06:27 PM
  #1309
jimjim's Avatar
Default Oops
Sorry, heres the pics
Old Nov 20, 2007 | 11:51 PM
  #1310
nice lookin truck man. Welcome to the site.
Old Nov 22, 2007 | 01:28 AM
  #1311
01WS6/tamu's Avatar
A4 guys. What type of lines did you use for the trans cooler lines. I had a set for a fullsize with an ls and they hit everything. I have my stock lines at the shop and I guess I'll try those tomorrow. If anyone has run AN line sets does anyone make an AN fitting that will lock into the OEM quick connects on the transmission case? Later and happy turkey day.
Old Nov 22, 2007 | 01:30 PM
  #1312
BluLS1's Avatar
will the factory lines not work any better either?
Old Nov 22, 2007 | 10:16 PM
  #1313
Bigdeezs's Avatar
Yea I used the stock f-body lines...they fit pretty nicely.
Old Nov 24, 2007 | 11:10 PM
  #1314
almostfast's Avatar
same here...
Old Nov 25, 2007 | 04:09 PM
  #1315
Frank02L's Avatar
Couple pictures so far.
Old Nov 25, 2007 | 10:27 PM
  #1316
01WS6/tamu's Avatar
I got the 4.3 lines to work. I just fabbed some an hoses since I am running a full external cooler and no radiator cooler.
I tore down the front suspension to put in all of the ZQ8 goodies off of my other truck. I need to replace all of the upper and lower control arm bushings. How much of a loss of ride quality and increase in noise will I get by going to poly urethane. This is a DD and I do not want the twitchy steering like an Fbody has. It great for smooth roads but out here in BFE your shoulders and arms hurt from constantly correcting the steering. My fullsize firmed up nicely but was not objectionable when I swapped to urethane on it.
Old Nov 26, 2007 | 06:24 AM
  #1317
LSXS10's Avatar
I put urethane in all my front susp. , its a little firmer but not bothersome...I live in BFE too
Old Nov 26, 2007 | 12:33 PM
  #1318
Jhankinson's Avatar
I like my Poly front bushings. If you grease the hell outta them when you install them...they wont squeek at all. Its a little stiff...but overall I like it quite nicely. Def dont need to be correcting steering constantly...its just a lil more firm than stock
Old Nov 26, 2007 | 05:24 PM
  #1319
01WS6/tamu's Avatar
I guess It was here that I heard that the 2wd blazers use the same sway bar as a zq8 truck. If this is the case does anyone know what size it is so I can order bushings. Thanks
Old Nov 26, 2007 | 05:43 PM
  #1320
blazerls1's Avatar
i just finished replacing mine about 10 min ago.I used 1 1/4 energy suspension.You can get these at autozone....
